Article: Knights Landing Details
By: Nicolas Capens (nicolas.capens.delete@this.gmail.com), January 11, 2014 8:45 pm
Gabriele Svelto (gabriele.svelto.delete@this.gmail.com) on January 11, 2014 4:08 am wrote:
> Nicolas Capens (nicolas.capens.delete@this.gmail.com) on January 10, 2014 11:27 am wrote:
> > There is no address being computed. But I can agree on calling
> > it a form of virtual indexing (VI) if you want.
> > But since VIPT caches are high performance, it's really about
> > the tagging, not the indexing. What you and David
> > appear to be confused about is that this isn't a virtually
> > tagged cache. There are no tags. The L0 would not
> > contain any data that isn't in L1. The symbolic encoding of
> > the address is only used for lookup, not for validation.
> On the one hand you mention that this would be done 'just as the LSU does' and on the other hand
> you come up with tracking the contents of this cache only via instruction decoding, now let me ask
> you: how would you do that across predicted branches? Interrupts? Exceptions? Multi-threading? Every
> write to a register could invalidate your tags and if you generate them during decoding you need
> first to bolt some of this logic to the decoders which already sounds crazy enough to me but then
> you also need to keep track of whatever tags you generate in the ROB. You can't seriously think this
> is simple. If this was done 'like the LSU' then you'd be using addresses and the logic would be limited
> to within the LSU; what you're suggesting requires modifications all over the core.
The decoder isn't involved at all. When a memory operand is needed, the encoding for it (the SIB byte and its extension bits) is sent to the LSU, which for an L1 access then reads the registers used by that symbolic address and computes the virtual address out of the contents of those registers. Then that virtual address is used for the actual L1 lookup, and it's also translated into a physical address along the way. Instead for the L0 cache I'm describing, there would be no translation from the symbolic address to the virtual address. The symbolic address is used to tag previously loaded data.
Clearly the LSU readily has access to this symbolic address. Where you might be confused is that in many architectures the LSU doesn't take the symbolic address directly, but instead gets the virtual address from an AGU.
So I hope this clears up for you that the instruction decoders are not involved at all, and branching doesn't affect it either. You just skip the virtual address calculation and go straight to the L0 cache to check if you've loaded that data before recently. If not, it becomes a regular L1 access. You may also start the L1 access in parallel and abort it on an L0 hit.
Topic | Posted By | Date |
Knights Landing details (new article) | David Kanter | 2014/01/02 11:58 PM |
eDRAM as cache | iz | 2014/01/03 03:39 AM |
eDRAM options | Eric Bron | 2014/01/09 02:45 AM |
Knights Landing details (new article) | Emil Briggs | 2014/01/03 05:06 AM |
Knights Landing details (new article) | Michael S | 2014/01/03 06:05 AM |
PCI-E and QPI | David Kanter | 2014/01/03 11:11 AM |
eDRAM still seems too expensive ... | Mark Roulo | 2014/01/03 09:48 AM |
Nevermind ... I see that you addressed this :-) | Mark Roulo | 2014/01/03 09:51 AM |
eDRAM still seems too expensive ... | Eric Bron | 2014/01/03 12:42 PM |
eDRAM or stacked DRAM? | Patrick Chase | 2014/01/03 10:21 AM |
eDRAM or stacked DRAM? | Wes Felter | 2014/01/03 02:00 PM |
eDRAM or stacked DRAM? | Patrick Chase | 2014/01/03 06:26 PM |
eDRAM or stacked DRAM? | tarlinian | 2014/06/23 08:59 PM |
eDRAM or stacked DRAM? | Maynard Handley | 2014/06/24 12:47 AM |
eDRAM or stacked DRAM? | Michael S | 2014/06/24 02:13 AM |
eDRAM or stacked DRAM? | David Kanter | 2014/06/24 11:09 AM |
eDRAM or stacked DRAM? | anon | 2014/06/24 06:50 PM |
eDRAM or stacked DRAM? | Eric Bron | 2014/06/24 09:02 PM |
eDRAM or stacked DRAM? | anon | 2014/06/24 09:39 PM |
