By: Wilco (Wilco.Dijkstra.delete@this.ntlworld.com), January 13, 2011 7:09 am
Megol (golem960@gmail.com) on 1/13/11 wrote:
>Wilco (Wilco.Dijkstra@ntlworld.com) on 1/12/11 wrote:
>>>[If the rumors are right and Microsoft indeed finishing porting of their Nt-based
>>>line to ARM], I see close to zero chance that they will set SCTLR.A=1.
>>Indeed. Note booting NT on ARM has been a compiler checkin requirement for a long time...
>>>>So an ARM compiler will use LDM or LDRD
>>>>only if the access is guaranteed (by the ABI) to be least 4-byte aligned. For badly
>>>>written software which doesn't understand alignment at all, I added a mode in the
>>>>ARM compiler which assumes all accesses are unaligned.
>>>>Wilco
>>>Why do you call it badly written?
>>>In my book the software does not have to be portable to be considered well-written.
>>Writing software without considering portability is just madness, it doesn't take
>>much extra effort, and I'd argue that anyone who doesn't understand portability
>>shouldn't really be writing software in the first place. Tomorrow your manager may
>>tell you that your N million line application has been sold - oh and I promised
>you will deliver the port next month...
>True _IFF_ one writes embedded code. Not if one designs applications intended only for x86.
>People treating C/C++ as some kind of universal language will never get close to speed of light.
There are multiple OSes and compilers in the x86 world. Then there is 32-bit vs 64-bit. So you end up porting your software anyway even when you stay in the x86 world.
And making your software portable does not at all mean losing performance. Understanding the issues will actually improve performance (eg. knowing that aligning data is good for performance on x86).
>>>That is, as long as it runs fast and correct within well-defined platform constrains.
>>>On x86 doing unaligned access is in most cases the best from performance perspective
>>>so, as long as portability is not part of the spec, the software that in performance-critical
>>>parts does something else could be considered badly written.
>>Code with lots of misaligned accesses typically doesn't run fast - not even on
>>x86 as there is always a penalty. There certainly are a few key examples where they
>>improve performance, but apart from those, unaligned accesses don't help much, even there wasn't any penalty.
>"lots of misaligned accesses" is something you wrote not the parent.
>X86 have a penalty for unaligned accesses however there are many cases where not
>specializing code to handle a handful of unaligned accesses is much faster. This
>can be compared with architectures not supporting unaligned accesses at all where
>the comparable code have to be slow to catch the few misaligned accesses there are.
That's not how it works. If there are a few unaligned cases then one would ensure those few cases are either aligned or dealt with specially in some other way. So your performance critical code doesn't need to be slowed down in any way. However I accept it takes extra effort to track down and fix the unaligned cases, and that is why people prefer having hardware unaligned accesses.
>>However you can use unaligned accesses safely and portably. So in cases where it
>>does improve performance or is required to process unaligned data it's perfectly
>>fine. I consider it badly written if the unaligned access isn't explicitly marked
>>- in those cases it is often not only a correctness bug but also a performance hog.
>>Wilco
>There are many cases where it isn't possible to do it explicitly, the standard
>languages aren't powerful enough for that.
I can't imagine a case where it isn't powerful enough. You could describe the fact that an int pointer passed to a function may be unaligned by declaring it as void*. Then whenever you cast it to int* you know that you either need a runtime check or always do the access one byte at a time. With a few simple defines this can be both portable as well as optimal.
