Market reasons to ditch the IGP
Article: Intel's Sandy Bridge Microarchitecture
By: EduardoS (no.delete@this.spam.com), February 19, 2011 10:13 am
Seni (seniike@hotmail.com) on 2/18/11 wrote:
>This is not a 32 bit processor, so addresses aren't 25+7. They are 57+7.
>To check to which elements are stored in the same cache line, you just have to
>run ALL POSSIBLE PAIRS in parallel through separate 57-bit comparators.
>So, for 8 lookups per AVX word, that's 36 comparators.
>With all 8 57-bit numbers running as a single 456-bit bus, and then each comparator
>running out taps to the 114 input bits it needs, I get 456 bits wide and 114*36= 4104 bits tall.
>This is a big thing. And that's just the wiring feeding into the comparators.
>Maybe it's not as easy as you thought?
Well.. Let's see, a AVX register have 256 bits wich is good for, 4 64 bits values, 8 32 bits values, 16 16 bits values or 32 8 bits values (aka bytes), if someone decides to use the full 64 bits addressing there are only 4 values for comparison, with 8 32-bits values (wich I believe would be the most common) there are only 32 bits to care about, one may still be able to use 64 bits addresing, by allowing a base address to be added to every value but we still only need to compare 32 bits values, the 25 bits thing, well, only if we require all values to be aligned (aka the lowest two bits to be zero), wich is dumb because if all valus are aligned then the value is likely an index wich would need a shift to be converted to an address and we lost 2 bits wich could be used to address more memory, if values are not aligned each access may access two cachelines, still plausible tought, anyway, assuming the aligned case with 64 byte cachelines there are 8 28 bits values to be compared, redoing the math, this would reduce your width and height, I still don't get what you mean by those big numbers, gather/scather isn't that expensive, I'm not sure about it's latency but I'm sure it won't be so big.
Sandy Bridge CPU article onlineDavid Kanter2010/09/26 09:35 PM
  Sandy Bridge CPU article onlineAlex2010/09/27 05:22 AM
    Sandy Bridge CPU article onlineDavid Kanter2010/09/27 10:06 AM
  Sandy Bridge CPU article onlinesomeone2010/09/27 06:03 AM
    Sandy Bridge CPU article onlineslacker2010/09/27 02:08 PM
      PowerPC is now PowerPaul A. Clayton2010/09/27 04:34 PM
    Sandy Bridge CPU article onlineDave2010/11/10 10:15 PM
  Sandy Bridge CPU article onlinesomeone2010/09/27 06:23 AM
    Sandy Bridge CPU article onlineDavid Kanter2010/09/27 06:39 PM
      Optimizing register clearPaul A. Clayton2010/09/28 12:34 PM
  Sandy Bridge CPU article onlineMS2010/09/27 06:54 AM
    Sandy Bridge CPU article onlineDavid Kanter2010/09/27 10:15 AM
      Sandy Bridge CPU article onlineMS2010/09/27 11:02 AM
      Sandy Bridge CPU article onlinempx2010/09/27 11:44 AM
        Sandy Bridge CPU article onlineMS2010/09/27 02:37 PM
          PreciselyDavid Kanter2010/09/27 03:22 PM
  Sandy Bridge CPU article onlineRichard Cownie2010/09/27 08:27 AM
    Sandy Bridge CPU article onlineDavid Kanter2010/09/27 10:01 AM
      Sandy Bridge CPU article onlineRichard Cownie2010/09/27 10:40 AM
        Sandy Bridge CPU article onlineboots2010/09/27 11:19 AM
          Right, mid-2011, not 2010. Sorry (NT)Richard Cownie2010/09/27 11:42 AM
        bulldozer single thread performanceMax2010/09/27 12:57 PM
          bulldozer single thread performanceMatt Waldhauer2011/03/02 11:32 AM
      Sandy Bridge CPU article onlinePun Zu2010/09/27 11:32 AM
      Sandy Bridge CPU article online?2010/09/27 11:44 AM
        Sandy Bridge CPU article onlineDavid Kanter2010/09/27 01:11 PM
          My opinion is that anything that would take advantage of 256-bit AVXredpriest2010/09/27 01:17 PM
            My opinion is that anything that would take advantage of 256-bit AVXAaron Spink2010/09/27 03:09 PM
              My opinion is that anything that would take advantage of 256-bit AVXredpriest2010/09/27 04:06 PM
                My opinion is that anything that would take advantage of 256-bit AVXDavid Kanter2010/09/27 05:23 PM
                  My opinion is that anything that would take advantage of 256-bit AVXIan Ollmann2010/09/28 03:57 PM
                    My opinion is that anything that would take advantage of 256-bit AVXIan Ollmann2010/09/28 04:35 PM
                      My opinion is that anything that would take advantage of 256-bit AVXMatt Waldhauer2010/09/28 10:58 PM
                My opinion is that anything that would take advantage of 256-bit AVXAaron Spink2010/09/27 06:39 PM
                  My opinion is that anything that would take advantage of 256-bit AVXIan Ollmann2010/09/28 04:14 PM
              My opinion is that anything that would take advantage of 256-bit AVXMegol2010/09/28 02:17 AM
                My opinion is that anything that would take advantage of 256-bit AVXMichael S2010/09/28 05:47 AM
                  PGICarlie Coats2010/09/28 10:23 AM
                    gfortran...Carlie Coats2010/09/29 09:33 AM
                  My opinion is that anything that would take advantage of 256-bit AVXmpx2010/09/28 12:58 PM
                    My opinion is that anything that would take advantage of 256-bit AVXMichael S2010/09/28 01:36 PM
                    My opinion is that anything that would take advantage of 256-bit AVXFoo_2010/09/29 01:08 AM
              My opinion is that anything that would take advantage of 256-bit AVXmpx2010/09/28 11:37 AM
                My opinion is that anything that would take advantage of 256-bit AVXAaron Spink2010/09/28 01:19 PM
                  My opinion is that anything that would take advantage of 256-bit AVXhobold2010/09/28 03:08 PM
                  My opinion is that anything that would take advantage of 256-bit AVXIan Ollmann2010/09/28 04:26 PM
                My opinion is that anything that would take advantage of 256-bit AVXAnthony2010/09/28 10:31 PM
          Sandy Bridge CPU article onlineHans de Vries2010/09/27 02:19 PM
            Sandy Bridge CPU article onlineDavid Kanter2010/09/27 03:19 PM
            Sandy Bridge CPU article online-Sweeper_2010/09/27 05:50 PM
              Sandy Bridge CPU article onlineDavid Kanter2010/09/27 06:41 PM
  Sandy Bridge CPU article onlineMichael S2010/09/27 02:55 PM
  Sandy Bridge CPU article onlineline982010/09/27 03:05 PM
    Sandy Bridge CPU article onlineDavid Kanter2010/09/27 03:20 PM
    Sandy Bridge CPU article onlineMichael S2010/09/27 03:23 PM
      Sandy Bridge CPU article onlineline982010/09/27 03:42 PM
        Sandy Bridge CPU article onlineDavid Kanter2010/09/27 09:33 PM
  Sandy Bridge CPU article onlineRoyi2010/09/27 04:04 PM
    Sandy Bridge CPU article onlineJack2010/09/27 04:40 PM
      Sandy Bridge CPU article onlineRoyi2010/09/27 11:47 PM
        Sandy Bridge CPU article onlineDavid Kanter2010/09/27 11:54 PM
          Sandy Bridge CPU article onlineRoyi2010/09/27 11:59 PM
            Sandy Bridge CPU article onlineJS2010/09/28 01:18 AM
              Sandy Bridge CPU article onlineRoyi2010/09/28 01:31 AM
                Sandy Bridge CPU article onlineJack2010/09/28 06:34 AM
                  Sandy Bridge CPU article onlineRoyi2010/09/28 08:22 AM
                    Sandy Bridge CPU article onlineFoo_2010/09/28 12:53 PM
                      Sandy Bridge CPU article onlinePaul2010/09/28 01:17 PM
                      Sandy Bridge CPU article onlinempx2010/09/28 01:22 PM
                        Sandy Bridge CPU article onlineanonymous2010/09/28 02:06 PM
                      Sandy Bridge CPU article onlineIntelUser20002010/09/29 01:49 AM
                    Sandy Bridge CPU article onlineJack2010/09/28 05:08 PM
                      Sandy Bridge CPU article onlinempx2010/09/29 01:50 AM
                        Sandy Bridge CPU article onlineLinus Torvalds2010/09/29 12:01 PM
                          Sandy Bridge CPU article onlineRoyi2010/09/29 12:48 PM
                          Sandy Bridge CPU article onlinempx2010/09/29 02:15 PM
                            Sandy Bridge CPU article onlineLinus Torvalds2010/09/29 02:27 PM
                              Sandy Bridge CPU article online?2010/09/29 11:18 PM
                                Sandy Bridge CPU article onlinesavantu2010/09/30 12:28 AM
                                  Sandy Bridge CPU article online?2010/09/30 03:43 AM
                                    Sandy Bridge CPU article onlinegallier22010/09/30 04:18 AM
                                      Sandy Bridge CPU article online?2010/09/30 08:38 AM
                                        Sandy Bridge CPU article onlineDavid Hess2010/09/30 10:28 AM
                                      moderation (again)hobold2010/10/01 05:08 AM
                                Sandy Bridge CPU article onlineMegol2010/09/30 02:13 AM
                                  Sandy Bridge CPU article online?2010/09/30 03:47 AM