eDRAM or stacked DRAM? | Michael S | 2014/06/25 12:46 AM |
eDRAM or stacked DRAM? | Michael S | 2014/06/25 12:29 AM |
eDRAM or stacked DRAM? | Eric Bron | 2014/06/24 04:37 AM |
eDRAM or stacked DRAM? | tarlinian | 2014/06/24 07:53 AM |
eDRAM or stacked DRAM? | Eric Bron | 2014/06/24 08:09 AM |
eDRAM or stacked DRAM? | tarlinian | 2014/06/24 08:40 AM |
eDRAM or stacked DRAM? | Eric Bron | 2014/06/24 09:10 AM |
eDRAM or stacked DRAM? | Eric Bron | 2014/06/24 09:12 AM |
eDRAM or stacked DRAM? | Wes Felter | 2014/06/24 09:09 PM |
eDRAM or stacked DRAM? | Michael S | 2014/06/25 01:02 AM |
Why not tag-inclusive L3? | Paul A. Clayton | 2014/01/03 03:28 PM |
Why not tag-inclusive L3? | Eric Bron | 2014/01/04 02:22 AM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/04 04:43 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/04 05:20 AM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/04 01:55 PM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/04 02:27 PM |
Knights Landing L/S bandwidth | hobold | 2014/01/04 03:23 PM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/04 04:20 PM |
Knights Landing L/S bandwidth | Michael S | 2014/01/05 02:42 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/05 02:49 AM |
Knights Landing L/S bandwidth | Patrick Chase | 2014/01/11 07:13 PM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/13 07:39 PM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/05 02:18 PM |
Knights Landing L/S bandwidth | Michael S | 2014/01/06 03:09 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/06 04:11 AM |
Knights Landing L/S bandwidth | Michael S | 2014/01/06 04:40 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/06 04:54 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/08 08:00 AM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/07 02:31 PM |
Knights Landing L/S bandwidth | Michael S | 2014/01/07 03:17 PM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/07 08:55 PM |
Knights Landing L/S bandwidth | Michael S | 2014/01/08 12:42 AM |
Knights Landing L/S bandwidth | Gabriele Svelto | 2014/01/08 07:30 AM |
Occam's razor | Nicolas Capens | 2014/01/08 01:33 PM |
Occam's razor | Gabriele Svelto | 2014/01/08 01:51 PM |
Occam's razor | Eric Bron | 2014/01/08 02:28 PM |
Occam's razor | bakaneko | 2014/01/09 03:45 AM |
Occam's razor | anon | 2014/01/09 04:02 AM |
Occam's razor | bakaneko | 2014/01/09 05:24 AM |
Occam's razor | bakaneko | 2014/01/09 05:51 AM |
Occam's razor | anon | 2014/01/09 06:18 AM |
Occam's razor | anon | 2014/01/09 06:16 AM |
Occam's razor | bakaneko | 2014/01/09 07:43 AM |
Occam's razor | anon | 2014/01/09 08:17 AM |
Occam's razor | bakaneko | 2014/01/09 10:12 AM |
Occam's razor | Eric Bron | 2014/01/09 10:18 AM |
Occam's razor | bakaneko | 2014/01/09 10:58 AM |
Occam's razor | anon | 2014/01/09 11:35 AM |
Occam's razor | bakaneko | 2014/01/12 09:48 AM |
99.9% not a new extension | Nicolas Capens | 2014/01/10 10:39 AM |
Compiler complexity | Gabriele Svelto | 2014/01/11 02:58 AM |
Compiler complexity | Nicolas Capens | 2014/01/11 12:20 PM |
Compiler complexity | Gabriele Svelto | 2014/01/11 02:17 PM |
Patent pending | Nicolas Capens | 2014/01/14 06:21 PM |
99.9% not a new extension | bakaneko | 2014/01/12 10:08 AM |
L0 data cache | Eric Bron | 2014/01/08 03:52 PM |
Occam's razor | David Kanter | 2014/01/08 03:53 PM |
Occam's razor | Nicolas Capens | 2014/01/09 02:07 AM |
Occam's razor | Ricardo B | 2014/01/09 04:21 AM |
Virtually indexed, untagged | Nicolas Capens | 2014/01/10 10:27 AM |
Virtually indexed, untagged | Gabriele Svelto | 2014/01/11 03:08 AM |
Virtually indexed, untagged | Nicolas Capens | 2014/01/11 08:45 PM |
Virtually indexed, untagged | David Kanter | 2014/01/12 01:13 AM |
Virtually indexed, untagged | anon | 2014/01/12 03:02 AM |
Virtually indexed, untagged | Nicolas Capens | 2014/01/16 08:55 AM |
Virtually indexed, untagged | Michael S | 2014/01/12 03:09 AM |
Virtually indexed, untagged | Nicolas Capens | 2014/01/16 09:47 AM |
Occam's razor | David Kanter | 2014/01/09 05:42 PM |