Wilco
>>>>Wilco
>>Wilco
Wilco
Topic | Posted By | Date |
The ARM story: Earthquake looming? | Will Smith | 2011/01/12 01:30 AM |
The ARM story: Earthquake looming? | Max | 2011/01/12 02:50 AM |
Any x86 -> ARM port experience? | Ben Harper | 2011/01/12 04:22 AM |
Any x86 -> ARM port experience? | Michael S | 2011/01/12 07:52 AM |
Any x86 -> ARM port experience? | Megol | 2011/01/12 10:10 AM |
Any x86 -> ARM port experience? | Michael S | 2011/01/12 11:19 AM |
Any x86 -> ARM port experience? | Wilco | 2011/01/12 12:47 PM |
badly written? | Michael S | 2011/01/12 01:59 PM |
badly written? | Wilco | 2011/01/12 03:03 PM |
badly written? | Megol | 2011/01/13 05:16 AM |
badly written? | Wilco | 2011/01/13 07:09 AM |
badly written? | Megol | 2011/01/14 03:28 AM |
badly written? | Wilco | 2011/01/14 07:20 AM |
badly written? | mpx | 2011/01/13 09:19 AM |
badly written? | James | 2011/01/14 04:15 AM |
unaligned read is fast on Nehalem | Richard Cownie | 2011/01/13 10:10 AM |
unaligned read is fast on Nehalem | Linus Torvalds | 2011/01/13 10:45 AM |
l1 access size? | anon | 2011/01/13 12:16 PM |
unaligned read is fast on Nehalem | Richard Cownie | 2011/01/13 12:21 PM |
unaligned read is fast on Nehalem | EduardoS | 2011/01/13 04:42 PM |
unaligned read is fast on Nehalem | Michael S | 2011/01/13 04:50 PM |
unaligned read is fast on Nehalem | Richard Cownie | 2011/01/13 05:50 PM |
unaligned read is fast on Nehalem | Konrad Schwarz | 2011/01/17 07:28 AM |
badly written? | anoneeeemouse | 2011/01/12 06:31 PM |
And endianness? | Ben Harper | 2011/01/13 05:34 AM |
And endianness? | rwessel | 2011/01/13 05:40 AM |
And endianness? | Wilco | 2011/01/13 06:20 AM |
And endianness? | Ben Harper | 2011/01/13 08:11 AM |
And endianness? | Konrad Schwarz | 2011/01/17 07:20 AM |
And endianness? | Megol | 2011/01/17 11:09 AM |
Any x86 -> ARM port experience? | EduardoS | 2011/01/12 02:30 PM |
Any x86 -> ARM port experience? | anon | 2011/01/12 10:53 AM |
Any x86 -> ARM port experience? | anon | 2011/01/12 10:28 PM |
Any x86 -> ARM port experience? | anon | 2011/01/12 10:52 PM |
The ARM story: Earthquake looming? | Linus Torvalds | 2011/01/12 11:44 AM |
The ARM story: Earthquake looming? | Wilco | 2011/01/12 03:53 PM |
The ARM story: Earthquake looming? | anon | 2011/01/12 04:14 PM |
The ARM story: Earthquake looming? | Wilco | 2011/01/12 04:20 PM |
The ARM story: Earthquake looming? | anon | 2011/01/12 04:36 PM |
The ARM story: Earthquake looming? | Wilco | 2011/01/12 05:17 PM |
The ARM story: Earthquake looming? | Aaron Spink | 2011/01/12 05:46 PM |
The ARM story: Earthquake looming? | Wilco | 2011/01/12 05:54 PM |
The ARM story: Earthquake looming? | anon | 2011/01/12 05:49 PM |
The ARM story: Earthquake looming? | Wilco | 2011/01/12 06:20 PM |
The ARM story: Earthquake looming? | anon | 2011/01/12 07:20 PM |
The ARM story: Earthquake looming? | Wilco | 2011/01/12 08:51 PM |
Some CoreMark results | Paul A. Clayton | 2011/01/12 07:41 PM |
Some CoreMark results | Wilco | 2011/01/12 10:49 PM |