                              Sandy Bridge CPU article onlineIan Ameline2010/09/30 08:54 AM
                                Sandy Bridge CPU article onlineLinus Torvalds2010/09/30 10:18 AM
                                  Sandy Bridge CPU article onlineIan Ameline2010/09/30 12:04 PM
                                    Sandy Bridge CPU article onlineLinus Torvalds2010/09/30 12:38 PM
                                      Sandy Bridge CPU article onlineMichael S2010/09/30 01:02 PM
                                        Sandy Bridge CPU article onlineNEON cortex2010/11/17 08:09 PM
                                  Sandy Bridge CPU article onlinempx2010/09/30 12:40 PM
                                    Sandy Bridge CPU article onlineLinus Torvalds2010/09/30 01:00 PM
                                    Sandy Bridge CPU article onlineNEON cortex2010/11/17 08:44 PM
                                Sandy Bridge CPU article onlineDavid Hess2010/09/30 10:36 AM
                                  Sandy Bridge CPU article onlinesomeone2010/09/30 11:23 AM
                                    Sandy Bridge CPU article onlinempx2010/09/30 01:50 PM
                                      wii lessonMichael S2010/09/30 02:12 PM
                                        wii lessonDan Downs2010/09/30 03:33 PM
                                        wii lessonKevin G2010/10/01 12:27 AM
                                          wii lessonRohit2010/10/01 07:53 AM
                                            wii lessonKevin G2010/10/02 03:30 AM
                                        wii lessonmpx2010/10/01 09:02 AM
                                        wii lessonIntelUser20002010/10/01 09:31 AM
                                      GPUs and gamesDavid Kanter2010/09/30 08:17 PM
                                        GPUs and gameshobold2010/10/01 05:27 AM
                                          GPUs and gamesanonymous2010/10/01 06:35 AM
                                        GPUs and gamesGabriele Svelto2010/10/01 09:07 AM
                                          GPUs and gamesLinus Torvalds2010/10/01 10:41 AM
                                            GPUs and gamesAnon2010/10/01 11:23 AM
                                            Can Intel do *this* ???Mark Roulo2010/10/03 03:17 PM
                                              Can Intel do *this* ???Anon2010/10/03 03:29 PM
                                                Can Intel do *this* ???Mark Roulo2010/10/03 03:55 PM
                                                  Can Intel do *this* ???Anon2010/10/03 05:45 PM
                                                    Can Intel do *this* ???Ian Ameline2010/10/03 10:35 PM
                                                Graphics, IGPs, and CacheJoe2010/10/10 09:51 AM
                                                  Graphics, IGPs, and CacheAnon2010/10/10 10:18 PM
                                                  Graphics, IGPs, and CacheRohit2010/10/11 06:14 AM
                                                  Graphics, IGPs, and Cachehobold2010/10/11 06:43 AM
                                                  Maybe the IGPU doesn't load into the L3Mark Roulo2010/10/11 08:05 AM
                                                  Graphics, IGPs, and CacheDavid Kanter2010/10/11 09:01 AM
                                              Can Intel do *this* ???Gabriele Svelto2010/10/04 12:31 AM
                                        Kanter's Law.Ian Ameline2010/10/01 02:05 PM
                                          Kanter's Law.David Kanter2010/10/01 02:18 PM
                                            Kanter's Law.Ian Ameline2010/10/01 02:33 PM
                                            Kanter's Law.Kevin G2010/10/01 04:19 PM
                                              Kanter's Law.IntelUser20002010/10/01 10:36 PM
                                                Kanter's Law.Kevin G2010/10/02 03:15 AM
                                                  Kanter's Law.IntelUser20002010/10/02 02:35 PM
                                            Wii vs pc'sRohit2010/10/01 07:34 PM
                                              Wii vs pc'sGabriele Svelto2010/10/01 11:54 PM
                                        GPUs and gamesmpx2010/10/02 11:30 AM
                                          GPUs and gamesFoo_2010/10/02 04:03 PM
                                            GPUs and gamesmpx2010/10/03 11:29 AM
                                              GPUs and gamesFoo_2010/10/03 01:52 PM
                                                GPUs and gamesmpx2010/10/03 03:29 PM
                                                  GPUs and gamesAnon2010/10/03 03:49 PM
                                                    GPUs and gamesmpx2010/10/04 11:42 AM
                                                      GPUs and gamesMS2010/10/04 02:51 PM
                                                      GPUs and gamesAnon2010/10/04 08:29 PM
                                                        persistence of visionhobold2010/10/04 11:47 PM
                                                        GPUs and gamesmpx2010/10/05 12:51 AM
                                                          GPUs and gamesMS2010/10/05 06:49 AM
                                                            GPUs and gamesJack2010/10/05 11:17 AM
                                                              GPUs and gamesMS2010/10/05 05:19 PM
                                                          GPUs and gamesJack2010/10/05 11:11 AM
                                                            GPUs and gamesmpx2010/10/05 12:51 PM
                                                              GPUs and gamesDavid Kanter2010/10/06 09:04 AM
        GPUs and gamesjack2010/10/06 09:34 PM
                                                        GPUs and gamesLinus Torvalds2010/10/05 07:29 AM
                                                  GPUs and gamesFoo_2010/10/04 04:49 AM
                                                    GPUs and gamesJeremiah2010/10/08 10:58 AM
                                                    GPUs and gamesMS2010/10/08 01:37 PM
                                                GPUs and gamesSalvatore De Dominicis2010/10/04 01:41 AM
                                                  GPUs and gamesKevin G2010/10/05 02:13 PM
                                        GPUs and gamesmpx2010/10/03 11:36 AM
                                          GPUs and gamesDavid Kanter2010/10/04 07:08 AM
                                            GPUs and gamesKevin G2010/10/04 10:38 AM
                                    Sandy Bridge CPU article onlineNEON cortex2010/11/17 09:19 PM
                                  Sandy Bridge CPU article onlineIan Ameline2010/09/30 12:06 PM
                                    Sandy Bridge CPU article onlinerwessel2010/09/30 02:29 PM
                                      Sandy Bridge CPU article onlineMichael S2010/09/30 03:06 PM
                                        Sandy Bridge CPU article onlinerwessel2010/09/30 06:55 PM
                                          Sandy Bridge CPU article onlineDavid Hess2010/10/01 03:53 AM
                                            Sandy Bridge CPU article onlinerwessel2010/10/01 08:30 AM
                                              Sandy Bridge CPU article onlineDavid Hess2010/10/01 09:31 AM
                                                Sandy Bridge CPU article onlinerwessel2010/10/01 10:56 AM
                                                  Sandy Bridge CPU article onlineDavid Hess2010/10/01 08:28 PM
                                                    Sandy Bridge CPU article onlineRicardo B2010/10/02 05:38 AM
                                                      Sandy Bridge CPU article onlineDavid Hess2010/10/02 06:59 PM
                                                  which bus more wastefulMichael S2010/10/02 10:38 AM
                                                    which bus more wastefulrwessel2010/10/02 07:15 PM
                                            Sandy Bridge CPU article onlineRicardo B2010/10/01 10:08 AM
                                              Sandy Bridge CPU article onlineDavid Hess2010/10/01 08:31 PM
                                            Sandy Bridge CPU article onlineAndi Kleen2010/10/01 11:55 AM
                                              Sandy Bridge CPU article onlineDavid Hess2010/10/01 08:32 PM
                                      Sandy Bridge CPU article onlinekdg2010/10/01 11:26 AM
                                        Sandy Bridge CPU article onlineAnon2010/10/01 11:33 AM
                                          Analog display out?David Kanter2010/10/01 01:05 PM
                                            Analog display out?mpx2010/10/02 11:46 AM