Occam's razor | Nicolas Capens | 2014/01/10 01:22 PM |
Occam's razor | David Kanter | 2014/01/10 03:06 PM |
MEM : ALU ratio | Nicolas Capens | 2014/01/10 11:24 PM |
MEM : ALU ratio | Gabriele Svelto | 2014/01/11 02:47 AM |
MEM : ALU ratio | Eric Bron | 2014/01/11 03:41 AM |
MEM : ALU ratio | Eric Bron | 2014/01/11 04:06 AM |
MEM : ALU ratio | David Kanter | 2014/01/11 07:28 PM |
MEM : ALU ratio | Eric Bron nli | 2014/01/12 01:54 AM |
MEM : ALU ratio | Gabriele Svelto | 2014/01/11 09:15 AM |
MEM : ALU ratio | Nicolas Capens | 2014/01/14 05:56 PM |
Etiquette in linking to papers | Paul A. Clayton | 2014/01/14 06:44 PM |
MEM : ALU ratio | anon | 2014/01/14 07:32 PM |
L0 power cost | Nicolas Capens | 2014/01/16 01:05 PM |
L0 power cost | anon | 2014/01/16 09:01 PM |
L0 power cost | Nicolas Capens | 2014/01/18 11:30 PM |
Links revealed | Paul A. Clayton | 2014/01/19 03:47 PM |
L0 power cost | anon | 2014/01/20 12:19 AM |
L0 power cost | Nicolas Capens | 2014/01/20 01:49 PM |
L0 power cost | anon | 2014/01/21 12:18 AM |
Q.E.D. | Nicolas Capens | 2014/01/21 07:44 PM |
Q.E.D. | anon | 2014/01/21 08:24 PM |
Straw man | Nicolas Capens | 2014/01/23 10:56 PM |
Straw man | anon | 2014/01/25 05:46 AM |
Still waiting for an explanation | Nicolas Capens | 2014/01/25 11:19 PM |
Still waiting for an explanation | Exophase | 2014/01/26 12:13 PM |
Still waiting for an explanation | bakaneko | 2014/01/26 10:52 PM |
Q.E.D. | Ricardo B | 2014/01/22 05:58 PM |
Q.E.D. | Michael S | 2014/01/23 03:59 AM |
L0 entry count | Nicolas Capens | 2014/01/24 12:11 AM |
L0 entry count | Eric Bron | 2014/01/24 01:08 AM |
L0 entry count | Michael S | 2014/01/24 05:18 AM |
L0 entry count | Eric Bron | 2014/01/24 06:15 AM |
L0 entry count | Michael S | 2014/01/24 07:10 AM |
L0 entry count | Eric Bron | 2014/01/24 07:20 AM |
L0 entry count | Nicolas Capens | 2014/01/24 01:33 PM |
L0 entry count | Eric Bron | 2014/01/24 02:20 PM |
L0 entry count and L1 read port orthogonality | Nicolas Capens | 2014/01/26 12:14 AM |
L0 entry count and L1 read port orthogonality | Eric Bron | 2014/01/26 02:49 AM |
L0 hit rate | Nicolas Capens | 2014/01/23 11:49 PM |
L0 hit rate | Ricardo B | 2014/01/24 05:42 AM |
L0 hit rate | Exophase | 2014/01/24 12:37 PM |
L0 hit rate | Eric Bron | 2014/01/24 01:12 PM |
L0 vs RF power | Nicolas Capens | 2014/01/24 01:43 PM |
MEM : ALU ratio | David Kanter | 2014/01/11 12:47 PM |
MEM : ALU ratio | Nicolas Capens | 2014/01/16 08:23 AM |
MEM : ALU ratio | Stubabe | 2014/01/17 11:58 AM |
MEM : ALU ratio | Stubabe | 2014/01/17 12:42 PM |
MEM : ALU ratio | Michael S | 2014/01/18 03:57 PM |
MEM : ALU ratio | bakaneko | 2014/01/18 11:47 PM |
MEM : ALU ratio | Nicolas Capens | 2014/01/20 02:48 PM |
It's called "tunnel vision" (NT) | iz | 2014/01/20 03:36 PM |
MEM : ALU ratio | Michael S | 2014/01/20 03:37 PM |
MEM : ALU ratio | Stubabe | 2014/01/21 03:54 PM |
MEM : ALU ratio | Nicolas Capens | 2014/01/21 09:07 PM |
MEM : ALU ratio | Michael S | 2014/01/22 07:17 AM |
MEM : ALU ratio | Nicolas Capens | 2014/01/24 02:33 PM |
MEM : ALU ratio | Stubabe | 2014/01/21 03:32 PM |
MEM : ALU ratio | Michael S | 2014/01/22 07:56 AM |
MEM : ALU ratio | Stubabe | 2014/01/23 08:06 AM |
MEM : ALU ratio | Eric Bron | 2014/01/23 08:45 AM |
edit | Eric Bron | 2014/01/23 08:49 AM |
MEM : ALU ratio | Michael S | 2014/01/23 08:58 AM |
MEM : ALU ratio | Eric Bron | 2014/01/23 09:29 AM |
MEM : ALU ratio | Michael S | 2014/01/23 09:33 AM |
MEM : ALU ratio | Stubabe | 2014/01/24 03:50 AM |
MEM : ALU ratio | bakaneko | 2014/01/23 09:36 AM |
MEM : ALU ratio | NoSpammer | 2014/01/11 02:39 PM |
L1 vs L0 access cost | Nicolas Capens | 2014/01/16 02:17 PM |
L1 vs L0 access cost | NoSpammer | 2014/01/19 12:48 PM |
L1 vs L0 access cost | dmcq | 2014/01/22 04:45 AM |
L1 vs L0 access cost | Gabriele Svelto | 2014/01/22 06:29 AM |
L1 vs L0 access cost | dmcq | 2014/01/22 12:33 PM |
L1 vs L0 access cost | Gabriele Svelto | 2014/01/22 03:33 PM |
L1 vs L0 access cost | dmcq | 2014/01/24 03:19 AM |