Some CoreMark results | Paul A. Clayton | 2011/01/13 09:14 AM |
Some CoreMark results | Wilco | 2011/01/13 12:31 PM |
Some CoreMark results | Linus Torvalds | 2011/01/13 12:36 PM |
Some CoreMark results | anonymous | 2011/01/13 01:05 PM |
Some CoreMark results | Wilco | 2011/01/13 01:15 PM |
Some CoreMark results | Linus Torvalds | 2011/01/13 03:02 PM |
Some CoreMark results | Wilco | 2011/01/14 08:24 AM |
Some CoreMark results | none | 2011/01/14 08:55 AM |
The ARM story: Earthquake looming? | Linus Torvalds | 2011/01/12 04:21 PM |
The ARM story: Earthquake looming? | Wilco | 2011/01/12 05:07 PM |
The ARM story: Earthquake looming? | Linus Torvalds | 2011/01/12 06:07 PM |
The ARM story: Earthquake looming? | Michael S | 2011/01/13 04:33 AM |
The ARM story: Earthquake looming? | Linus Torvalds | 2011/01/13 09:19 AM |
The ARM story: Earthquake looming? | Megol | 2011/01/14 04:51 AM |
The ARM story: Earthquake looming? | anon | 2011/01/12 05:09 PM |
The ARM story: Earthquake looming? | Linus Torvalds | 2011/01/12 06:09 PM |
The ARM story: Earthquake looming? | anonymous | 2011/01/13 06:50 AM |
The ARM story: Earthquake looming? | Michael S | 2011/01/13 07:52 AM |
The ARM story: Earthquake looming? | Linus Torvalds | 2011/01/13 10:28 AM |
The ARM story: Earthquake looming? | ? | 2011/01/14 08:48 AM |
The ARM story: Earthquake looming? | none | 2011/01/14 09:01 AM |
The ARM story: Earthquake looming? | someone | 2011/01/14 11:03 AM |
The ARM story: Earthquake looming? | none | 2011/01/14 03:38 PM |
The ARM story: Earthquake looming? | someone | 2011/01/15 10:53 AM |
The ARM story: Earthquake looming? | mpx | 2011/01/15 01:18 AM |
The ARM story: Earthquake looming? | Aaron Spink | 2011/01/15 06:03 AM |
The ARM story: Earthquake looming? | Brett | 2011/01/15 12:01 PM |
The ARM story: Earthquake looming? | mpx | 2011/01/15 01:40 PM |
The ARM story: Earthquake looming? | Aaron Spink | 2011/01/17 04:11 PM |
The ARM story: Earthquake looming? | Rob Thorpe | 2011/01/17 04:35 PM |
The ARM story: Earthquake looming? | Michael S | 2011/01/17 05:23 PM |
As you can see... | Rob Thorpe | 2011/01/17 06:52 PM |
The ARM story: Earthquake looming? | Aaron Spink | 2011/01/17 05:57 PM |
The ARM story: Earthquake looming? | Greg Gritton | 2011/01/17 11:57 PM |
The ARM story: Earthquake looming? | Brett | 2011/01/18 11:00 AM |
The ARM story: Earthquake looming? | Megol | 2011/01/18 11:11 AM |
The ARM story: Earthquake looming? | Max | 2011/01/18 01:34 AM |
The ARM story: Earthquake looming? | Brett | 2011/01/18 10:39 AM |
Apple | David Kanter | 2011/01/18 11:22 AM |
The ARM story: Earthquake looming? | Max | 2011/01/18 12:17 PM |
The ARM story: Earthquake looming? | Rob Thorpe | 2011/01/18 03:36 PM |
The ARM story: Earthquake looming? | Brett | 2011/01/18 06:00 PM |
The ARM story: Earthquake looming? | David Kanter | 2011/01/18 07:44 PM |
The ARM story: Earthquake looming? | rwessel | 2011/01/18 09:19 PM |
Definition of SOC | Rob Thorpe | 2011/01/19 02:24 PM |
The ARM story: Earthquake looming? | Aaron Spink | 2011/01/18 11:26 PM |