                                            Analog display out?Anon2010/10/03 03:26 PM
                                              Digital is expensive!David Kanter2010/10/03 06:36 PM
                                                Digital is expensive!Anon2010/10/03 08:07 PM
                                                  Digital is expensive!David Kanter2010/10/03 10:02 PM
                                                    Digital is expensive!Steve Underwood2010/10/04 03:52 AM
                                                      Digital is expensive!David Kanter2010/10/04 07:03 AM
                                                        Digital is expensive!anonymous2010/10/04 07:11 AM
                                                          Digital is not very expensive!Steve Underwood2010/10/04 06:08 PM
                                                            Digital is not very expensive!Anon2010/10/04 08:33 PM
                                                              Digital is not very expensive!Steve Underwood2010/10/04 11:03 PM
        Digital is not very expensive!mpx2010/10/05 01:10 PM
                                                            Digital is not very expensive!Gabriele Svelto2010/10/05 12:24 AM
                                                    Digital is expensive!jal1422010/10/04 11:46 AM
                                                Digital is expensive!mpx2010/10/04 01:04 AM
                                                  Digital is expensive!Gabriele Svelto2010/10/04 03:28 AM
                                                  Digital is expensive!Mark Christiansen2010/10/04 03:12 PM
                                              Analog display out?slacker2010/10/03 06:44 PM
                                                Analog display out?Anon2010/10/03 08:05 PM
                                            Analog display out?Steve Underwood2010/10/04 03:48 AM
                                        Sandy Bridge CPU article onlineDavid Hess2010/10/01 08:37 PM
                                          Sandy Bridge CPU article onlineslacker2010/10/02 02:53 PM
                                            Sandy Bridge CPU article onlineDavid Hess2010/10/02 06:49 PM
                                memory bandwithMax2010/09/30 12:19 PM
                                  memory bandwithAnon2010/10/01 11:28 AM
                                    memory bandwithJack2010/10/01 07:45 PM
                                      memory bandwithAnon2010/10/03 03:19 PM
                                Sandy Bridge CPU article onlinePiedPiper2010/09/30 07:05 PM
                            Sandy Bridge CPU article onlineMatt Sayler2010/09/29 04:38 PM
                            Sandy Bridge CPU article onlineJack2010/09/29 09:39 PM
                              Sandy Bridge CPU article onlinempx2010/09/30 12:24 AM
                                Sandy Bridge CPU article onlinepasser2010/09/30 03:15 AM
                                  Sandy Bridge CPU article onlinempx2010/09/30 03:47 AM
                                    Sandy Bridge CPU article onlinepasser2010/09/30 04:25 AM
                                  SB and web browsingRohit2010/09/30 06:47 AM
                                    SB and web browsingDavid Hess2010/09/30 07:10 AM
                                      SB and web browsingMS2010/09/30 10:21 AM
                                        SB and web browsingpasser2010/09/30 10:26 AM
                                          SB and web browsingMS2010/10/02 06:41 PM
                                      SB and web browsingRohit2010/10/01 08:02 AM
                                Sandy Bridge CPU article onlineDavid Kanter2010/09/30 08:35 AM
                                Sandy Bridge CPU article onlineJack2010/09/30 10:40 PM
                          processor evolutionhobold2010/09/29 02:16 PM
                            processor evolutionFoo_2010/09/30 06:10 AM
                              processor evolutionJack2010/09/30 07:07 PM
                                3D gaming as GPGPU apphobold2010/10/01 04:59 AM
                                  3D gaming as GPGPU appJack2010/10/01 07:39 PM
                              processor evolutionhobold2010/10/01 04:35 AM
                                processor evolutionDavid Kanter2010/10/01 10:02 AM
                                  processor evolutionAnon2010/10/01 11:46 AM
                                    DisplayDavid Kanter2010/10/01 01:26 PM
                                      DisplayRohit2010/10/02 02:56 AM
                                        DisplayLinus Torvalds2010/10/02 07:40 AM
                                          Displayrwessel2010/10/02 08:58 AM
                                            DisplaysJ2010/10/02 10:28 PM
                                              Displayrwessel2010/10/03 08:38 AM
                                            DisplayAnon2010/10/03 03:06 PM
                                              Display tech and compute are differentDavid Kanter2010/10/03 06:33 PM
                                                Display tech and compute are differentAnon2010/10/03 08:16 PM
                                                  Display tech and compute are differentDavid Kanter2010/10/03 10:00 PM
                                                Display tech and compute are differenthobold2010/10/04 01:40 AM
                                          Display?2010/10/03 03:02 AM
                                            DisplayLinus Torvalds2010/10/03 10:18 AM
                                              DisplayRichard Cownie2010/10/03 11:12 AM
                                                DisplayLinus Torvalds2010/10/03 12:16 PM
                                                  Displayslacker2010/10/03 07:35 PM
                                                    current V12 engines with >6.0 displacementanonymous2010/10/04 07:06 AM
                                                      current V12 engines with >6.0 displacementRicardo B2010/10/04 11:44 AM
                                                        current V12 engines with >6.0 displacementanonymous2010/10/04 02:59 PM
                                                          current V12 engines with >6.0 displacementRicardo B2010/10/04 03:13 PM
                                                          current V12 engines with >6.0 displacementAaron Spink2010/10/04 08:58 PM
                                                            current V12 engines with >6.0 displacementslacker2010/10/05 01:39 AM
                                                              current V12 engines with >6.0 displacementMS2010/10/05 06:57 AM
                                                              current V12 engines with >6.0 displacementRicardo B2010/10/05 01:20 PM
                                                              current V12 engines with >6.0 displacementAaron Spink2010/10/05 09:26 PM
        current V12 engines with >6.0 displacementslacker2010/10/06 05:39 AM
        current V12 engines with >6.0 displacementAaron Spink2010/10/06 01:22 PM
        current V12 engines with >6.0 displacementRicardo B2010/10/06 03:07 PM
        current V12 engines with >6.0 displacementAaron Spink2010/10/06 03:56 PM
        current V12 engines with >6.0 displacementrwessel2010/10/06 03:30 PM
        current V12 engines with >6.0 displacementAaron Spink2010/10/06 03:53 PM
        current V12 engines with >6.0 displacementAnonymous2010/10/07 01:32 PM
        current V12 engines with >6.0 displacementrwessel2010/10/07 07:54 PM
        current V12 engines with >6.0 displacementAaron Spink2010/10/07 09:02 PM
        Top Gear is awful, and Jeremy Clarkson cannot drive.slacker2010/10/06 07:20 PM
        Top Gear is awful, and Jeremy Clarkson cannot drive.Ricardo B2010/10/07 01:32 AM
        Top Gear is awful, and Jeremy Clarkson cannot drive.slacker2010/10/07 08:15 AM
        Top Gear is awful, and Jeremy Clarkson cannot drive.Ricardo B2010/10/07 10:51 AM
        current V12 engines with >6.0 displacementanon2010/10/06 05:03 PM
        current V12 engines with >6.0 displacementAaron Spink2010/10/06 06:26 PM
        current V12 engines with >6.0 displacementanon2010/10/06 11:15 PM
        current V12 engines with >6.0 displacementHoward Chu2010/10/07 02:16 PM
                                                              current V12 engines with >6.0 displacementAnon2010/10/05 10:31 PM
        current V12 engines with >6.0 displacementslacker2010/10/06 05:55 AM
        current V12 engines with >6.0 displacementRicardo B2010/10/06 06:15 AM
        current V12 engines with >6.0 displacementslacker2010/10/06 06:34 AM
        I wonder is there any tech area that this forum doesn't have an opinion on (NT)Rob Thorpe2010/10/06 10:11 AM