L1 vs L0 access cost | Nicolas Capens | 2014/01/24 01:16 AM |
Occam's razor | Patrick Chase | 2014/01/13 10:19 AM |
Occam's razor | Nicolas Capens | 2014/01/08 11:40 PM |
Occam's razor | Gabriele Svelto | 2014/01/09 01:41 AM |
Occam's razor | Eric Bron | 2014/01/09 01:54 AM |
Occam's razor | Gabriele Svelto | 2014/01/09 05:35 AM |
Occam's razor | Eric Bron | 2014/01/09 06:14 AM |
avoiding redundant loads | Eric Bron | 2014/01/09 06:18 AM |
AVX2 version | Eric Bron | 2014/01/09 06:32 AM |
Occam's razor | Amiba Gelos | 2014/01/09 02:01 AM |
Occam's razor | Eric Bron | 2014/01/09 02:06 AM |
Occam's razor | Amiba Gelos | 2014/01/09 02:43 AM |
Occam's razor | Eric Bron | 2014/01/09 03:02 AM |
L0 access latency | Nicolas Capens | 2014/01/09 03:27 AM |
L0 access latency | Amiba Gelos | 2014/01/09 04:16 AM |
compared to L0$ i would say banking is far more likely (NT) | Amiba Gelos | 2014/01/09 04:20 AM |
L0 access latency | Nicolas Capens | 2014/01/10 02:20 PM |
Occam's razor | Nicolas Capens | 2014/01/09 03:19 AM |
Occam's razor | NoSpammer | 2014/01/09 11:55 AM |
Occam's razor | Nicolas Capens | 2014/01/10 02:40 PM |
Occam's razor | Michael S | 2014/01/11 09:21 AM |
Occam's razor | Michael S | 2014/01/12 02:21 PM |
KNC compiler output | Nicolas Capens | 2014/01/16 05:39 PM |
KNC compiler output | Michael S | 2014/01/18 04:13 PM |
L0 cache coherency | David Kanter | 2014/01/11 07:39 PM |
Occam's razor | anon | 2014/01/09 04:12 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/08 09:46 AM |
Knights Landing L/S bandwidth | Michael S | 2014/01/08 10:23 AM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/08 01:02 PM |
Knights Landing L/S bandwidth | Michael S | 2014/01/08 01:29 PM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/08 01:54 PM |
Knights Landing L/S bandwidth | Michael S | 2014/01/08 02:00 PM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/08 02:13 PM |
Knights Landing L/S bandwidth | Michael S | 2014/01/08 02:28 PM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/08 02:32 PM |
Knights Landing L/S bandwidth | Michael S | 2014/01/08 02:40 PM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/08 02:51 PM |
Knights Landing L/S bandwidth | Michael S | 2014/01/09 11:18 AM |
Knights Landing L/S bandwidth | Patrick Chase | 2014/01/12 09:03 PM |
Also page/line splits? | David Kanter | 2014/01/12 09:50 PM |
Also page/line splits? | anon | 2014/01/13 12:44 AM |
Also page/line splits? | none | 2014/01/13 02:09 AM |
Also page/line splits? | anon | 2014/01/13 03:19 AM |
Knights Landing L/S bandwidth | Exophase | 2014/01/12 11:15 PM |
Knights Landing L/S bandwidth | anon | 2014/01/13 12:41 AM |
Knights Landing L/S bandwidth | Patrick Chase | 2014/01/13 10:14 AM |
Aliased writes | Nicolas Capens | 2014/01/14 08:46 PM |
Knights Landing L/S bandwidth | Ricardo B | 2014/01/07 03:27 PM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/07 09:28 PM |
Knights Landing L/S bandwidth | Ricardo B | 2014/01/08 01:13 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/08 10:10 AM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/08 02:31 PM |
Knights Landing L/S bandwidth | Ricardo B | 2014/01/08 02:58 PM |
Knights Landing L/S bandwidth | G. Gouvine | 2014/01/09 08:10 AM |
Knights Landing L/S bandwidth | Ricardo B | 2014/01/09 10:19 AM |
Efficient load queue vs. efficient L0 cache | Nicolas Capens | 2014/01/11 11:28 AM |
Efficient load queue vs. efficient L0 cache | G. Gouvine | 2014/01/13 01:11 AM |
Efficient load queue vs. efficient L0 cache | Michael S | 2014/01/13 02:43 AM |
Register file read port requirements | Nicolas Capens | 2014/01/10 11:55 PM |
Register file read port requirements | Ricardo B | 2014/01/11 04:24 AM |
Register file read port requirements | Eric Bron | 2014/01/11 04:32 AM |
Register file read port requirements | Michael S | 2014/01/11 08:57 AM |
Register file read port requirements | Eric Bron | 2014/01/11 10:16 AM |
Register file read port requirements | Michael S | 2014/01/11 10:46 AM |
Register file read port requirements | Eric Bron | 2014/01/11 11:12 AM |