The ARM story: Earthquake looming? | Brett | 2011/01/19 01:57 AM |
The ARM story: Earthquake looming? | Aaron Spink | 2011/01/19 02:15 AM |
Pioneers get arrows in their backs | Brett | 2011/01/19 07:08 PM |
Pioneers get arrows in their backs | Aaron Spink | 2011/01/19 08:22 PM |
Plausible ID, HCI translation | Paul A. Clayton | 2011/01/19 09:18 AM |
Quad pixel? | David Kanter | 2011/01/19 02:37 PM |
Quad pixel? | Brett | 2011/01/19 03:53 PM |
Quad pixel? | David Kanter | 2011/01/19 08:10 PM |
TRIM (was Quad pixel?) | Linus Torvalds | 2011/01/19 05:22 PM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/19 08:15 PM |
TRIM (was Quad pixel?) | anon | 2011/01/19 09:11 PM |
TRIM (was Quad pixel?) | Linus Torvalds | 2011/01/19 09:12 PM |
TRIM (was Quad pixel?) | iz | 2011/01/19 10:03 PM |
TRIM (was Quad pixel?) | Linus Torvalds | 2011/01/19 10:52 PM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/19 11:35 PM |
TRIM (was Quad pixel?) | anon | 2011/01/19 11:43 PM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/20 12:23 AM |
TRIM (was Quad pixel?) | anon | 2011/01/20 01:00 AM |
TRIM (was Quad pixel?) | mpx | 2011/01/20 02:34 PM |
TRIM (was Quad pixel?) | anon | 2011/01/20 04:29 PM |
TRIM (was Quad pixel?) | Linus Torvalds | 2011/01/20 09:34 AM |
TRIM (was Quad pixel?) | Ricardo B | 2011/01/20 11:25 AM |
TRIM (was Quad pixel?) | Linus Torvalds | 2011/01/20 11:51 AM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/20 01:28 PM |
TRIM (was Quad pixel?) | anon | 2011/01/20 02:00 PM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/20 03:52 PM |
TRIM (was Quad pixel?) | anon | 2011/01/20 04:30 PM |
TRIM (was Quad pixel?) | Ricardo B | 2011/01/20 01:36 PM |
TRIM (was Quad pixel?) | Linus Torvalds | 2011/01/20 04:57 PM |
TRIM (was Quad pixel?) | Ricardo B | 2011/01/20 06:14 PM |
TRIM (was Quad pixel?) | MS | 2011/01/21 09:06 AM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/20 01:19 PM |
TRIM (was Quad pixel?) | mpx | 2011/01/21 05:45 AM |
TRIM (was Quad pixel?) | James | 2011/01/21 07:37 AM |
TRIM (was Quad pixel?) | mpx | 2011/01/21 03:10 PM |
databases and filesystems | Foo_ | 2011/01/21 06:26 AM |
TRIM (was Quad pixel?) | iz | 2011/01/20 12:45 AM |
TRIM (was Quad pixel?) | Linus Torvalds | 2011/01/20 09:54 AM |
TRIM (was Quad pixel?) | iz | 2011/01/20 11:28 PM |
TRIM (was Quad pixel?) | anon | 2011/01/19 10:34 PM |
TRIM (was Quad pixel?) | Doug Siebert | 2011/01/19 11:48 PM |
TRIM (was Quad pixel?) | anon | 2011/01/19 11:59 PM |
TRIM - How about we use LBA and PBA? | Aaron Spink | 2011/01/20 12:06 AM |
TRIM - How about we use LBA and PBA? | anon | 2011/01/20 12:10 AM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/20 05:23 PM |
TRIM (was Quad pixel?) | Anon | 2011/01/19 10:58 PM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/19 11:04 PM |
TRIM (was Quad pixel?) | anon | 2011/01/19 11:34 PM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/19 11:59 PM |
TRIM (was Quad pixel?) | anon | 2011/01/20 12:18 AM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/20 12:54 AM |
