Article: ARM Goes 64-bit
By: Paul A. Clayton (paaronclayton.delete@this.gmail.com), August 17, 2012 6:19 am
Kenneth Jonsson (kj.delete@this.localhost.org) on August 17, 2012 2:41 am wrote:
[snip Actual Data on register use]
Thank you for providing the data. Even such a small sample looks interesting.
> So to spin the question a bit: what are the
> downsides of a large number of GPRs?
For x86-64 instruction encoding was (it seems) the biggest issue. AArch64 uses (fixed-size) 32-bit instructions, so five bit register names are reasonable.
Increasing the number of registers obviously increases the size of the register file (which means more area and both more active and more static power use). Register renaming faces a similar issue, possibly more so since the number of reads and writes per cycle in the renaming structure will be greater than the number of register reads and writes per cycle (after a branch misprediction some instructions will almost certainly have been renamed but not executed--a possible exception would be with a multithreaded core).
In addition, renaming it seems tends to be handled in a more brute force manner and with a guaranteed fixed output; register reading is often avoided by result forwarding (and some implementations reduce the number of register read ports so that peak execution would not be possible without some forwarding and/or reduced number of register sources [e.g., operations with an immediate source and moves]). Reducing the number of register read ports may be more attractive in an OoO design (and an OoO design might also make write port reduction more practical). In some implementations, a write into the renamer table also reads the preceding value, adding a read port that would not be needed for the register file.
There are mechanisms to reduce the port count for the renaming table. Predecoded instructions, especially in a trace cache with its single entry point nature, could support the use of banking and deduplication (of both reads and writes). Banking and asymmetric porting can reduce the overhead of table access itself. (Increasing the number of architected registers could increase the opportunities for banking and other special cases.) These would tend to remove guaranteed throughput, but such might be an acceptable trade-off for greater typical throughput within an area/power budget.
>It has to be fairly big trade-offs to be
> made somewhere as very few architectures seem to move beyond 32 GPRs and AMD did
> for some reason settle at 16 GPRs when they designed x86_64.
It is difficult to fit 6-bit register names in a 32-bit instruction without excessive sacrifices in immediate sizes and other areas--ISAs with more than 32 registers tend to have longer instructions (e.g., 40 for IBMs experimental HPC ISA and 41 for Itanium, though Cell's SPEs have 128 registers with 32-bit instructions). (Likewise, adding four register name extension bits rather than two for REX prefixes would have been more difficult without using a two-byte prefix.)
> Not a perfect comparison, but the performance difference
> between IA32 and x86_64 is very small so IA32 cannot be held
> back too much by its lack of GPRs.
64-bit points supposedly eat about 10% of performance, IIRC; so the gain from more registers is mostly consumed by larger pointers. (x86-64 also slightly increases code size, which might have a tiny performance impact.)
[snip]
> Sorry for a long post, interesting topic i.m.h.o :)
Long posts are quite acceptable if they have good content, and I certainly cannot complain because I have a severe problem with being concise. I agree the topic is interesting.