        Cunieform tabletsDavid Kanter2010/10/06 12:57 PM
        Cunieform tabletsLinus Torvalds2010/10/06 01:06 PM
        Ouch...maybe I should hire a new editor (NT)David Kanter2010/10/06 04:38 PM
        Cunieform tabletsrwessel2010/10/06 03:41 PM
        Cunieform tabletsseni2010/10/07 10:56 AM
        Cunieform tabletsHoward Chu2010/10/07 01:44 PM
        current V12 engines with >6.0 displacementAnonymous2010/10/06 06:10 PM
        current V12 engines with >6.0 displacementanonymous2010/10/06 10:44 PM
        current V12 engines with >6.0 displacementslacker2010/10/07 07:55 AM
        current V12 engines with >6.0 displacementanonymous2010/10/07 08:51 AM
        current V12 engines with >6.0 displacementslacker2010/10/07 07:38 PM
        current V12 engines with >6.0 displacementanonymous2010/10/07 08:33 PM
        current V12 engines with >6.0 displacementAaron Spink2010/10/07 09:04 PM
        Practical vehicles for commutingRob Thorpe2010/10/08 05:50 AM
        Practical vehicles for commutingGabriele Svelto2010/10/08 06:05 AM
        Practical vehicles for commutingRob Thorpe2010/10/08 06:21 AM
        Practical vehicles for commutingj2010/10/08 02:20 PM
        Practical vehicles for commutingRob Thorpe2010/12/09 07:00 AM
        current V12 engines with >6.0 displacementanonymous2010/10/08 10:14 AM
        current V12 engines with >6.0 displacementAnonymous2010/10/07 01:23 PM
        current V12 engines with >6.0 displacementanon2010/10/07 04:08 PM
        current V12 engines with >6.0 displacementanonymous2010/10/07 05:41 PM
        current V12 engines with >6.0 displacementslacker2010/10/07 08:05 PM
        current V12 engines with >6.0 displacementanonymous2010/10/07 08:52 PM
        current V12 engines with >6.0 displacementAnonymous2010/10/08 07:52 PM
        current V12 engines with >6.0 displacementanon2010/10/06 11:28 PM
        current V12 engines with >6.0 displacementAaron Spink2010/10/07 12:37 AM
        current V12 engines with >6.0 displacementRicardo B2010/10/07 01:37 AM
                                                      current V12 engines with >6.0 displacementslacker2010/10/05 02:02 AM
                                                    DisplayLinus Torvalds2010/10/04 10:39 AM
                                                      DisplayGabriele Svelto2010/10/05 12:34 AM
                                                  DisplayRichard Cownie2010/10/04 06:22 AM
                                                    Displayanon2010/10/04 09:22 PM
                                                      DisplayRichard Cownie2010/10/05 06:42 AM
                                              Displaympx2010/10/03 11:55 AM
                                                Displayrcf2010/10/03 01:12 PM
                                                  Displaympx2010/10/03 02:36 PM
                                                    Displayrcf2010/10/03 05:36 PM
                                                      DisplayRicardo B2010/10/04 02:50 PM
                                                        Displaygallier22010/10/05 03:44 AM
                                                          DisplayDavid Hess2010/10/05 05:21 AM
                                                            Displaygallier22010/10/05 08:21 AM
                                                  DisplayDavid Hess2010/10/03 11:21 PM
                                                    Displayrcf2010/10/04 08:06 AM
                                                DisplayDavid Kanter2010/10/03 01:54 PM
                                                  Alternative integrationPaul A. Clayton2010/10/06 08:51 AM
                                              Displayslacker2010/10/03 07:26 PM
                                              Display & marketing & analogies?2010/10/04 02:33 AM
                                                Display & marketing & analogieskdg2010/10/04 06:00 AM
                                      DisplayKevin G2010/10/02 09:49 AM
                                        DisplayAnon2010/10/03 03:43 PM
                        Sandy Bridge CPU article onlineDavid Kanter2010/09/29 03:17 PM
        Sandy Bridge CPU article onlineJack2010/09/28 06:27 AM
    Sandy Bridge CPU article onlineIntelUser20002010/09/28 03:07 AM
      Sandy Bridge CPU article onlinempx2010/09/28 12:34 PM
        Sandy Bridge CPU article onlineAaron Spink2010/09/28 01:28 PM
          Sandy Bridge CPU article onlineJoshW2010/09/28 02:13 PM
          Sandy Bridge CPU article onlinempx2010/09/28 02:54 PM
        Sandy Bridge CPU article onlineFoo_2010/09/29 01:19 AM
          Sandy Bridge CPU article onlinempx2010/09/29 03:06 AM
            Sandy Bridge CPU article onlineJS2010/09/29 03:42 AM
              Sandy Bridge CPU article onlinempx2010/09/29 04:03 AM
            Sandy Bridge CPU article onlineFoo_2010/09/29 05:55 AM
  Sandy Bridge CPU article onlineajensen2010/09/28 12:19 AM
    Sandy Bridge CPU article onlineIan Ollmann2010/09/28 04:52 PM
      Sandy Bridge CPU article onlinea reader2010/09/28 05:05 PM
      Sandy Bridge CPU article onlineajensen2010/09/28 11:35 PM
  Updated: Sandy Bridge CPU articleDavid Kanter2010/10/01 05:11 AM
    Updated: Sandy Bridge CPU articleanon2011/01/07 09:55 PM
      Updated: Sandy Bridge CPU articleEric Bron2011/01/08 03:29 AM
        Updated: Sandy Bridge CPU articleanon2011/01/11 11:24 PM
          Updated: Sandy Bridge CPU articleanon2011/01/15 11:21 AM
            David Kanter can you shed some light? Re Updated: Sandy Bridge CPU articleanon2011/01/16 11:22 PM
              David Kanter can you shed some light? Re Updated: Sandy Bridge CPU articleanonymous2011/01/17 02:04 AM
                David Kanter can you shed some light? Re Updated: Sandy Bridge CPU articleanon2011/01/17 07:12 AM
                  I can try....David Kanter2011/01/18 03:54 PM
                    I can try....anon2011/01/18 08:07 PM
                      I can try....David Kanter2011/01/18 11:24 PM
                        I can try....anon2011/01/19 07:51 AM
                          Wider fetch than execute makes sensePaul A. Clayton2011/01/19 08:53 AM
  Sandy Bridge CPU article onlineNicolas Capens2011/01/04 07:29 AM
    Sandy Bridge CPU article onlineSeni2011/01/04 09:07 PM
      Sandy Bridge CPU article onlinehobold2011/01/04 11:26 PM
        Sandy Bridge CPU article onlineMichael S2011/01/05 02:01 AM
          software assist exceptionshobold2011/01/05 04:36 PM
      Sandy Bridge CPU article onlineMichael S2011/01/05 01:58 AM
        Sandy Bridge CPU article onlineanon2011/01/05 04:51 AM
          Sandy Bridge CPU article onlineSeni2011/01/05 08:53 AM
            Sandy Bridge CPU article onlineMichael S2011/01/05 09:03 AM
              Sandy Bridge CPU article onlineanon2011/01/05 04:14 PM
      Sandy Bridge CPU article onlineNicolas Capens2011/01/05 04:50 AM
        Sandy Bridge CPU article onlineGabriele Svelto2011/01/05 05:00 AM
          Sandy Bridge CPU article onlineNicolas Capens2011/01/05 07:26 AM
            Sandy Bridge CPU article onlineGabriele Svelto2011/01/05 07:50 AM
              Sandy Bridge CPU article onlineMichael S2011/01/05 08:39 AM
              Sandy Bridge CPU article onlineNicolas Capens2011/01/05 03:50 PM
                permuting vector elementshobold2011/01/05 05:03 PM
                  permuting vector elementsNicolas Capens2011/01/05 06:01 PM
                  permuting vector elementsNicolas Capens2011/01/06 08:27 AM
                Sandy Bridge CPU article onlineGabriele Svelto2011/01/11 11:33 AM
                  Sandy Bridge CPU article onlineEduardoS2011/01/11 01:51 PM
                  Sandy Bridge CPU article onlinehobold2011/01/11 02:11 PM
                    Sandy Bridge CPU article onlineDavid Kanter2011/01/11 06:07 PM
                      Sandy Bridge CPU article onlineMichael S2011/01/12 03:25 AM
                        Sandy Bridge CPU article onlinehobold2011/01/12 05:03 PM
                          Sandy Bridge CPU article onlineDavid Kanter2011/01/12 11:27 PM
                            Sandy Bridge CPU article onlineEric Bron2011/01/13 02:38 AM
                            Sandy Bridge CPU article onlineMichael S2011/01/13 03:32 AM
                              Sandy Bridge CPU article onlinehobold2011/01/13 01:53 PM
                            What happened to VPERMIL2PS?Michael S2011/01/13 03:46 AM
                              What happened to VPERMIL2PS?Eric Bron2011/01/13 06:46 AM
                          Lower cost permutePaul A. Clayton2011/01/13 12:11 PM
                          Sandy Bridge CPU article onlineanon2011/01/25 06:31 PM
                  Sandy Bridge CPU article onlineNicolas Capens2011/01/12 06:34 PM
                    Sandy Bridge CPU article onlineGabriele Svelto2011/01/13 07:38 AM