TRIM (was Quad pixel?) | anon | 2011/01/20 01:12 AM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/20 01:44 AM |
TRIM (was Quad pixel?) | anon | 2011/01/20 08:56 AM |
TRIM (was Quad pixel?) | anon | 2011/01/20 08:59 AM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/20 01:33 PM |
TRIM (was Quad pixel?) | anon | 2011/01/20 04:55 PM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/20 05:14 PM |
TRIM (was Quad pixel?) | anon | 2011/01/20 06:14 PM |
TRIM (was Quad pixel?) | Aaron Spink | 2011/01/20 08:38 PM |
TRIM (was Quad pixel?) | anon | 2011/01/20 09:16 PM |
TRIM (was Quad pixel?) | mpx | 2011/01/20 03:58 PM |
Supercaps | slacker | 2011/01/20 04:57 PM |
Supercaps | Aaron Spink | 2011/01/20 05:20 PM |
Supercaps | slacker | 2011/01/20 05:43 PM |
Supercaps | Aaron Spink | 2011/01/20 08:25 PM |
Supercaps | slacker | 2011/01/20 11:02 PM |
Supercaps | MS | 2011/01/21 01:37 PM |
TRIM (was Quad pixel?) | Linus Torvalds | 2011/01/20 09:58 AM |
TRIM (was Quad pixel?) | ajensen | 2011/01/21 03:23 AM |
Mythical SSDs | Ricardo B | 2011/01/21 06:27 AM |
Mythical SSDs | Linus Torvalds | 2011/01/21 10:24 AM |
Mythical SSDs | anon | 2011/01/21 12:00 PM |
What is off-line? | David Kanter | 2011/01/21 12:09 PM |
What is off-line? | Linus Torvalds | 2011/01/21 01:51 PM |
What is off-line? | Octoploid | 2011/01/21 02:04 PM |
Mythical SSDs | ajensen | 2011/01/21 12:28 PM |
Mythical SSDs | Aaron Spink | 2011/01/21 12:58 PM |
Mythical SSDs | Linus Torvalds | 2011/01/21 01:21 PM |
Mythical SSDs | Aaron Spink | 2011/01/21 04:13 PM |
Mythical SSDs | anon | 2011/01/21 07:47 PM |
Mythical SSDs | mpx | 2011/01/22 01:01 AM |
Mythical SSDs | anon | 2011/01/22 02:08 AM |
Mythical Linus | ? | 2011/01/25 07:16 AM |
Mythical Linus | Ungo | 2011/01/25 12:35 PM |
Mythical Linus | Dean Kent | 2011/01/25 01:14 PM |
Filesystem impact | David Kanter | 2011/01/25 01:16 PM |
Filesystem impact | Ungo | 2011/01/25 03:15 PM |
Filesystem impact | iz | 2011/01/25 05:18 PM |
Filesystem impact | Aaron Spink | 2011/01/26 01:25 PM |
Filesystem impact | Foo_ | 2011/01/25 05:14 PM |
Filesystem impact | iz | 2011/01/25 05:24 PM |
Filesystem impact | Aaron Spink | 2011/01/26 01:27 PM |
Filesystem impact | Robert Myers | 2011/01/26 06:43 PM |
Filesystem impact | anon | 2011/01/26 08:29 PM |
Filesystem impact | anon | 2011/01/26 07:19 PM |
Filesystem impact | Groo | 2011/01/25 07:42 PM |
Filesystem impact | iz | 2011/01/25 10:03 PM |
Filesystem impact | mpx | 2011/01/26 02:15 AM |
Filesystem impact | iz | 2011/01/26 03:14 AM |
Windows 7 and SSDs: Setup secrets and tune-up tweaks | _Arthur | 2011/01/26 06:59 PM |
TRIM | iz | 2011/01/19 09:54 PM |
TRIM | Aaron Spink | 2011/01/19 11:43 PM |
TRIM | iz | 2011/01/20 01:01 AM |
TRIM | Aaron Spink | 2011/01/20 01:25 AM |
TRIM | iz | 2011/01/20 04:29 AM |
TRIM (was Quad pixel?) | Megol | 2011/01/20 03:29 AM |
TRIM (was Quad pixel?) | Linus Torvalds | 2011/01/20 10:05 AM |
TRIM (was Quad pixel?) | Rob Thorpe | 2011/01/22 01:30 PM |