[snip]
| Topic | Posted By | Date |
| New Article: ARM Goes 64-bit | David Kanter | 08/14/12 12:04 AM |
| New Article: ARM Goes 64-bit | none | 08/14/12 12:44 AM |
| New Article: ARM Goes 64-bit | David Kanter | 08/14/12 01:04 AM |
| MIPS MT-ASE | Paul A. Clayton | 08/14/12 09:01 AM |
| MONITOR/MWAIT | EduardoS | 08/14/12 10:08 AM |
| MWAIT not specifically MT | Paul A. Clayton | 08/14/12 10:36 AM |
| MWAIT not specifically MT | EduardoS | 08/15/12 03:16 PM |
| MONITOR/MWAIT | anonymou5 | 08/14/12 11:07 AM |
| MONITOR/MWAIT | EduardoS | 08/15/12 03:20 PM |
| MIPS MT-ASE | rwessel | 08/14/12 10:14 AM |
| New Article: ARM Goes 64-bit | SHK | 08/14/12 02:01 AM |
| New Article: ARM Goes 64-bit | anon | 08/14/12 02:37 AM |
| New Article: ARM Goes 64-bit | Richard Cownie | 08/14/12 03:57 AM |
| New Article: ARM Goes 64-bit | anon | 08/14/12 04:29 AM |
| New Article: ARM Goes 64-bit | none | 08/14/12 04:44 AM |
| New Article: ARM Goes 64-bit | anon | 08/14/12 05:28 AM |
| New Article: ARM Goes 64-bit | anon | 08/14/12 05:32 AM |
| New Article: ARM Goes 64-bit | EduardoS | 08/14/12 06:06 AM |
| New Article: ARM Goes 64-bit | none | 08/14/12 05:40 AM |
| AArch64 select better than cmov | Paul A. Clayton | 08/14/12 06:08 AM |
| New Article: ARM Goes 64-bit | anon | 08/14/12 06:12 AM |
| New Article: ARM Goes 64-bit | none | 08/14/12 06:25 AM |
| Predicated ld/store are useful | Paul A. Clayton | 08/14/12 06:48 AM |
| Predicated ld/store are useful | none | 08/14/12 06:56 AM |
| Predicated ld/store are useful | anon | 08/14/12 07:07 AM |
| Predicated stores might not be that bad | Paul A. Clayton | 08/14/12 07:27 AM |
| Predicated stores might not be that bad | David Kanter | 08/15/12 01:14 AM |
| Predicated stores might not be that bad | Michael S | 08/15/12 11:41 AM |
| Predicated stores might not be that bad | R Byron | 08/17/12 04:09 AM |
| New Article: ARM Goes 64-bit | anon | 08/14/12 06:54 AM |
| New Article: ARM Goes 64-bit | none | 08/14/12 07:04 AM |
| New Article: ARM Goes 64-bit | anon | 08/14/12 07:43 AM |
| New Article: ARM Goes 64-bit | EduardoS | 08/14/12 06:07 AM |
| New Article: ARM Goes 64-bit | anon | 08/14/12 06:20 AM |
| New Article: ARM Goes 64-bit | none | 08/14/12 06:29 AM |
| New Article: ARM Goes 64-bit | anon | 08/14/12 07:00 AM |
| New Article: ARM Goes 64-bit | Michael S | 08/14/12 03:43 PM |
| New Article: ARM Goes 64-bit | Richard Cownie | 08/14/12 06:53 AM |
| OT: Conrad's "Youth" | Richard Cownie | 08/14/12 07:20 AM |
| New Article: ARM Goes 64-bit | EduardoS | 08/14/12 06:04 AM |
| New Article: ARM Goes 64-bit | mpx | 08/14/12 08:59 AM |
| New Article: ARM Goes 64-bit | Antti-Ville Tuunainen | 08/14/12 09:16 AM |
| New Article: ARM Goes 64-bit | anonymou5 | 08/14/12 11:03 AM |
| New Article: ARM Goes 64-bit | name99 | 11/17/12 03:31 PM |
| Microarchitecting a counter register | Paul A. Clayton | 11/17/12 07:37 PM |
| New Article: ARM Goes 64-bit | bakaneko | 08/14/12 04:21 AM |
| New Article: ARM Goes 64-bit | name99 | 11/17/12 03:40 PM |