Register file read port requirements | Michael S | 2014/01/11 11:36 AM |
Register file read port requirements | Eric Bron | 2014/01/11 11:51 AM |
Register file read port requirements | Patrick Chase | 2014/01/13 01:27 PM |
Register file read port requirements | Eric Bron | 2014/01/13 03:24 PM |
Register file read port requirements | Patrick Chase | 2014/01/13 05:02 PM |
Register file read port requirements | Eric Bron | 2014/01/14 03:50 AM |
Register file read port requirements | Michael S | 2014/01/14 10:36 AM |
Register file read port requirements | Eric Bron nli | 2014/01/14 12:04 PM |
Register file read port requirements | Patrick Chase | 2014/01/13 01:17 PM |
Register file read port requirements | Michael S | 2014/01/15 03:27 AM |
Register file read port requirements | Eric Bron | 2014/01/11 10:28 AM |
Register file read port requirements | Michael S | 2014/01/11 11:07 AM |
Register file read port requirements | Patrick Chase | 2014/01/13 01:40 PM |
Register file read port requirements | Patrick Chase | 2014/01/13 01:34 PM |
Register file read port requirements | Ricardo B | 2014/01/11 11:55 AM |
Register file read port requirements | Eric Bron | 2014/01/11 12:17 PM |
Register file read port requirements | Ricardo B | 2014/01/11 01:36 PM |
Register file read port requirements | Eric Bron | 2014/01/11 01:42 PM |
Register file read port requirements | Ricardo B | 2014/01/11 02:20 PM |
Register file read port requirements | Eric Bron | 2014/01/11 02:26 PM |
Register file read port requirements | Michael S | 2014/01/11 03:07 PM |
Register file read port requirements | Ricardo B | 2014/01/11 03:38 PM |
Register file read port requirements | Michael S | 2014/01/11 03:49 PM |
Register file read port requirements | Eric Bron | 2014/01/11 02:39 PM |
Register file read port requirements | Eric Bron | 2014/01/11 02:41 PM |
Register file read port requirements | Ricardo B | 2014/01/11 03:30 PM |
Register file read port requirements | Nicolas Capens | 2014/01/11 11:09 AM |
Knights Landing L/S bandwidth | anon | 2014/01/05 05:55 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/05 06:30 AM |
Knights Landing L/S bandwidth | anon | 2014/01/06 12:07 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/06 01:38 AM |
Knights Landing L/S bandwidth | anon | 2014/01/06 03:01 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/06 03:44 AM |
Knights Landing L/S bandwidth | anon | 2014/01/06 04:39 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/06 05:00 AM |
Knights Landing L/S bandwidth | anon | 2014/01/06 05:44 AM |
Knights Landing L/S bandwidth | Michael S | 2014/01/06 07:54 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/06 09:11 AM |
Knights Landing L/S bandwidth | Michael S | 2014/01/06 09:14 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/06 10:37 AM |
Knights Landing L/S bandwidth | Ricardo B | 2014/01/08 05:25 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/08 07:36 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/08 07:41 AM |
KNC code generator with EVEX back-end? | Michael S | 2014/01/08 08:43 AM |
KNC code generator with EVEX back-end? | Exophase | 2014/01/08 09:00 AM |
KNC code generator with EVEX back-end? | Ricardo B | 2014/01/08 10:39 AM |
KNC code generator with EVEX back-end? | Eric Bron | 2014/01/08 11:15 AM |
KNC code generator with EVEX back-end? | Exophase | 2014/01/08 12:17 PM |
KNC code generator with EVEX back-end? | Ricardo B | 2014/01/08 01:06 PM |
KNC code generator with EVEX back-end? | Exophase | 2014/01/08 01:24 PM |
KNC code generator with EVEX back-end? | Eric Bron | 2014/01/08 01:38 PM |
KNC code generator with EVEX back-end? | Michael S | 2014/01/08 12:54 PM |
KNC code generator with EVEX back-end? | Eric Bron | 2014/01/08 09:25 AM |
KNC code generator with EVEX back-end? | Eric Bron | 2014/01/08 09:35 AM |
KNC code generator with EVEX back-end? | Michael S | 2014/01/08 10:07 AM |
KNC code generator with EVEX back-end? | Eric Bron | 2014/01/08 10:24 AM |