TRIM (was Quad pixel?) | anon | 2011/01/22 07:07 PM |
TRIM | David Kanter | 2011/01/24 02:05 PM |
TRIM | anon | 2011/01/24 02:57 PM |
TRIM | MS | 2011/01/24 03:22 PM |
TRIM | Dan Downs | 2011/01/24 06:44 PM |
TRIM | Dan Downs | 2011/01/24 06:51 PM |
TRIM | anon | 2011/01/24 07:29 PM |
TRIM | MS | 2011/01/24 08:40 PM |
TRIM | Ricardo B | 2011/01/25 03:40 PM |
TRIM | Anon | 2011/01/24 06:37 PM |
TRIM | Richard Cownie | 2011/01/24 07:45 PM |
TRIM | Aaron Spink | 2011/01/24 07:53 PM |
TRIM | Anon | 2011/01/24 09:28 PM |
TRIM | Richard Cownie | 2011/01/25 07:39 AM |
TRIM Linus is right | gallier2 | 2011/01/25 11:18 AM |
TRIM Linus is right | Max | 2011/01/25 12:30 PM |
TRIM Linus is right | Michael S | 2011/01/25 01:17 PM |
TRIM Linus is right | Max | 2011/01/25 06:15 PM |
TRIM Linus is right | Anon | 2011/01/25 09:09 PM |
TRIM Linus is right | gallier2 | 2011/01/26 02:26 AM |
TRIM Linus is right | anon | 2011/01/26 09:30 PM |
TRIM Linus is right | Ricardo B | 2011/01/26 02:12 AM |
TRIM Linus is right | iz | 2011/01/26 03:19 AM |
Linus is wrong - TRIM is *essential* | ? | 2011/01/26 05:04 AM |
Linus is wrong - TRIM is *essential* | Meeple | 2011/01/26 04:34 PM |
Linus is wrong - TRIM is *essential* | iz | 2011/01/26 08:01 PM |
Linus is wrong - TRIM is *essential* | anon | 2011/01/26 08:40 PM |
Linus is wrong - TRIM is *essential* | David Kanter | 2011/01/26 09:09 PM |
Linus is wrong - TRIM is *essential* | anon | 2011/01/26 09:40 PM |
TRIM Linus is right | MS | 2011/01/26 12:03 PM |
TRIM Linus is right | Michael S | 2011/01/26 12:48 PM |
TRIM Linus is right | MS | 2011/01/26 01:30 PM |
Relative latency | David Kanter | 2011/01/26 01:09 PM |
Relative latency | MS | 2011/01/26 01:34 PM |
NAND flash latencies | slacker | 2011/01/26 07:14 PM |
NAND flash latencies | iz | 2011/01/26 08:18 PM |
NAND flash latencies -- Correction | slacker | 2011/01/26 08:58 PM |
NAND flash latencies -- Correction | iz | 2011/01/27 12:58 AM |
NAND flash latencies -- Correction | David Kanter | 2011/01/27 01:54 AM |
NAND flash latencies -- Correction | Ricardo B | 2011/01/27 04:42 AM |
NAND flash latencies -- Correction | iz | 2011/01/27 07:54 PM |
NAND flash latencies -- Correction | Ricardo B | 2011/01/28 06:02 AM |
NAND flash latencies -- Correction | MS | 2011/01/28 03:06 PM |
NAND flash latencies -- Correction | iz | 2011/01/28 05:12 PM |
Relative latency | Ricardo B | 2011/01/26 03:23 PM |
Relative latency | MS | 2011/01/26 04:16 PM |
TRIM Linus is right | James | 2011/01/26 05:26 AM |
TRIM Linus is right | gallier2 | 2011/01/25 02:46 PM |
TRIM Linus is right | MS | 2011/01/25 03:10 PM |
Linus is HALF right | Darrell Coker | 2011/01/25 07:36 PM |
Linus is HALF right | Ricardo B | 2011/01/26 01:52 AM |
EXT4 *not* heavily optimized for rotating media | ? | 2011/01/26 02:34 AM |
TRIM | Anon | 2011/01/25 09:00 PM |
The alternative to TRIM | Max | 2011/01/20 11:35 AM |
The alternative to TRIM | anon | 2011/01/20 04:57 PM |
The alternative to TRIM | Max | 2011/01/21 02:27 AM |