                      Sandy Bridge CPU article onlineNicolas Capens2011/01/15 09:47 PM
                        Sandy Bridge CPU article onlineGabriele Svelto2011/01/16 03:13 AM
                        And just to make a further exampleGabriele Svelto2011/01/16 04:24 AM
                        Sandy Bridge CPU article onlinempx2011/01/16 01:27 PM
                      Sandy Bridge CPU article onlineNicolas Capens2011/01/25 02:56 PM
                        Sandy Bridge CPU article onlineDavid Kanter2011/01/25 04:11 PM
                          Sandy Bridge CPU article onlineNicolas Capens2011/01/26 08:49 AM
                            Sandy Bridge CPU article onlineEduardoS2011/01/26 04:35 PM
                              Sandy Bridge CPU article onlineNicolas Capens2011/01/27 02:51 AM
                                Sandy Bridge CPU article onlineEduardoS2011/01/27 02:40 PM
                                  Sandy Bridge CPU article onlineNicolas Capens2011/01/28 03:24 AM
                                    Sandy Bridge CPU article onlineEric Bron2011/01/28 03:49 AM
                                      Sandy Bridge CPU article onlineNicolas Capens2011/01/30 02:11 PM
                                        Sandy Bridge CPU article onlineEric Bron2011/01/31 03:43 AM
                                          Sandy Bridge CPU article onlineNicolas Capens2011/02/01 04:02 AM
                                            Sandy Bridge CPU article onlineEric Bron2011/02/01 04:28 AM
                                            Sandy Bridge CPU article onlineEric Bron2011/02/01 04:43 AM
                                    Sandy Bridge CPU article onlineEduardoS2011/01/28 07:14 PM
                                      Sandy Bridge CPU article onlineNicolas Capens2011/02/01 02:58 AM
                                        Sandy Bridge CPU article onlineEduardoS2011/02/01 02:36 PM
                                          Sandy Bridge CPU article onlineanon2011/02/01 04:56 PM
                                            Sandy Bridge CPU article onlineEduardoS2011/02/01 09:17 PM
                                              Sandy Bridge CPU article onlineanon2011/02/01 10:13 PM
                                              Sandy Bridge CPU article onlineEric Bron2011/02/02 04:08 AM
                                              Sandy Bridge CPU article onlineEric Bron2011/02/02 04:26 AM
                                Sandy Bridge CPU article onlinekalmaegi2011/02/01 09:29 AM
                            SW RasterizationDavid Kanter2011/01/27 05:18 PM
                              Lower pin count memoryiz2011/01/27 09:19 PM
                                Lower pin count memoryDavid Kanter2011/01/27 09:25 PM
                                  Lower pin count memoryiz2011/01/27 11:31 PM
                                    Lower pin count memoryDavid Kanter2011/01/27 11:52 PM
                                      Lower pin count memoryiz2011/01/28 12:28 AM
                                        Lower pin count memoryDavid Kanter2011/01/28 01:05 AM
                                          Lower pin count memoryiz2011/01/28 03:55 AM
                                            Lower pin count memoryDavid Hess2011/01/28 01:15 PM
                                            Lower pin count memoryDavid Kanter2011/01/28 01:57 PM
                                              Lower pin count memoryiz2011/01/28 05:20 PM
                                      Two years laterForgotPants2013/10/26 11:33 AM
                                        Two years lateranon2013/10/26 11:36 AM
                                        Two years laterExophase2013/10/26 12:56 PM
                                        Two years laterDavid Hess2013/10/26 05:05 PM
                                        Herz is totally the thing you DON*T care.Jouni Osmala2013/10/27 01:48 AM
                                          Herz is totally the thing you DON*T care.EduardoS2013/10/27 07:00 AM
                                            Herz is totally the thing you DON*T care.Michael S2013/10/27 07:45 AM
                                        Two years latersomeone2013/10/28 07:21 AM
                                  Lower pin count memoryMartin Høyer Kristiansen2011/01/28 01:41 AM
                                    Lower pin count memoryiz2011/01/28 03:07 AM
                                Lower pin count memoryDarrell Coker2011/01/27 10:39 PM
                                  Lower pin count memoryiz2011/01/28 12:20 AM
                                    Lower pin count memoryDarrell Coker2011/01/28 06:07 PM
                                      Lower pin count memoryiz2011/01/28 11:57 PM
                                        Lower pin count memoryDarrell Coker2011/01/29 02:21 AM
                                          Lower pin count memoryiz2011/01/31 10:28 PM
                              SW RasterizationNicolas Capens2011/02/02 08:48 AM
                                SW RasterizationEric Bron2011/02/02 09:37 AM
                                  SW RasterizationNicolas Capens2011/02/02 04:35 PM
                                    SW RasterizationEric Bron2011/02/02 05:11 PM
                                    SW RasterizationEric Bron2011/02/03 02:13 AM
                                      SW RasterizationNicolas Capens2011/02/04 07:57 AM
                                        SW RasterizationEric Bron2011/02/04 08:50 AM
                                          erratumEric Bron2011/02/04 08:58 AM
                                          SW RasterizationNicolas Capens2011/02/04 05:25 PM
                                            SW RasterizationDavid Kanter2011/02/04 05:33 PM
                                              SW Rasterizationanon2011/02/04 06:04 PM
                                              SW RasterizationNicolas Capens2011/02/05 03:39 PM
                                                SW RasterizationDavid Kanter2011/02/05 05:07 PM
                                                  SW RasterizationNicolas Capens2011/02/05 11:39 PM
                                        SW RasterizationEric Bron2011/02/04 10:55 AM
                                Comments pt 1David Kanter2011/02/02 01:08 PM
                                  Comments pt 1Eric Bron2011/02/02 03:16 PM
                                  Comments pt 1Gabriele Svelto2011/02/03 01:37 AM
                                    Comments pt 1Eric Bron2011/02/03 02:36 AM
                                    Comments pt 1Nicolas Capens2011/02/03 11:08 PM
                                  Comments pt 1Nicolas Capens2011/02/03 10:26 PM
                                    Comments pt 1Eric Bron2011/02/04 03:33 AM
                                      Comments pt 1Nicolas Capens2011/02/04 05:24 AM
                                    example codeEric Bron2011/02/04 04:51 AM
                                      example codeNicolas Capens2011/02/04 08:24 AM
                                        example codeEric Bron2011/02/04 08:36 AM
                                          example codeNicolas Capens2011/02/05 11:43 PM
                                    Comments pt 1Rohit2011/02/04 12:43 PM
                                      Comments pt 1Nicolas Capens2011/02/04 05:05 PM
                                        Comments pt 1David Kanter2011/02/04 05:36 PM
                                          Comments pt 1Nicolas Capens2011/02/05 02:45 PM
                                            Comments pt 1Eric Bron2011/02/05 04:13 PM
                                              Comments pt 1Nicolas Capens2011/02/05 11:52 PM
                                                Comments pt 1Eric Bron2011/02/06 01:31 AM
                                                  Comments pt 1Nicolas Capens2011/02/06 04:06 PM
                                                    Comments pt 1Eric Bron2011/02/07 03:12 AM
                                                      The need for gather/scatter supportNicolas Capens2011/02/10 10:07 AM
                                                        The need for gather/scatter supportEric Bron2011/02/11 03:11 AM
                                                          Gather/scatter performance dataNicolas Capens2011/02/13 03:39 AM
                                                            Gather/scatter performance dataEric Bron2011/02/13 07:46 AM
                                                              Gather/scatter performance dataNicolas Capens2011/02/14 07:48 AM
        Gather/scatter performance dataEric Bron2011/02/14 09:32 AM
        Gather/scatter performance dataEric Bron2011/02/14 10:07 AM
                                                            Gather/scatter performance dataEric Bron2011/02/13 09:00 AM