KNC code generator with EVEX back-end? | Michael S | 2014/01/08 10:43 AM |
KNC code generator with EVEX back-end? | Eric Bron | 2014/01/08 12:23 PM |
KNC code generator with EVEX back-end? | Eric Bron | 2014/01/08 09:43 AM |
AVX2 code much different than AVX-512 | Eric Bron | 2014/01/08 07:52 AM |
evil question | hobold | 2014/01/08 09:22 AM |
evil question | Eric Bron | 2014/01/08 09:27 AM |
evil question | hobold | 2014/01/08 01:33 PM |
evil question | Michael S | 2014/01/08 01:37 PM |
stupid question (was: evil question) | hobold | 2014/01/09 04:41 AM |
stupid question (was: evil question) | Eric Bron | 2014/01/09 04:52 AM |
stupid question (was: evil question) | Michael S | 2014/01/09 07:00 AM |
stupid question (was: evil question) | Michael S | 2014/01/09 07:12 AM |
stupid question (was: evil question) | Eric Bron | 2014/01/09 09:47 AM |
stupid question (was: evil question) | Michael S | 2014/01/09 10:48 AM |
more decisive (hopefully) test case | Michael S | 2014/01/09 11:01 AM |
more decisive (hopefully) test case | Eric Bron | 2014/01/09 11:08 AM |
more decisive (hopefully) test case | Michael S | 2014/01/09 11:24 AM |
more decisive (hopefully) test case | Eric Bron | 2014/01/09 11:27 AM |
more decisive (hopefully) test case | Michael S | 2014/01/09 11:33 AM |
AVX2 | Eric Bron | 2014/01/09 11:14 AM |
AVX2 | Michael S | 2014/01/09 11:30 AM |
AVX2 | Eric Bron | 2014/01/09 11:40 AM |
another try | Michael S | 2014/01/09 02:02 PM |
another try | Eric Bron | 2014/01/09 02:33 PM |
another try | Michael S | 2014/01/09 03:20 PM |
another try - ignore misformated mess above | Michael S | 2014/01/09 03:24 PM |
another try - ignore misformated mess above | Gabriele Svelto | 2014/01/10 12:01 AM |
another try - ignore misformated mess above | Eric Bron | 2014/01/10 02:05 AM |
another try - ignore misformated mess above | Michael S | 2014/01/11 09:23 AM |
another try - ignore misformated mess above | Eric Bron | 2014/01/11 10:08 AM |
another try - ignore misformated mess above | Michael S | 2014/01/11 11:09 AM |
another try - ignore misformated mess above | Michael S | 2014/01/11 11:12 AM |
another try - ignore misformated mess above | Eric Bron | 2014/01/11 11:24 AM |
another try - ignore misformated mess above | Michael S | 2014/01/11 12:24 PM |
another try - ignore misformated mess above | Eric Bron | 2014/01/11 01:11 PM |
another try - ignore misformated mess above | Michael S | 2014/01/11 01:18 PM |
another try - ignore misformated mess above | Eric Bron | 2014/01/11 01:27 PM |
another try - ignore misformated mess above | Michael S | 2014/01/11 01:29 PM |
another try - ignore misformated mess above | Eric Bron | 2014/01/11 01:46 PM |
another try - ignore misformated mess above | Michael S | 2014/01/11 02:28 PM |
another try - ignore misformated mess above | Eric Bron | 2014/01/11 01:17 PM |
another try - ignore misformated mess above | Michael S | 2014/01/11 01:24 PM |
KNC version | Michael S | 2014/01/11 04:19 PM |
KNC version | Eric Bron nli | 2014/01/12 01:59 AM |
KNC version | Gabriele Svelto | 2014/01/12 08:06 AM |
evil question | Eric Bron | 2014/01/08 01:41 PM |
Knights Landing L/S bandwidth | Patrick Chase | 2014/01/05 10:20 PM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/06 01:45 AM |
Knights Landing L/S bandwidth | anon | 2014/01/06 03:12 AM |
Knights Landing L/S bandwidth | Michael S | 2014/01/06 03:17 AM |
Knights Landing L/S bandwidth | anon | 2014/01/06 04:20 AM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/04 04:34 PM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/04 04:44 PM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/05 11:25 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/05 12:50 PM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/05 02:34 PM |
Might even help with gather | Nicolas Capens | 2014/01/05 02:40 PM |
What is an L0 cache? | David Kanter | 2014/01/05 09:44 PM |
What is an L0 cache? | anon | 2014/01/06 04:57 AM |
What is an L0 cache? | Nicolas Capens | 2014/01/06 11:57 AM |