The alternative to TRIM | Dan Downs | 2011/01/20 05:18 PM |
The alternative to TRIM | Aaron Spink | 2011/01/20 05:34 PM |
The alternative to TRIM | Linus Torvalds | 2011/01/20 06:16 PM |
The alternative to TRIM | Gabriele Svelto | 2011/01/22 02:10 AM |
The alternative to TRIM | Dan Downs | 2011/01/20 07:12 PM |
The alternative to TRIM | Aaron Spink | 2011/01/20 08:34 PM |
Another Alternative to Trim | Mark Christiansen | 2011/01/22 12:07 PM |
Another Alternative to Trim | iz | 2011/01/22 06:43 PM |
Another Alternative to Trim | Linus Torvalds | 2011/01/22 09:12 PM |
Another Alternative to Trim | Aaron Spink | 2011/01/23 02:01 AM |
Another Alternative to Trim | iz | 2011/01/23 05:20 AM |
Another Alternative to Trim | mpx | 2011/01/23 12:00 PM |
Another Alternative to Trim | iz | 2011/01/23 06:10 PM |
TRIM vs. GC for SSD Longevity | mpx | 2011/01/20 02:19 PM |
TRIM vs. GC for SSD Longevity | iz | 2011/01/20 07:05 PM |
TRIM vs. GC for SSD Longevity | mpx | 2011/01/21 03:29 AM |
TRIM vs. GC for SSD Longevity | anon | 2011/01/21 07:51 PM |
TRIM vs. GC for SSD Longevity | Aaron Spink | 2011/01/20 08:42 PM |
TRIM vs. GC for SSD Longevity | MS | 2011/01/21 06:07 PM |
Quad pixel? | Anon | 2011/01/19 10:48 PM |
Quad pixel? | mpx | 2011/01/20 08:40 AM |
The ARM story: Earthquake looming? | Rob Thorpe | 2011/01/19 01:57 PM |
The ARM story: Earthquake looming? | Brett | 2011/01/19 03:35 PM |
The ARM story: Earthquake looming? | Aaron Spink | 2011/01/19 08:30 PM |
Apollo Computer | Brett | 2011/01/19 09:52 PM |
iPad 2 display same as iPad | David Kanter | 2011/02/02 11:12 AM |
iPad 2 display same as iPad | Brett | 2011/02/02 01:30 PM |
iPad 2 display same as iPad | Mark Roulo | 2011/02/02 02:25 PM |
iPad 2 display same as iPad | Brett | 2011/02/02 02:59 PM |
iPad 2 display same as iPad | Richard Cownie | 2011/02/03 10:30 AM |
iPad 2 display same as iPad | Anon | 2011/02/02 04:08 PM |
iPad 2 display same as iPad | Rob Thorpe | 2011/02/03 11:42 AM |
The ARM story: Earthquake looming? | Ungo | 2011/01/19 05:54 AM |
The ARM story: Earthquake looming? | mpx | 2011/01/15 01:32 PM |
The ARM story: Earthquake looming? | Aaron Spink | 2011/01/17 04:20 PM |
The ARM story: Earthquake looming? | slacker | 2011/01/15 04:03 PM |
Intel GMs for low-end | David Kanter | 2011/01/18 11:05 AM |
The ARM story: Earthquake looming? | Linus Torvalds | 2011/01/14 09:29 AM |
The ARM story: Earthquake looming? | a reader | 2011/01/14 07:25 PM |
The ARM story: Earthquake looming? | Foo_ | 2011/01/15 03:12 AM |
The ARM story: Earthquake looming? | Matt Sayler | 2011/01/15 12:25 PM |
The ARM story: Earthquake looming? | IntelUser2000 | 2011/01/16 05:20 PM |
The ARM story: Earthquake looming? | Matt Sayler | 2011/01/16 06:02 PM |
The ARM story: Earthquake looming? | Megol | 2011/01/17 10:18 AM |
The ARM story: Earthquake looming? | Brett | 2011/01/17 04:58 PM |
The ARM story: Earthquake looming? | Louis Gerbarg | 2011/01/17 06:12 PM |
The ARM story: Earthquake looming? | Brett | 2011/01/17 08:06 PM |