| New Article: ARM Goes 64-bit | EduardoS | 11/17/12 04:52 PM |
| New Article: ARM Goes 64-bit | Doug S | 11/17/12 05:48 PM |
| New Article: ARM Goes 64-bit | bakaneko | 11/18/12 05:40 PM |
| New Article: ARM Goes 64-bit | Wilco | 11/19/12 07:59 AM |
| New Article: ARM Goes 64-bit | EduardoS | 11/19/12 08:23 AM |
| New Article: ARM Goes 64-bit | Wilco | 11/19/12 09:31 AM |
| Downloading µarch-specific binaries? | Paul A. Clayton | 11/19/12 11:21 AM |
| New Article: ARM Goes 64-bit | EduardoS | 11/19/12 11:41 AM |
| New Article: ARM Goes 64-bit | Wilco | 11/21/12 07:44 AM |
| JIT vs. static compilation (Was: New Article: ARM Goes 64-bit) | VMguy | 11/22/12 03:21 AM |
| JIT vs. static compilation (Was: New Article: ARM Goes 64-bit) | David Kanter | 11/22/12 12:12 PM |
| JIT vs. static compilation (Was: New Article: ARM Goes 64-bit) | Gabriele Svelto | 11/23/12 03:50 AM |
| New Article: ARM Goes 64-bit | EduardoS | 11/23/12 10:09 AM |
| New Article: ARM Goes 64-bit | EBFE | 11/26/12 01:24 AM |
| New Article: ARM Goes 64-bit | Gabriele Svelto | 11/26/12 03:33 AM |
| New Article: ARM Goes 64-bit | EBFE | 11/27/12 11:17 PM |
| New Article: ARM Goes 64-bit | Gabriele Svelto | 11/28/12 02:32 AM |
| New Article: ARM Goes 64-bit | EduardoS | 11/26/12 12:16 PM |
| New Article: ARM Goes 64-bit | EBFE | 11/28/12 12:33 AM |
| New Article: ARM Goes 64-bit | EduardoS | 11/28/12 05:53 AM |
| New Article: ARM Goes 64-bit | Michael S | 11/28/12 06:15 AM |
| New Article: ARM Goes 64-bit | EduardoS | 11/28/12 07:33 AM |
| New Article: ARM Goes 64-bit | Michael S | 11/28/12 09:16 AM |
| New Article: ARM Goes 64-bit | EduardoS | 11/28/12 09:53 AM |
| New Article: ARM Goes 64-bit | Eugene Nalimov | 11/28/12 05:58 PM |
| Amazing! | EduardoS | 11/28/12 07:25 PM |
| Amazing! (non-italic response) | EduardoS | 11/28/12 07:25 PM |
| Amazing! | EBFE | 11/28/12 08:20 PM |
| Undefined behaviour doubles down | EduardoS | 11/28/12 09:10 PM |
| New Article: ARM Goes 64-bit | EBFE | 11/28/12 07:54 PM |
| New Article: ARM Goes 64-bit | EduardoS | 11/28/12 09:21 PM |
| Have you heard of Transmeta? | David Kanter | 11/19/12 03:47 PM |
| New Article: ARM Goes 64-bit | bakaneko | 11/19/12 09:08 AM |
| New Article: ARM Goes 64-bit | David Kanter | 11/19/12 03:40 PM |
| Semantic Dictionary Encoding | Ray | 11/19/12 10:37 PM |
| New Article: ARM Goes 64-bit | Rohit | 11/20/12 04:48 PM |
| New Article: ARM Goes 64-bit | David Kanter | 11/20/12 11:07 PM |
| New Article: ARM Goes 64-bit | Wilco | 11/21/12 06:41 AM |
| New Article: ARM Goes 64-bit | David Kanter | 11/21/12 10:12 AM |
| A JIT example | Mark Roulo | 11/21/12 10:30 AM |
| A JIT example | Wilco | 11/21/12 07:04 PM |
| A JIT example | rwessel | 11/21/12 09:05 PM |
| A JIT example | Gabriele Svelto | 11/23/12 03:53 AM |
| A JIT example | EduardoS | 11/23/12 10:13 AM |
| A JIT example | Wilco | 11/23/12 01:41 PM |
| A JIT example | EduardoS | 11/23/12 02:06 PM |
| A JIT example | Gabriele Svelto | 11/23/12 04:09 PM |