What is an L0 cache? | anon | 2014/01/06 01:18 PM |
Knights Landing L/S bandwidth | David Kanter | 2014/01/04 09:58 AM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/04 03:24 PM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/04 03:46 PM |
Knights Landing L/S bandwidth | Konrad Schwarz | 2014/01/07 11:48 PM |
Knights Landing L/S bandwidth | Michael S | 2014/01/08 01:45 AM |
Knights Landing L/S bandwidth | David Kanter | 2014/01/05 12:44 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/05 02:55 AM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/05 11:18 AM |
Knights Landing L/S bandwidth | Maynard Handley | 2014/01/05 10:33 PM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/06 03:02 AM |
Knights Landing L/S bandwidth | Michael S | 2014/01/06 03:23 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/06 03:35 AM |
Knights Landing L/S bandwidth | Michael S | 2014/01/06 04:20 AM |
Knights Landing L/S bandwidth | Michael S | 2014/01/06 04:32 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/06 04:36 AM |
Knights Landing L/S bandwidth | Michael S | 2014/01/06 05:00 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/06 05:07 AM |
Knights Landing L/S bandwidth | Eric Bron | 2014/01/06 05:14 AM |
edits | Eric Bron | 2014/01/06 05:22 AM |
optimized version | Eric Bron | 2014/01/06 05:35 AM |
yet more optimized version | Eric Bron | 2014/01/06 05:42 AM |
latest version for today | Eric Bron | 2014/01/06 05:51 AM |
Probably just L2 bandwith limited | Nicolas Capens | 2014/01/06 10:48 AM |
yet more optimized version | Maynard Handley | 2014/01/06 05:54 PM |
optimized version | Maynard Handley | 2014/01/06 05:52 PM |
optimized version | Michael S | 2014/01/07 09:42 AM |
optimized version | Nicolas Capens | 2014/01/07 11:36 AM |
optimized version | Michael S | 2014/01/07 02:41 PM |
optimized version | Nicolas Capens | 2014/01/07 09:52 PM |
optimized version | Michael S | 2014/01/08 01:10 AM |
optimized version | Eric Bron | 2014/01/07 01:34 PM |
optimized version | Michael S | 2014/01/07 02:18 PM |
optimized version | Eric Bron | 2014/01/07 02:30 PM |
optimized version | Eric Bron | 2014/01/07 02:33 PM |
optimized version | Michael S | 2014/01/07 02:57 PM |
optimized version | Maynard Handley | 2014/01/07 05:50 PM |
optimized version | Michael S | 2014/01/08 01:39 AM |
Knights Landing L/S bandwidth | Maynard Handley | 2014/01/06 05:47 PM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/06 08:18 AM |
Knights Landing L/S bandwidth | Maynard Handley | 2014/01/06 05:56 PM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/07 11:18 AM |
Knights Landing L/S bandwidth | NoSpammer | 2014/01/05 12:15 PM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/05 02:06 PM |
Knights Landing L/S bandwidth | NoSpammer | 2014/01/06 03:20 AM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/06 10:54 AM |
Knights Landing L/S bandwidth | NoSpammer | 2014/01/06 12:24 PM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/06 08:15 PM |
Knights Landing L/S bandwidth | NoSpammer | 2014/01/07 02:58 AM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/07 02:18 PM |
Knights Landing L/S bandwidth | NoSpammer | 2014/01/08 12:38 PM |
Knights Landing L/S bandwidth | Nicolas Capens | 2014/01/08 10:14 PM |
AVX512F question | Michael S | 2014/01/06 09:18 AM |
AVX512F question | Nicolas Capens | 2014/01/06 11:01 AM |
Knights Landing - time for obituary? | Michael S | 2018/07/31 02:00 PM |
Knights Landing - time for obituary? | Adrian | 2018/07/31 08:24 PM |
Knights Landing - time for obituary? | SoftwareEngineer | 2018/08/01 01:15 AM |
auto-vectorization is a dead end | Michael S | 2018/08/01 02:48 AM |
Auto-vectorization of random C is a dead end | Mark Roulo | 2018/08/01 10:07 AM |
Auto-vectorization of random C is a dead end | Passing Through | 2018/08/01 12:35 PM |
Auto-vectorization of random C is a dead end | David Kanter | 2018/08/01 09:44 PM |
Auto-vectorization of random C is a dead end | Passing Through | 2018/08/02 12:51 AM |
