PAE sucks (Why didn't MS take advantage of PAE?)
By: David W. Hess (dwhess.delete@this.banishedsouls.org), May 13, 2007 12:37 pm
Linus Torvalds (torvalds@osdl.org) on 5/13/07 wrote:
>PAE really really sucks.
>Reasons for why you need a bigger virtual space:
>- you need to map that physical memory somehow, and no,
>tiny windows into the physical memory simply do not
>cut it! If you cannot have normal pointers to the
>physical space, it immediately means that you need to
>jump through serious hoops to get there.
>- you additionally need to be able to remap things
>in alternate ways (ie user space) or make space for
>non-memory issues (virtual page tables, IO, you name it)
>Ergo, a factor-of-two is a requirement. PAE was a total
>and utter disaster.
>Yes, Linux supported it, and probably did so better than
>anybody else. But "better than anybody else" still wasn't
>very good. Because you couldn't use normal pointers to
>point to arbitrary physical memory, all the memory that
>couldn't be accessed directly (ie anythign that didn't fit
>in the virtual address map, which also had the user
>space memory in it) was basically limited to "special uses
>only".
Wow Linus. I hope you did not spend a lot of time on your post just to answer me because I did not think my post deserved that much attention. :) I am flattered.
I certainly agree that PAE sucks for the reasons you describe but what I wanted to get at was Microsoft's decision not to support PAE on the desktop when they had support already available.
For similar reasons, I questioned AMD's initial Athlon 64 offering for not allowing inexpensive dual processor workstation designs from the start but there I suspect AMD had better reasons then Microsoft for the decisions they made.
>I'm not at all surprised that Windows didn't push PAE
>either. It was a total braindamage. I bet they supported
>it in the server offerings just because they had to, and
>I bet they did a much worse job of it than Linux did, and
>the reason you can do that with servers is that the loads
>are much easier, and you can expect maintainers to set
>magic config entries to tweak it to make it appear
>to work well for any particular load, when in reality it
>is fragile as hell and works only with duct-tape and
>prayers.
>That kind of "duct-tape and prayers and lots of specialized
>knowledge about the load" is simply not possible in
>a desktop environment. Yeah, users have prayers, but they
>lack the duct-tape and the knowledge to work around the
>problems.
So it was an applications support issue instead of a marketing issue?
>And dammit, in this age and date when almost everybody
>has a gigabyte of RAM in any new machine, anybody who still
>thinks that "not that many people need 64-bits" is simply
>not aware of what he's speaking of.
I actually have 2 GB on my old Pentium 4 which is still my main machine and the reason I did not get more RAM was inadequate desktop support. Ya, I should be using a real operating system but getting past legacy applications has proven to be difficult for me.
>Go back and play with HIGHMEM.SYS on a 286, and stop
>blathering crap. When you've spent the last ten
>years of your life working with HIGHMEM.SYS, then
>you can come back and tell me that we still don't need
>64 bits. Until that is the case, anybody who still doesn't
>get why 64 bits is a requirement should just shut
>up rather than make a total fool of himself.>
Microsoft's Address Windowing Extensions allow this very use and I agree that it is at best a kludge. I was not advocating the use of 32 bits plus PAE over true 64 bit addressing but instead questioning Microsoft's lack of PAE support on the desktop before x86-64 became available. (Ha. Talk about getting back onto the previous "what should 64 bit x86 be called" topic.)
I did live through all the years of HIMEM.SYS and actually did some application programming at that time but I was more of a QEMM and Desqview guy. The whole situation sucked but at least I avoided Windows until 95 became available except for using Mathematica.
>So no, PAE does not mean that you can use more than
>4GB of RAM. Even before PAE, the practical limit was around
>1GB, and PAE didn't move that post a fraction of an inch!
I never argued that PAE allowed the use of more then 4GB of linear or virtual address space. It does allow the use of more then 4GB of physical address space by multiple seperate applications. I actually recently went through the current Intel documentation on segments, paging, etc. to confirm my thoughts on the subject.