                                                              Gather/scatter performance dataNicolas Capens2011/02/14 07:49 AM
        Gather/scatter performance dataEric Bron2011/02/15 02:23 AM
                                                            Gather/scatter performance dataEric Bron2011/02/13 05:06 PM
                                                              Gather/scatter performance dataNicolas Capens2011/02/14 07:52 AM
        Gather/scatter performance dataEric Bron2011/02/14 09:43 AM
                                SW Rasterization - a long way offRohit2011/02/02 01:17 PM
                                  SW Rasterization - a long way offNicolas Capens2011/02/04 03:59 AM
                                    CPU only rendering - a long way offRohit2011/02/04 11:52 AM
                                      CPU only rendering - a long way offNicolas Capens2011/02/04 07:15 PM
                                        CPU only rendering - a long way offRohit2011/02/05 02:00 AM
                                          CPU only rendering - a long way offNicolas Capens2011/02/05 09:45 PM
                                            CPU only rendering - a long way offDavid Kanter2011/02/06 09:51 PM
                                              CPU only rendering - a long way offGian-Carlo Pascutto2011/02/07 12:22 AM
                                                EncryptionDavid Kanter2011/02/07 01:18 AM
                                                  EncryptionNicolas Capens2011/02/07 07:51 AM
                                                    EncryptionDavid Kanter2011/02/07 11:50 AM
                                                      EncryptionNicolas Capens2011/02/08 10:26 AM
                                                        CPUs are latency optimizedDavid Kanter2011/02/08 11:38 AM
                                                          efficient compiler on an efficient GPU real today.sJ2011/02/08 11:29 PM
                                                          CPUs are latency optimizedNicolas Capens2011/02/09 09:49 PM
                                                            CPUs are latency optimizedEric Bron2011/02/10 12:49 AM
                                                              CPUs are latency optimizedAntti-Ville Tuunainen2011/02/10 06:16 AM
                                                              CPUs are latency optimizedNicolas Capens2011/02/10 07:04 AM
        CPUs are latency optimizedEric Bron2011/02/10 07:48 AM
        CPUs are latency optimizedNicolas Capens2011/02/10 01:31 PM
        CPUs are latency optimizedEric Bron2011/02/11 02:43 AM
        CPUs are latency optimizedNicolas Capens2011/02/11 07:31 AM
                                                            CPUs are latency optimizedEduardoS2011/02/10 05:29 PM
                                                              CPUs are latency optimizedAnon2011/02/10 06:40 PM
        CPUs are latency optimizedDavid Kanter2011/02/10 08:33 PM
        CPUs are latency optimizedEduardoS2011/02/11 02:18 PM
                                                              CPUs are latency optimizedNicolas Capens2011/02/11 05:56 AM
        CPUs are latency optimizedRohit2011/02/11 07:33 AM
        CPUs are latency optimizedNicolas Capens2011/02/14 02:19 AM
        CPUs are latency optimizedEric Bron2011/02/14 03:23 AM
        CPUs are latency optimizedEduardoS2011/02/14 01:11 PM
        CPUs are latency optimizedDavid Kanter2011/02/11 02:45 PM
        CPUs are latency optimizedNicolas Capens2011/02/15 05:22 AM
        CPUs are latency optimizedDavid Kanter2011/02/15 12:47 PM
        CPUs are latency optimizedNicolas Capens2011/02/15 07:10 PM
        Have funDavid Kanter2011/02/15 10:04 PM
        Have funNicolas Capens2011/02/17 03:59 AM
        Have funBrett2011/02/17 12:56 PM
        Have funNicolas Capens2011/02/19 04:53 PM
        Have funBrett2011/02/20 06:08 PM
        Have funBrett2011/02/20 07:13 PM
        On-die storage to fight AmdahlNicolas Capens2011/02/23 05:37 PM
        On-die storage to fight AmdahlBrett2011/02/23 09:59 PM
        On-die storage to fight AmdahlBrett2011/02/23 10:08 PM
        On-die storage to fight AmdahlNicolas Capens2011/02/24 07:42 PM
        On-die storage to fight AmdahlRohit2011/02/25 11:02 PM
        On-die storage to fight AmdahlNicolas Capens2011/03/09 06:53 PM
        On-die storage to fight AmdahlRohit2011/03/10 08:02 AM
        NVIDIA using tile based rendering?Nathan Monson2011/03/11 07:58 PM
        NVIDIA using tile based rendering?Rohit2011/03/12 04:29 AM
        NVIDIA using tile based rendering?Nathan Monson2011/03/12 11:05 AM
        NVIDIA using tile based rendering?Rohit2011/03/12 11:16 AM
        On-die storage to fight AmdahlBrett2011/02/26 02:10 AM
        On-die storage to fight AmdahlNathan Monson2011/02/26 01:51 PM
        On-die storage to fight AmdahlBrett2011/02/26 04:40 PM
        Convergence is inevitableNicolas Capens2011/03/09 08:22 PM
        Convergence is inevitableBrett2011/03/09 10:59 PM
        Convergence is inevitableAntti-Ville Tuunainen2011/03/10 03:34 PM
        Convergence is inevitableBrett2011/03/10 09:39 PM
        Procedural texturing?David Kanter2011/03/11 01:32 AM
        Procedural texturing?hobold2011/03/11 03:59 AM
        Procedural texturing?Dan Downs2011/03/11 09:28 AM
        Procedural texturing?Mark Roulo2011/03/11 02:58 PM
        Procedural texturing?Anon2011/03/11 06:11 PM
        Procedural texturing?Nathan Monson2011/03/11 07:30 PM
        Procedural texturing?Brett2011/03/15 07:45 AM
        Procedural texturing?Seni2011/03/15 10:13 AM
        Procedural texturing?Brett2011/03/15 11:45 AM
        Procedural texturing?Seni2011/03/15 02:09 PM
        Procedural texturing?Brett2011/03/11 10:02 PM
        Procedural texturing?Brett2011/03/11 09:34 PM
        Procedural texturing?Eric Bron2011/03/12 03:37 AM
        Convergence is inevitableJouni Osmala2011/03/09 11:28 PM
        Convergence is inevitableBrett2011/04/05 05:08 PM
        Convergence is inevitableNicolas Capens2011/04/07 05:23 AM
        Convergence is inevitablenone2011/04/07 07:03 AM
        Convergence is inevitableNicolas Capens2011/04/07 10:34 AM
        Convergence is inevitableanon2011/04/07 02:15 PM
        Convergence is inevitablenone2011/04/08 01:57 AM
        Convergence is inevitableBrett2011/04/07 08:04 PM
        Convergence is inevitablenone2011/04/08 02:14 AM
        Gather implementationDavid Kanter2011/04/08 12:01 PM
        RAM LatencyDavid Hess2011/04/07 08:22 AM
        RAM LatencyBrett2011/04/07 07:20 PM
        RAM LatencyNicolas Capens2011/04/07 10:18 PM
        RAM LatencyBrett2011/04/08 05:33 AM
        RAM LatencyNicolas Capens2011/04/10 02:23 PM
        RAM LatencyRohit2011/04/08 06:57 AM
        RAM LatencyNicolas Capens2011/04/10 01:23 PM
        RAM LatencyDavid Kanter2011/04/10 02:27 PM
        RAM LatencyRohit2011/04/11 06:17 AM
        Convergence is inevitableEric Bron2011/04/07 09:46 AM
        Convergence is inevitableNicolas Capens2011/04/07 09:50 PM
        Convergence is inevitableEric Bron2011/04/08 12:39 AM
        Flaws in PowerVRRohit2011/02/25 11:21 PM
        Flaws in PowerVRBrett2011/02/26 12:37 AM
        Flaws in PowerVRPaul2011/02/26 05:17 AM
        Have funDavid Kanter2011/02/18 12:52 PM
        Have funMichael S2011/02/19 12:12 PM
        Have funDavid Kanter2011/02/19 03:26 PM
        Have funMichael S2011/02/19 04:43 PM
        Have funanon2011/02/19 05:02 PM
        Have funMichael S2011/02/19 05:56 PM
        Have funanon2011/02/20 03:50 PM
        Have funEduardoS2011/02/20 02:44 PM
        Linear vs non-linearEduardoS2011/02/20 02:55 PM
        Have funMichael S2011/02/20 04:19 PM
        Have funEduardoS2011/02/20 05:51 PM
        Have funNicolas Capens2011/02/21 11:12 AM
        Have funMichael S2011/02/21 12:38 PM
        Have funEric Bron2011/02/21 02:10 PM
        Have funEric Bron2011/02/21 02:39 PM
        Have funMichael S2011/02/21 06:13 PM
        Have funEric Bron2011/02/22 12:43 AM
        Have funMichael S2011/02/22 01:47 AM
        Have funEric Bron2011/02/22 02:10 AM
        Have funMichael S2011/02/22 11:37 AM
        Have funanon2011/02/22 01:38 PM
        Have funEduardoS2011/02/22 03:49 PM
        Gather/scatter efficiencyNicolas Capens2011/02/23 06:37 PM
        Gather/scatter efficiencyanonymous2011/02/23 06:51 PM
        Gather/scatter efficiencyNicolas Capens2011/02/24 06:57 PM
        Gather/scatter efficiencyanonymous2011/02/24 07:16 PM
        Gather/scatter efficiencyMichael S2011/02/25 07:45 AM
        Gather implementationDavid Kanter2011/02/25 05:34 PM
        Gather implementationMichael S2011/02/26 10:40 AM
        Gather implementationanon2011/02/26 11:52 AM
        Gather implementationMichael S2011/02/26 12:16 PM
        Gather implementationanon2011/02/26 11:22 PM