| A JIT example | Symmetry | 11/26/12 05:58 AM |
| New Article: ARM Goes 64-bit | Ray | 11/19/12 10:27 PM |
| New Article: ARM Goes 64-bit | David Kanter | 08/14/12 09:11 AM |
| v7-M is Thumb-only | Paul A. Clayton | 08/14/12 06:58 AM |
| Minor suggested correction | Paul A. Clayton | 08/14/12 08:33 AM |
| Minor suggested correction | anon | 08/14/12 08:57 AM |
| New Article: ARM Goes 64-bit | Exophase | 08/14/12 08:33 AM |
| New Article: ARM Goes 64-bit | David Kanter | 08/14/12 09:16 AM |
| New Article: ARM Goes 64-bit | jigal | 08/15/12 01:49 PM |
| Correction re ARM and BBC Micro | Paul | 08/14/12 08:59 PM |
| Correction re ARM and BBC Micro | Per Hesselgren | 08/15/12 03:27 AM |
| Memory BW so low | Per Hesselgren | 08/15/12 03:14 AM |
| Memory BW so low | none | 08/15/12 11:16 AM |
| New Article: ARM Goes 64-bit | dado | 08/15/12 10:25 AM |
| Number of GPRs | Kenneth Jonsson | 08/16/12 02:35 PM |
| Number of GPRs | Exophase | 08/16/12 02:52 PM |
| Number of GPRs | Kenneth Jonsson | 08/17/12 02:41 AM |
| Ooops, missing link... | Kenneth Jonsson | 08/17/12 02:44 AM |
| 64-bit pointers eat some performance | Paul A. Clayton | 08/17/12 06:19 AM |
| 64-bit pointers eat some performance | bakaneko | 08/17/12 08:37 AM |
| Brute force seems to work | Paul A. Clayton | 08/17/12 10:08 AM |
| Brute force seems to work | bakaneko | 08/17/12 11:15 AM |
| 64-bit pointers eat some performance | Richard Cownie | 08/17/12 08:46 AM |
| Pointer compression is atypical | Paul A. Clayton | 08/17/12 10:43 AM |
| Pointer compression is atypical | Richard Cownie | 08/17/12 12:57 PM |
| Pointer compression is atypical | Howard Chu | 08/22/12 10:17 PM |
| Pointer compression is atypical | Richard Cownie | 08/23/12 04:48 AM |
| Pointer compression is atypical | Howard Chu | 08/23/12 06:51 AM |
| Pointer compression is atypical | Wilco | 08/17/12 02:41 PM |
| Pointer compression is atypical | Richard Cownie | 08/17/12 04:13 PM |
| Pointer compression is atypical | Ricardo B | 08/19/12 10:44 AM |
| Pointer compression is atypical | Howard Chu | 08/22/12 10:08 PM |
| Unified libraries? | Paul A. Clayton | 08/23/12 07:49 AM |
| Pointer compression is atypical | Richard Cownie | 08/23/12 08:44 AM |
| Pointer compression is atypical | Howard Chu | 08/23/12 05:17 PM |
| Pointer compression is atypical | anon | 08/23/12 08:15 PM |
| Pointer compression is atypical | Howard Chu | 08/23/12 09:33 PM |
| 64-bit pointers eat some performance | Foo_ | 08/18/12 12:09 PM |
| 64-bit pointers eat some performance | Richard Cownie | 08/18/12 05:25 PM |
| 64-bit pointers eat some performance | Richard Cownie | 08/18/12 05:32 PM |
| Page-related benefit of small pointers | Paul A. Clayton | 08/23/12 08:36 AM |
| Number of GPRs | Wilco | 08/17/12 06:31 AM |
| Number of GPRs | Kenneth Jonsson | 08/17/12 11:54 AM |
| Number of GPRs | Exophase | 08/17/12 12:44 PM |
| Number of GPRs | Kenneth Jonsson | 08/17/12 01:22 PM |
| Number of GPRs | Wilco | 08/17/12 02:53 PM |
| What about dynamic utilization? | Exophase | 08/17/12 09:30 AM |