Rock/Tukwila rumorsmas05/05/07 12:59 PM
  Rock/Tukwila rumorsDavid Kanter05/05/07 02:33 PM
    Rock/Tukwila rumorsDean Kent05/05/07 03:35 PM
      K8 vs Win64 timelineanonymous05/05/07 06:19 PM
        Yes, I misremembered...Dean Kent05/05/07 10:03 PM
    RockDaniel Bizó05/06/07 02:34 AM
      RockDean Kent05/06/07 07:11 AM
    Rock/Tukwila rumorsJoe05/06/07 11:24 AM
      Rock/Tukwila rumorsDean Kent05/06/07 11:49 AM
      Rock/Tukwila rumorsLinus Torvalds05/06/07 12:09 PM
      Rock/Tukwila rumorsanon05/07/07 01:32 AM
        Rock/Tukwila rumorsRakesh Malik05/07/07 09:36 AM
          Rock/Tukwila rumorsMichael S05/07/07 10:06 AM
          Rock/Tukwila rumorsanon05/07/07 09:48 PM
            Rock/Tukwila rumorsRakesh Malik05/08/07 06:45 AM
              Rock/Tukwila rumorsanon05/08/07 05:30 PM
                Wow. (nt)Brannon05/08/07 06:16 PM
                Rock/Tukwila rumorsrwessel05/08/07 09:48 PM
                  Rock/Tukwila rumorsJS05/08/07 10:07 PM
                    Rock/Tukwila rumorsJS05/09/07 06:44 AM
                Rock/Tukwila rumorsRakesh Malik05/09/07 05:35 AM
                  Much ado about xMichael S05/09/07 09:39 AM
                    Call it x86-64Linus Torvalds05/09/07 10:27 AM
                      (i)AMD64Michael S05/09/07 12:16 PM
                        (i)AMD64Linus Torvalds05/09/07 12:29 PM
                          (i)AMD64Groo05/09/07 04:45 PM
                          TIFNAAanonymous05/09/07 05:49 PM
                            Inspired by FYR Macedonia? (NT)Michael S05/09/07 11:21 PM
                              More likely...rwessel05/10/07 12:39 AM
                            TIFNAAGabriele Svelto05/09/07 11:57 PM
                          (i)AMD64James05/10/07 02:27 AM
                        i86Dean Kent05/09/07 12:30 PM
                        (i)AMD64Max05/09/07 01:28 PM
                          wide86? long86?hobold05/10/07 05:05 AM
                            x87 perhaps, it is one more. :) (NT)Groo05/10/07 05:50 AM
                              x86+Dean Kent05/10/07 08:44 AM
                                Does it really matter?Doug Siebert05/10/07 09:10 AM
                                  let's stay with x86-64 for now, pleaseMarcin Niewiadomski05/10/07 11:50 AM
                                    let's stay with x86-64 for now, pleaseDean Kent05/11/07 06:11 AM
                                      let's stay with x86-64 for now, pleaserwessel05/11/07 02:46 PM
                                        let's stay with x86-64 for now, pleaseDean Kent05/11/07 06:03 PM
                                          let's stay with x86-64 for now, pleaseMichael S05/12/07 10:49 AM
                                            let's stay with x86-64 for now, pleaseDean Kent05/12/07 01:05 PM
                                              let's stay with x86-64 for now, pleaseMichael S05/12/07 01:25 PM
                                                let's stay with x86-64 for now, pleaseDean Kent05/12/07 03:39 PM
                                                  let's stay with x86-64 for now, pleaseJasonB05/13/07 07:43 AM
                                                    client consolidationMichael S05/13/07 08:37 AM
                                                  let's stay with x86-64 for now, pleaseTzvetan Mikov05/13/07 03:44 PM
                                                let's stay with x86-64 for now, pleaserwessel05/14/07 02:42 PM
                                      What's your point?Doug Siebert05/11/07 02:56 PM
                                        What's your point?Linus Torvalds05/11/07 04:15 PM
                                          What's your point?Doug Siebert05/13/07 03:11 PM
                                            What's your point?Dean Kent05/13/07 07:04 PM
                                              What's your point?JasonB05/14/07 02:06 AM
                                                What's your point?Dean Kent05/14/07 07:20 AM
                                                  What's your point?JasonB05/14/07 04:35 PM
                                                  What's your point?JasonB05/14/07 07:35 PM
                                                    What's your point?Dean Kent05/14/07 08:12 PM
                                        What's your point?Dean Kent05/11/07 06:06 PM
                                        What's your point?Stephen H05/13/07 01:55 AM
                                          Why didn't MS take advantage of PAE?David W. Hess05/13/07 08:37 AM
                                            PAE sucks (Why didn't MS take advantage of PAE?)Linus Torvalds05/13/07 10:20 AM
                                              PAE sucks (Why didn't MS take advantage of PAE?)Dean Kent05/13/07 10:49 AM
                                              PAE sucks (Why didn't MS take advantage of PAE?)David W. Hess05/13/07 12:37 PM
                                              > 1 GB RAM on a 32-bit systemTzvetan Mikov05/13/07 01:44 PM
                                                > 1 GB RAM on a 32-bit systemS. Rao05/13/07 03:00 PM
                                                  > 1 GB RAM on a 32-bit systemTzvetan Mikov05/13/07 05:32 PM
                                                    > 1 GB RAM on a 32-bit systemS. Rao05/14/07 12:19 AM
                                                > 1 GB RAM on a 32-bit systemLinus Torvalds05/13/07 03:46 PM
                                                  > 1 GB RAM on a 32-bit systemTzvetan Mikov05/13/07 05:23 PM