        Gather implementationMichael S2011/02/27 07:23 AM
        Gather/scatter efficiencyNicolas Capens2011/02/28 03:14 PM
        Consider yourself ignoredDavid Kanter2011/02/22 01:05 AM
        one more anti-FMA flame. By me.Michael S2011/02/16 07:40 AM
        one more anti-FMA flame. By me.Eric Bron2011/02/16 08:30 AM
        one more anti-FMA flame. By me.Eric Bron2011/02/16 09:15 AM
        one more anti-FMA flame. By me.Nicolas Capens2011/02/17 06:27 AM
        anti-FMA != anti-throughput or anti-SGMichael S2011/02/17 07:42 AM
        anti-FMA != anti-throughput or anti-SGNicolas Capens2011/02/17 05:46 PM
        Tarantula paperPaul A. Clayton2011/02/18 12:38 AM
        Tarantula paperNicolas Capens2011/02/19 05:19 PM
        anti-FMA != anti-throughput or anti-SGEric Bron2011/02/18 01:48 AM
        anti-FMA != anti-throughput or anti-SGNicolas Capens2011/02/20 03:46 PM
        anti-FMA != anti-throughput or anti-SGMichael S2011/02/20 05:00 PM
        anti-FMA != anti-throughput or anti-SGNicolas Capens2011/02/23 04:05 AM
        Software pipelining on x86David Kanter2011/02/23 05:04 AM
        Software pipelining on x86JS2011/02/23 05:25 AM
        Software pipelining on x86Salvatore De Dominicis2011/02/23 08:37 AM
        Software pipelining on x86Jouni Osmala2011/02/23 09:10 AM
        Software pipelining on x86LeeMiller2011/02/23 10:07 PM
        Software pipelining on x86Nicolas Capens2011/02/24 03:17 PM
        Software pipelining on x86anonymous2011/02/24 07:04 PM
        Software pipelining on x86Nicolas Capens2011/02/28 09:27 AM
        Software pipelining on x86Antti-Ville Tuunainen2011/03/02 04:31 AM
        Software pipelining on x86Megol2011/03/02 12:55 PM
        Software pipelining on x86Geert Bosch2011/03/03 07:58 AM
        FMA benefits and latency predictionsDavid Kanter2011/02/25 05:14 PM
        FMA benefits and latency predictionsAntti-Ville Tuunainen2011/02/26 10:43 AM
        FMA benefits and latency predictionsMatt Waldhauer2011/02/27 06:42 AM
        FMA benefits and latency predictionsNicolas Capens2011/03/09 06:11 PM
        FMA benefits and latency predictionsRohit2011/03/10 08:11 AM
        FMA benefits and latency predictionsEric Bron2011/03/10 09:30 AM
        anti-FMA != anti-throughput or anti-SGMichael S2011/02/23 05:19 AM
        anti-FMA != anti-throughput or anti-SGNicolas Capens2011/02/23 07:50 AM
        anti-FMA != anti-throughput or anti-SGMichael S2011/02/23 10:37 AM
        FMA and beyondNicolas Capens2011/02/24 04:47 PM
        detour on terminologyhobold2011/02/24 07:08 PM
        detour on terminologyNicolas Capens2011/02/28 02:24 PM
        detour on terminologyEric Bron2011/03/01 02:38 AM
        detour on terminologyMichael S2011/03/01 05:03 AM
        detour on terminologyEric Bron2011/03/01 05:39 AM
        detour on terminologyMichael S2011/03/01 08:33 AM
        detour on terminologyEric Bron2011/03/01 09:34 AM
        erratum Eric Bron2011/03/01 09:54 AM
        detour on terminologyNicolas Capens2011/03/10 08:39 AM
        detour on terminologyEric Bron2011/03/10 09:50 AM
        anti-FMA != anti-throughput or anti-SGNicolas Capens2011/02/23 06:12 AM
        anti-FMA != anti-throughput or anti-SGDavid Kanter2011/02/20 11:25 PM
        anti-FMA != anti-throughput or anti-SGDavid Kanter2011/02/17 06:51 PM
        Tarantula vector unit well-integratedPaul A. Clayton2011/02/18 12:38 AM
        anti-FMA != anti-throughput or anti-SGMegol2011/02/19 02:17 PM
        anti-FMA != anti-throughput or anti-SGDavid Kanter2011/02/20 02:09 AM
        anti-FMA != anti-throughput or anti-SGMegol2011/02/20 09:55 AM
        anti-FMA != anti-throughput or anti-SGDavid Kanter2011/02/20 01:39 PM
        anti-FMA != anti-throughput or anti-SGEduardoS2011/02/20 02:35 PM
        anti-FMA != anti-throughput or anti-SGMegol2011/02/21 08:12 AM
        anti-FMA != anti-throughput or anti-SGanon2011/02/17 10:44 PM
        anti-FMA != anti-throughput or anti-SGMichael S2011/02/18 06:20 AM
        one more anti-FMA flame. By me.Eric Bron2011/02/17 08:24 AM
        thanksMichael S2011/02/17 04:56 PM
        CPUs are latency optimizedEduardoS2011/02/15 01:24 PM
        SwiftShader SNB testEric Bron2011/02/15 03:46 PM
        SwiftShader NHM testEric Bron2011/02/15 04:50 PM
        SwiftShader SNB testNicolas Capens2011/02/17 12:06 AM
        SwiftShader SNB testEric Bron2011/02/17 01:21 AM
        SwiftShader SNB testEric Bron2011/02/22 10:32 AM
        SwiftShader SNB test 2nd runEric Bron2011/02/22 10:51 AM
        SwiftShader SNB test 2nd runNicolas Capens2011/02/23 02:14 PM
        SwiftShader SNB test 2nd runEric Bron2011/02/23 02:42 PM
        Win7SP1 out but no AVX hype?Michael S2011/02/24 03:14 AM
        Win7SP1 out but no AVX hype?Eric Bron2011/02/24 03:39 AM
        CPUs are latency optimizedEric Bron2011/02/15 08:02 AM
        CPUs are latency optimizedEduardoS2011/02/11 03:40 PM
                                              CPU only rendering - not a long way offNicolas Capens2011/02/07 06:45 AM
                                                CPU only rendering - not a long way offDavid Kanter2011/02/07 12:09 PM
                                                  CPU only rendering - not a long way offanonymous2011/02/07 10:25 PM
                                                    Sandy Bridge IGP EUsDavid Kanter2011/02/07 11:22 PM
                                                      Sandy Bridge IGP EUsHannes2011/02/08 05:59 AM
                                SW Rasterization - Why?Seni2011/02/02 02:53 PM
                                  Market reasons to ditch the IGPNicolas Capens2011/02/10 03:12 PM
                                    Market reasons to ditch the IGPSeni2011/02/11 05:42 AM
                                      Market reasons to ditch the IGPNicolas Capens2011/02/16 04:29 AM
                                        Market reasons to ditch the IGPSeni2011/02/16 01:39 PM
                                          An excellent post!David Kanter2011/02/16 03:18 PM
                                          CPUs clock higherMoritz2011/02/17 08:06 AM
                                          Market reasons to ditch the IGPNicolas Capens2011/02/18 06:22 PM
                                            Market reasons to ditch the IGPIntelUser20002011/02/18 07:20 PM
                                              Market reasons to ditch the IGPNicolas Capens2011/02/21 02:42 PM
                                                Bad data (repeated)David Kanter2011/02/22 12:21 AM
                                                  Bad data (repeated)none2011/02/22 03:04 AM
                                                    13W or 8W?Foo_2011/02/22 06:00 AM
                                                      13W or 8W?Linus Torvalds2011/02/22 08:58 AM
                                                        13W or 8W?David Kanter2011/02/22 11:33 AM
                                                          13W or 8W?Mark Christiansen2011/02/22 02:47 PM
                                                  Bigger pictureNicolas Capens2011/02/24 06:33 PM
                                                    Bigger pictureNicolas Capens2011/02/24 08:06 PM
                                                    20+ WattNicolas Capens2011/02/24 08:18 PM
                                                      <20WDavid Kanter2011/02/25 01:13 PM
                                                        >20WNicolas Capens2011/03/08 07:34 PM
                                                          IGP is 3X more efficientDavid Kanter2011/03/08 10:53 PM
                                                            IGP is 3X more efficientEric Bron2011/03/09 02:44 AM
                                                          >20WEric Bron2011/03/09 03:48 AM
                                                    Specious data and claims are still speciousDavid Kanter2011/02/25 02:38 AM
                                                      IGP power consumption, LRB samplersNicolas Capens2011/03/08 06:24 PM
                                                        IGP power consumption, LRB samplersEduardoS2011/03/08 06:52 PM
                                                        IGP power consumption, LRB samplersRohit2011/03/09 07:42 AM
                                                Market reasons to ditch the IGPnone2011/02/22 02:58 AM
                                                  Market reasons to ditch the IGPNicolas Capens2011/02/24 06:43 PM
                                                Market reasons to ditch the IGPslacker2011/02/22 02:32 PM
                                            Market reasons to ditch the IGPSeni2011/02/18 09:51 PM
                                              Correction - 28 comparators, not 36. (NT)Seni2011/02/18 10:03 PM
