64 bit LPDDR2 is enough for Ivy's 24EU IGP...
By: Hans de Vries (all.spam.to.delete@this.nowhere.com), January 7, 2011 6:27 pm
Groo (charlie@semiaccurate.com) on 1/1/11 wrote:
>I have good reason to use all the numbers I used. :)
>-Charlie
I don't know the original info you got but a 512 bit LPDDR2
bus inside the package is in principle easy using standard
mass fabrication methods. It is relatively cheap using the
standard parts and freedom of choice of procurement from
any of the major DRAM manufacturers. It gives you 4GB..8GB
now and a 16GB option later this year which should be enough
for most of the users.
LPDDR2 is an electrical/signaling/package standard defined
for DRAM, Flash and DRAM/Flash combos which goes up to
1,066 Mb/sec/pin over a 64 bit bus. 512 bit would be a 3x3
array of LPDDR2 packages with the center location open for
power dissipation management.
http://www.jedec.org/news/pressreleases/jedec-announces-publication-lpddr2-standard-low-power-memory-devices
http://www.samsung.com/global/business/semiconductor/Greenmemory/Products/LPDDR2/LPDDR2_Overview.html
To see how the POP (Package on Package) buildup would be
just look at the this cross section of the iPhone package.
http://www.ifixit.com/Misc/iphone_processor_crossection.jpg
http://www.ifixit.com/Teardown/Apple-A4-Teardown/2204/1
Regards, Hans
Ivy Bridge and stacked DRAMDavid Kanter2010/12/29 02:06 PM
  Ivy Bridge and stacked DRAMGroo2010/12/29 04:31 PM
    Ivy Bridge and stacked DRAMRohit2010/12/30 12:02 AM
      Ivy Bridge and stacked DRAMGroo2010/12/30 01:20 PM
    Ivy Bridge and stacked DRAManon2010/12/30 03:26 AM
      Ivy Bridge and stacked DRAMGroo2010/12/30 01:23 PM
        Ivy Bridge and stacked DRAManon2010/12/30 03:59 PM
          Ivy Bridge and stacked DRAMGroo2010/12/30 07:24 PM
            64 bit LPDDR2 is enough for Ivy's 24EU IGP...Hans de Vries2010/12/30 11:54 PM
              64 bit LPDDR2 is enough for Ivy's 24EU IGP...Groo2011/01/01 01:07 PM
                64 bit LPDDR2 is enough for Ivy's 24EU IGP...Hans de Vries2011/01/07 06:27 PM
              64 bit LPDDR2 is enough for Ivy's 24EU IGP...IntelUser20002011/01/03 05:28 AM
          Ivy Bridge and stacked DRAMJouni Osmala2011/01/04 12:39 AM
  Ivy Bridge and stacked DRAMEuronymous2010/12/29 10:35 PM
    TSV + interposerDavid Kanter2010/12/29 11:36 PM
      TSV + interposerEuronymous2010/12/30 06:25 AM
      TSV + interposerarf2010/12/30 12:11 PM
        TSV dimensions vs. metal layersDavid Kanter2010/12/30 12:33 PM
          TSV dimensions vs. metal layersarf2010/12/30 03:24 PM
            TSV dimensions vs. metal layersDavid Kanter2010/12/30 06:10 PM
        TSV + interposerGroo2010/12/30 02:08 PM
          TSV + interposerDavid Kanter2010/12/30 02:45 PM
            TSV + interposerGroo2010/12/30 07:22 PM
    Ivy Bridge and stacked DRAMGroo2010/12/30 01:26 PM
  Ivy Bridge and stacked DRAMajensen2010/12/30 03:50 AM
  512-bit without TSV?M.Isobe2010/12/30 06:47 AM
    Multiple interposers are needed for ultra-wide interfaceM.Isobe2010/12/30 07:12 AM
  Stacked DRAM: Good for what it is intendedWill Smith2011/01/03 05:37 AM