| Compiler vs. assembly aliasing knowledge? | Paul A. Clayton | 08/17/12 10:20 AM |
| Compiler vs. assembly aliasing knowledge? | Exophase | 08/17/12 11:09 AM |
| Compiler vs. assembly aliasing knowledge? | anon | 08/18/12 02:23 AM |
| Compiler vs. assembly aliasing knowledge? | Ricardo B | 08/19/12 11:02 AM |
| Compiler vs. assembly aliasing knowledge? | anon | 08/19/12 06:07 PM |
| Compiler vs. assembly aliasing knowledge? | Ricardo B | 08/19/12 07:26 PM |
| Compiler vs. assembly aliasing knowledge? | anon | 08/19/12 10:03 PM |
| Compiler vs. assembly aliasing knowledge? | anon | 08/20/12 01:59 AM |
| Number of GPRs | David Kanter | 08/17/12 12:46 PM |
| RAT issues as part of reason 1 | Paul A. Clayton | 08/17/12 02:18 PM |
| Number of GPRs | name99 | 11/17/12 06:37 PM |
| Large ARFs increase renaming cost | Paul A. Clayton | 11/17/12 09:23 PM |
| Number of GPRs | David Kanter | 08/16/12 03:31 PM |
| Number of GPRs | Richard Cownie | 08/16/12 05:17 PM |
| 32 GPRs ~2-3% | Paul A. Clayton | 08/16/12 06:27 PM |
| Oops, Message-ID: aaed6e38-c7bd-467e-ba41-f40cf1020e5e@googlegroups.com (NT) | Paul A. Clayton | 08/16/12 06:29 PM |
| 32 GPRs ~2-3% | Exophase | 08/16/12 10:06 PM |
| R31 as SP/zero is kind of neat (NT) | Paul A. Clayton | 08/17/12 06:23 AM |
| 32 GPRs ~2-3% | rwessel | 08/17/12 08:24 AM |
| 32 GPRs ~2-3% | Exophase | 08/17/12 09:16 AM |
| 32 GPRs ~2-3% | Max | 08/17/12 04:19 PM |
| 32 GPRs ~2-3% | name99 | 11/17/12 07:43 PM |
| Number of GPRs | mpx | 08/17/12 01:11 AM |
| Latency and power | Paul A. Clayton | 08/17/12 06:54 AM |
| Number of GPRs | bakaneko | 08/17/12 03:09 AM |
| New Article: ARM Goes 64-bit | Steve | 08/17/12 02:12 PM |
| New Article: ARM Goes 64-bit | David Kanter | 08/19/12 12:42 PM |
| New Article: ARM Goes 64-bit | Doug S | 08/19/12 02:02 PM |
| New Article: ARM Goes 64-bit | Anon | 08/19/12 07:16 PM |
| New Article: ARM Goes 64-bit | Steve | 08/30/12 07:51 AM |
| Scalar vs Vector registers | Robert David Graham | 08/19/12 05:19 PM |
| Scalar vs Vector registers | David Kanter | 08/19/12 05:29 PM |
| New Article: ARM Goes 64-bit | Baserock ARM servers | 08/21/12 04:13 PM |
| Baserock ARM servers | Sysanon | 08/21/12 04:14 PM |
| A-15 virtualization and LPAE? | Paul A. Clayton | 08/21/12 06:13 PM |
| A-15 virtualization and LPAE? | Anon | 08/21/12 07:13 PM |
| Half-depth advantages? | Paul A. Clayton | 08/21/12 08:42 PM |
| Half-depth advantages? | Anon | 08/22/12 03:33 PM |
| Thanks for the information (NT) | Paul A. Clayton | 08/22/12 04:04 PM |
| A-15 virtualization and LPAE? | C. Ladisch | 08/23/12 11:12 AM |
| A-15 virtualization and LPAE? | Paul | 08/23/12 03:17 PM |
| Excessive pessimism | Paul A. Clayton | 08/23/12 04:08 PM |
| Excessive pessimism | David Kanter | 08/23/12 05:05 PM |
| New Article: ARM Goes 64-bit | Michael S | 08/22/12 07:12 AM |
| BTW, Baserock==product, Codethink==company (NT) | Paul A. Clayton | 08/22/12 08:56 AM |
| New Article: ARM Goes 64-bit | Reinoud Zandijk | 08/21/12 11:27 PM |