                                              Market reasons to ditch the IGPGabriele Svelto2011/02/19 01:49 AM
                                                Market reasons to ditch the IGPSeni2011/02/19 11:59 AM
                                                  Market reasons to ditch the IGPExophase2011/02/20 10:43 AM
                                              Market reasons to ditch the IGPEduardoS2011/02/19 10:13 AM
                                                Market reasons to ditch the IGPSeni2011/02/19 11:46 AM
                                              The next revolutionNicolas Capens2011/02/22 03:33 AM
                                                The next revolutionGabriele Svelto2011/02/22 09:15 AM
                                                  The next revolutionEric Bron2011/02/22 09:48 AM
                                                  The next revolutionNicolas Capens2011/02/23 07:39 PM
                                                    The next revolutionGabriele Svelto2011/02/24 12:43 AM
                                                      GPGPU content creation (or lack of it)Nicolas Capens2011/02/28 07:39 AM
                                                        GPGPU content creation (or lack of it)The market begs to differ2011/03/01 06:32 AM
                                                          GPGPU content creation (or lack of it)Nicolas Capens2011/03/09 09:14 PM
                                                            GPGPU content creation (or lack of it)Gabriele Svelto2011/03/10 01:01 AM
                                                        The market begs to differGabriele Svelto2011/03/01 06:33 AM
                                                    The next revolutionAnon2011/02/24 02:15 AM
                                                      The next revolutionNicolas Capens2011/02/28 02:34 PM
                                                The next revolutionSeni2011/02/22 02:02 PM
                                                  The next revolutionGabriele Svelto2011/02/23 06:27 AM
                                                    The next revolutionSeni2011/02/23 09:03 AM
                                                  The next revolutionNicolas Capens2011/02/24 06:11 AM
                                                    The next revolutionSeni2011/02/24 08:45 PM
                                                      IGP sampler countNicolas Capens2011/03/03 05:19 AM
                                                      Latency and throughput optimized coresNicolas Capens2011/03/07 03:28 PM
                                                        The real reason no IGP /CPU converge.Jouni Osmala2011/03/07 11:34 PM
                                                          Still convergingNicolas Capens2011/03/13 03:08 PM
                                                      Homogeneous CPU advantagesNicolas Capens2011/03/08 12:12 AM
                                                        Homogeneous CPU advantagesSeni2011/03/08 09:23 AM
                                                        Homogeneous CPU advantagesDavid Kanter2011/03/08 11:16 AM
                                                          Homogeneous CPU advantagesBrett2011/03/09 03:37 AM
                                                        Homogeneous CPU advantagesJouni Osmala2011/03/09 12:27 AM
                                SW Rasterizationfirsttimeposter2011/02/03 11:18 PM
                                  SW RasterizationNicolas Capens2011/02/04 04:48 AM
                                    SW RasterizationEric Bron2011/02/04 05:14 AM
                                      SW RasterizationNicolas Capens2011/02/04 08:36 AM
                                        SW RasterizationEric Bron2011/02/04 08:42 AM
                        Sandy Bridge CPU article onlineEric Bron2011/01/26 03:23 AM
                        Sandy Bridge CPU article onlineGabriele Svelto2011/02/04 04:31 AM
                          Sandy Bridge CPU article onlineNicolas Capens2011/02/05 08:46 PM
                            Sandy Bridge CPU article onlineGabriele Svelto2011/02/06 06:20 AM
                              Sandy Bridge CPU article onlineNicolas Capens2011/02/06 06:07 PM
      Sandy Bridge CPU article onlinearch.comp2011/01/06 10:58 PM
        Sandy Bridge CPU article onlineSeni2011/01/07 10:25 AM
    Sandy Bridge CPU article onlineMichael S2011/01/05 04:28 AM
      Sandy Bridge CPU article onlineNicolas Capens2011/01/05 06:06 AM
        permuting vector elements (yet again)hobold2011/01/05 05:15 PM
          permuting vector elements (yet again)Nicolas Capens2011/01/06 06:11 AM
      Sandy Bridge CPU article onlineEric Bron2011/01/05 12:46 PM
        wow ...!hobold2011/01/05 05:19 PM
          wow ...!Nicolas Capens2011/01/05 06:11 PM
          wow ...!Eric Bron2011/01/05 10:46 PM
            compress LUTEric Bron2011/01/05 11:05 PM
          wow ...!Michael S2011/01/06 02:25 AM
            wow ...!Nicolas Capens2011/01/06 06:26 AM
              wow ...!Eric Bron2011/01/06 09:08 AM
                wow ...!Nicolas Capens2011/01/07 07:19 AM
                wow ...!Steve Underwood2011/01/07 10:53 PM
                  saturationhobold2011/01/08 10:25 AM
                    saturationSteve Underwood2011/01/08 12:38 PM
                      saturationMichael S2011/01/08 01:05 PM
                        128 bit floatsBrett2011/01/08 01:39 PM
                          128 bit floatsMichael S2011/01/08 02:10 PM
                            128 bit floatsAnil Maliyekkel2011/01/08 03:46 PM
                              128 bit floatsKevin G2011/02/27 11:15 AM
                                128 bit floatshobold2011/02/27 04:42 PM
                                  128 bit floatsIan Ollmann2011/02/28 04:56 PM
                                    OpenCL FP accuracyhobold2011/03/01 06:45 AM
                                      OpenCL FP accuracyanon2011/03/01 08:03 PM
                                        OpenCL FP accuracyhobold2011/03/02 03:53 AM
                                      OpenCL FP accuracyEric Bron2011/03/02 07:10 AM
                                        pet projecthobold2011/03/02 09:22 AM
                                          pet projectAnon2011/03/02 09:10 PM
                                            pet projecthobold2011/03/03 04:57 AM
                                          pet projectEric Bron2011/03/03 02:29 AM
                                            pet projecthobold2011/03/03 05:14 AM
                                              pet projectEric Bron2011/03/03 03:10 PM
                                                pet projecthobold2011/03/03 04:04 PM
                                        OpenCL and AMDVincent Diepeveen2011/03/07 01:44 PM
                                          OpenCL and AMDEric Bron2011/03/08 02:05 AM
                                            OpenCL and AMDVincent Diepeveen2011/03/08 08:27 AM
                                128 bit floatsMichael S2011/02/27 04:46 PM
                                128 bit floatsAnil Maliyekkel2011/02/27 06:14 PM
                        saturationSteve Underwood2011/01/17 04:42 AM
            wow ...!hobold2011/01/06 05:05 PM
  RingMoritz2011/01/20 10:51 PM
    RingAntti-Ville Tuunainen2011/01/21 12:25 PM
      RingMoritz2011/01/23 01:38 AM
        RingMichael S2011/01/23 04:04 AM
          So fastMoritz2011/01/23 07:57 AM
            So fastDavid Kanter2011/01/23 10:05 AM
  Sandy Bridge CPU (L1D cache)Gordon Ward2011/09/09 02:47 AM
    Sandy Bridge CPU (L1D cache)David Kanter2011/09/09 04:19 PM
      Sandy Bridge CPU (L1D cache)EduardoS2011/09/09 08:53 PM
      Sandy Bridge CPU (L1D cache)Paul A. Clayton2011/09/10 05:12 AM
      Sandy Bridge CPU (L1D cache)Michael S2011/09/10 09:41 AM
        Sandy Bridge CPU (L1D cache)EduardoS2011/09/10 11:17 AM
  Address Ports on Sandy Bridge SchedulerVictor2011/10/16 06:40 AM
    Address Ports on Sandy Bridge SchedulerEduardoS2011/10/16 07:45 PM
    Address Ports on Sandy Bridge SchedulerMegol2011/10/17 09:20 AM
      Address Ports on Sandy Bridge SchedulerVictor2011/10/18 05:34 PM
        Benefits of early schedulingPaul A. Clayton2011/10/18 06:53 PM
          Benefits of early schedulingVictor2011/10/19 05:58 PM
            Consistency and invalidation orderingPaul A. Clayton2011/10/20 04:43 AM
        Address Ports on Sandy Bridge SchedulerJohn Upcroft2011/10/21 04:16 PM
          Address Ports on Sandy Bridge SchedulerDavid Kanter2011/10/22 10:49 AM
            Address Ports on Sandy Bridge SchedulerJohn Upcroft2011/10/26 01:24 PM
              Store TLB look-up at commit?Paul A. Clayton2011/10/26 08:30 PM
                Store TLB look-up at commit?Richard Scott2011/10/26 09:40 PM
                  Just a guessPaul A. Clayton2011/10/27 01:54 PM
How do you spell tangerine? 🍊