The ARM story: Earthquake looming? | Louis Gerbarg | 2011/01/18 10:13 AM |
The ARM story: Earthquake looming? | Rob Thorpe | 2011/01/18 03:23 PM |
Nice post | David Kanter | 2011/01/18 11:38 AM |
New MacBook Pros are getting closer | Matt Sayler | 2011/02/24 09:46 AM |
The ARM story: Earthquake looming? | ? | 2011/01/16 09:29 AM |
The ARM story: Earthquake looming? | anon | 2011/01/16 10:08 PM |
The ARM story: Earthquake looming? | Gabriele Svelto | 2011/01/17 12:43 AM |
The ARM story: Earthquake looming? | Robert Myers | 2011/01/14 06:29 PM |
The ARM story: Earthquake looming? | Max | 2011/01/15 07:18 AM |
The ARM story: Earthquake looming? | Groo | 2011/01/12 04:59 PM |
The ARM story: Earthquake looming? | Wilco | 2011/01/12 05:40 PM |
The ARM story: Earthquake looming? | Groo | 2011/01/12 09:14 PM |
The ARM story: Earthquake looming? | Adrian | 2011/01/13 02:35 PM |
The ARM story: Earthquake looming? | Paul | 2011/01/13 05:19 PM |
The ARM story: Earthquake looming? | Adrian | 2011/01/14 03:50 AM |
The ARM story: Earthquake looming? | Wilco | 2011/01/14 07:00 AM |
The ARM story: Earthquake looming? | none | 2011/01/14 07:26 AM |
The ARM story: Earthquake looming? | Wilco | 2011/01/14 07:46 AM |
The ARM story: Earthquake looming? | none | 2011/01/14 08:02 AM |
The ARM story: Earthquake looming? | Linus Torvalds | 2011/01/14 09:42 AM |
The ARM story: Earthquake looming? | Richard Cownie | 2011/01/14 10:06 AM |
The ARM story: Earthquake looming? | someone | 2011/01/14 11:20 AM |
The ARM story: Earthquake looming? | fastpathguru | 2011/01/14 12:22 PM |
The ARM story: Earthquake looming? | Richard Cownie | 2011/01/14 06:01 PM |
The ARM story: Earthquake looming? | Aaron Spink | 2011/01/15 06:07 AM |
The ARM story: Earthquake looming? | slacker | 2011/01/15 04:08 PM |
The ARM story: Earthquake looming? | Jukka Larja | 2011/01/16 01:44 AM |
The ARM story: Earthquake looming? | mpx | 2011/01/15 05:08 AM |
The ARM story: Earthquake looming? | Paul | 2011/01/15 09:20 AM |
The ARM story: 64 bit or bust? | Kevin G | 2011/01/14 05:21 PM |
The ARM story: 64 bit or bust? | someone | 2011/01/15 10:48 AM |
Bye, bye native binary | mpx | 2011/01/15 12:51 AM |
Bye, bye native binary | Exophase | 2011/01/18 06:39 PM |
RISC with 16 GPRs!? | anon | 2011/01/19 05:42 PM |
RISC with 16 GPRs!? | Exophase | 2011/01/19 06:20 PM |
doomed ARM sells 6B cores/year | Richard Cownie | 2011/01/19 10:01 PM |
The ARM story: Earthquake looming? | anon | 2011/01/12 10:30 PM |
The ARM story: Earthquake looming? | mpx | 2011/01/13 04:05 AM |
Not a chance in hell | Rohit | 2011/01/12 07:49 AM |
The ARM story: Earthquake looming? | notsure | 2011/01/12 12:39 PM |
The ARM story: Earthquake looming? | mpx | 2011/01/13 04:27 AM |
The _Android_ story: Earthquake looming? | fastpathguru | 2011/01/13 11:50 AM |
Internet + web apps + multimedia = enabler | mpx | 2011/01/14 02:11 AM |
The _Android_ story: Earthquake looming? | Will Smith | 2011/01/14 09:48 AM |
Notebook vendors show no interest in Oak Trail | Nicki Minaj | 2011/01/16 06:37 PM |
