Article: Cooling and performance/watt
Article: What Do Overclockers and Supercomputers Have in Common?
By: Robert Pearson (r.pearson.delete@this.ieee.org), July 26, 2021 9:45 am
David Kanter (dkanter.delete@this.realworldtech.com) on June 21, 2011 12:19 pm wrote:
> After a brief hiatus due to travel for conferences and other matters, we
> are returning to our regularly scheduled reading with a new article.
> Enthusiasts and engineers know cooling is vital; it raises frequency and dramatically lowers power by reducing
> CPU or GPU temperatures. The world’s fastest supercomputer shows that thermal management can increase
> CPU performance/watt by 20% and 3D integration will make cooling more critical in the future.
> http://www.realworldtech.com/page.cfm?ArticleID=RWT062011114950
> As always, comments, discussion and feedback are encouraged.
> David
One assumption here is that "logic" means "CMOS". An inherent flaw in CMOS is the once-per-cycle transient short from Vcc to ground (the N-channel FET turn on faster than the P-channel FET can turn off). The more clock cycles per second then the more shorts and the higher power dissipation.
One way to avoid this problem is to use a different technology such as I²L or tunnel diodes. I worked with tunnel diodes in 1968 at 0.5GHz. One problem was that none of the test equipment worked at those speeds. In 1984 General Electric was selling 70GHz tunnel diode logic. In 2021 researchers are working at 100GHz to 2THz. This looks very promising. Especially since the speed * power product is 100,000 times that of CMOS. That means 1000 times the performance at 1% of the power.
I saw the engineers struggle to go from TTL to CMOS. At TI most engineers could not make the transition from TTL to I²L. (A transistor with multiple emitters is NATURAL and a transistor with multiple collectors is UNNATURAL). (Don't tell them about ULMs.)
Once a major manufacturer actually tries tunnel diode logic, all the questions about the problems with CMOS will just go away. It may take a couple of decades for engineers to think in threshold logic (or another generation). Neural networks will help. The "perceptrons" are just threshold gates.
Robert Pearson
< Previous Post in Thread
Article: Cooling and performance/wattDavid Kanter2011/06/21 12:19 PM
  'temperature' not 'power'?Paul A. Clayton2011/06/21 03:01 PM
    'temperature' not 'power'?David Kanter2011/06/21 03:38 PM
  resistance(temperature)Moritz2011/06/22 04:48 AM
    resistance(temperature)Adrian2011/06/22 05:13 AM
      resistance(temperature)David Hess2011/06/22 08:53 AM
        resistance(temperature)Adrian2011/06/24 02:24 AM
          resistance(temperature)David Hess2011/06/24 02:14 PM
  Article: Cooling and performance/wattEd Trice2011/06/22 10:57 AM
    CoolingDavid Kanter2011/06/22 03:26 PM
      CoolingEd Trice2011/06/22 03:54 PM
      TE-elementsMoritz2011/06/23 05:55 AM
        Radiator placement and designRicardo B2011/06/23 07:34 AM
        TE-elementsEduardoS2011/06/23 04:21 PM
          water/airMoritz2011/06/23 10:30 PM
            water/airRicardo B2011/06/24 02:29 PM
              water/airbakaneko2011/06/24 09:45 PM
                water/airDavid Hess2011/06/25 04:12 AM
                water/airRicardo B2011/06/25 06:07 AM
                  water/airZaZa2011/06/25 09:47 AM
                    water/airRicardo B2011/06/25 11:40 AM
                      water/airrwessel2011/06/26 03:43 AM
                      water/airZaZa2011/06/26 04:05 PM
  Temperature inversionJonathan Kang2011/06/22 05:43 PM
    LN2 overclockingDoug Siebert2011/06/25 01:32 PM
    Temperature inversionVincent Diepeveen2011/06/27 01:01 PM
    Temperature inversionAnon2011/06/28 03:30 PM
      Temperature inversionJonathan Kang2011/07/05 06:38 PM
  Article: Cooling and performance/watt(tm)2011/06/27 05:51 AM
  Article: Cooling and performance/wattDavid2011/10/15 06:14 PM
    Article: Cooling and performance/wattrwessel2011/10/15 09:56 PM
  Exponential growth of subthreshold leakageKonrad Schwarz2011/12/15 07:56 AM
    Exponential growth of subthreshold leakageRohit2011/12/15 01:22 PM
      Exponential growth of subthreshold leakageDavid Kanter2011/12/15 04:20 PM
        Exponential growth of subthreshold leakageIain McClatchie2013/01/07 12:28 AM
          Exponential growth of subthreshold leakageDoug S2013/01/07 10:25 AM
          Exponential growth of subthreshold leakagesomeone2013/01/07 11:12 PM
  Article: Cooling and performance/wattRobert Pearson2021/07/26 09:45 AM
How do you spell tangerine? 🍊