                                                  > 1 GB RAM on a 32-bit systemJasonB05/13/07 06:37 PM
                                                    Windows manages memory differentlyTzvetan Mikov05/13/07 08:31 PM
                                                      Windows manages memory differentlyJasonB05/14/07 01:50 AM
                                                        Windows manages memory differentlyTzvetan Mikov05/14/07 08:56 AM
                                                          Windows manages memory differentlyrwessel05/14/07 03:40 PM
                                                            Windows manages memory differentlyDavid W. Hess05/14/07 04:07 PM
                                                              Windows manages memory differentlyrwessel05/14/07 04:51 PM
                                                            Windows manages memory differentlyTzvetan Mikov05/14/07 05:40 PM
                                                              Windows manages memory differentlyrwessel05/14/07 06:09 PM
                                                      Windows manages memory differentlyHoward Chu05/14/07 11:17 AM
                                                        Windows manages memory differentlyJukka Larja05/14/07 11:30 AM
                                                        Windows manages memory differentlyTzvetan Mikov05/14/07 01:54 PM
                                                          Windows manages memory differentlyHoward Chu05/15/07 03:35 AM
                                                            Windows manages memory differentlyGroo05/15/07 07:34 AM
                                                      Anyone know what OS X (10.4, Intel, desktop) does?Matt Sayler05/15/07 06:23 AM
                                                        Anyone know what OS X (10.4, Intel, desktop) does?Wes Felter05/15/07 08:37 AM
                                                        Anyone know what OS X (10.4, Intel, desktop) does?Anonymous05/15/07 10:49 AM
                                                        Anyone know what OS X (10.4, Intel, desktop) does?anon205/15/07 07:13 PM
                                              PAE sucks (Why didn't MS take advantage of PAE?)Paul05/13/07 03:40 PM
                                                PAE sucks (Why didn't MS take advantage of PAE?)Peter Arremann05/13/07 05:38 PM
                                                  PAE sucks (Why didn't MS take advantage of PAE?)Henrik S05/14/07 03:31 AM
                                              The fragility of your argumentslacker05/13/07 03:56 PM
                                                The fragility of your argumentnick05/13/07 05:42 PM
                                                The fragility of your argumentHoward Chu05/14/07 02:52 AM
                                                  The fragility of your argumentDean Kent05/14/07 09:19 AM
                                                The fragility of your argumentanon205/14/07 08:26 AM
                                                  The fragility of your argumentTzvetan Mikov05/14/07 09:01 AM
                                                  The fragility of your argumentDean Kent05/14/07 09:16 AM
                                                    The fragility of your argumentLinus Torvalds05/14/07 11:57 AM
                                                      The fragility of your argumentJasonB05/14/07 04:48 PM
                                                        The fragility of your argumentDean Kent05/14/07 07:36 PM
                                                          The fragility of your argumentRicardo B05/16/07 02:40 AM
                                                            The fragility of your argumentDean Kent05/16/07 03:32 AM
                                                              The fragility of your argumentRicardo B05/16/07 06:41 AM
        PSRicardo B05/16/07 06:50 AM
        The fragility of your argumentDean Kent05/16/07 09:07 AM
        Modern web browsingS. Rao05/16/07 09:16 AM
        Aha!Dean Kent05/16/07 09:27 AM
        Aha!Dean Kent05/16/07 09:32 AM
        Aha!S. Rao05/16/07 10:34 AM
        The fragility of your argumentRicardo B05/16/07 10:00 AM
                                                      The fragility of your argumentVincent Diepeveen05/16/07 10:10 AM
                                                        The fragility of your argumentPaul05/16/07 03:01 PM
                                                          The fragility of your argumentVincent Diepeveen05/17/07 03:05 AM
                                                    The fragility of your argumentanon205/15/07 01:35 AM
                                                    Splits vs page allocations?Matt Sayler05/15/07 07:33 AM
                                          What's your point?Michael S05/13/07 08:55 AM
                                            What's your point?anonymous05/13/07 11:08 AM
                                              What's your point?Michael S05/13/07 11:31 AM
                                      let's stay with x86-64 for now, pleaseJasonB05/13/07 07:16 AM
                                x864 =) (NT)some105/15/07 03:03 AM
    Rock/Tukwila rumorsIntelUser200005/06/07 02:27 PM
  Rock/Tukwila rumorsm05/13/07 08:05 AM
  Rock/Tukwila rumorsmas05/15/07 09:40 AM
How do you spell green?