Auto-vectorization of random C is a dead end | SoftwareEngineer | 2018/08/02 12:19 AM |
Auto-vectorization of random C is a dead end | Mark Roulo | 2018/08/02 08:50 AM |
Auto-vectorization of random C is a dead end | Michael S | 2018/08/02 11:11 AM |
Auto-vectorization of random C is a dead end | j | 2018/08/02 10:37 PM |
Auto-vectorization of random C is a dead end | Michael S | 2018/08/03 02:50 AM |
Auto-vectorization of random C is a dead end | rwessel | 2018/08/03 10:06 PM |
Auto-vectorization of random C is a dead end | Ricardo B | 2018/08/03 03:20 AM |
Auto-vectorization of random C is a dead end | Michael S | 2018/08/03 04:37 AM |
Auto-vectorization of random C is a dead end | Ricardo B | 2018/08/03 10:22 AM |
Auto-vectorization of random C is a dead end | Travis | 2018/08/03 06:58 PM |
Potential way to autovectorization in the future. | Jouni Osmala | 2018/08/03 09:22 PM |
Potential way to autovectorization in the future. | Jukka Larja | 2018/08/04 03:03 AM |
Potential way to autovectorization in the future. | Passing Through | 2018/08/04 05:47 AM |
Potential way to autovectorization in the future. | Travis | 2018/08/04 12:50 PM |
Potential way to autovectorization in the future. | Michael S | 2018/08/04 01:33 PM |
Potential way to autovectorization in the future. | Travis | 2018/08/04 01:48 PM |
Potential way to autovectorization in the future. | Passing Through | 2018/08/04 01:58 PM |
Skylake server/client AVX PRF speculation | Jeff S. | 2018/08/04 04:42 PM |
Skylake server/client AVX PRF speculation | anonymou5 | 2018/08/04 05:21 PM |
Skylake server/client AVX PRF speculation | Jeff S. | 2018/08/04 05:38 PM |
Skylake server/client AVX PRF speculation | anonymou5 | 2018/08/04 06:45 PM |
Skylake server/client AVX PRF speculation | Jeff S. | 2018/08/04 07:08 PM |
Skylake server/client AVX PRF speculation | anonymou5 | 2018/08/04 07:18 PM |
Skylake server/client AVX PRF speculation | Nomad | 2018/08/05 10:10 PM |
Skylake server/client AVX PRF speculation | anonymou5 | 2018/08/06 11:14 AM |
Skylake server/client AVX PRF speculation | Travis | 2018/08/06 07:43 PM |
Skylake server/client AVX PRF speculation | Travis | 2018/08/06 07:39 PM |
Auto-vectorization of random C is a dead end | Brett | 2018/08/04 12:55 PM |
Auto-vectorization of random C is a dead end | Travis | 2018/08/04 01:38 PM |
Auto-vectorization of random C is a dead end | Passing Through | 2018/08/04 02:00 PM |
New record for shortest post by Ireland - AI crashed? (NT) | Travis | 2018/08/04 02:34 PM |
New record for shortest post by Ireland - AI crashed? | Passing Through | 2018/08/04 03:12 PM |
New record for shortest post by Ireland - AI crashed? | anonymou5 | 2018/08/04 05:00 PM |
New record for shortest post by Ireland - AI crashed? | Brett | 2018/08/04 05:40 PM |
New record for shortest post by Ireland - AI crashed? | anonymou5 | 2018/08/04 06:38 PM |
Auto-vectorization of random C is a dead end | noko | 2018/08/04 08:46 PM |
The story of ispc (a 12 entry blog series) | Simon Farnsworth | 2018/08/01 02:50 AM |
the 1st link is empty (NT) | Michael S | 2018/08/01 03:05 AM |
the 1st link is empty | Simon Farnsworth | 2018/08/01 05:42 AM |
Interesting read, thanks! (NT) | SoftwareEngineer | 2018/08/01 05:57 AM |
Amazing read | Laurent | 2018/08/01 08:00 AM |
Amazing read | Passing Through | 2018/08/01 12:13 PM |
Amazing read | Doug S | 2018/08/01 01:30 PM |
Amazing read | Passing Through | 2018/08/01 01:49 PM |
ISPC vs OpenCL? | j | 2018/08/02 10:41 PM |
ISPC vs OpenCL? | coppcie | 2018/08/03 02:55 AM |
ISPC vs OpenCL? | Passing Through | 2018/08/03 03:07 AM |
Go away | Forum Reader | 2018/08/03 07:11 AM |
ISPC vs OpenCL? | Gian-Carlo Pascutto | 2018/09/11 05:50 AM |
ISPC vs OpenCL? | SoftwareEngineer | 2018/08/03 03:18 AM |
Knights Landing - time for obituary? | Kevin G | 2018/08/01 06:14 AM |
Knights Landing - time for obituary? | SoftwareEngineer | 2018/08/01 06:29 AM |
Knights Landing - time for obituary? | Passing Through | 2018/08/01 06:38 AM |
Knights Landing - time for obituary? | Eric Bron | 2018/08/02 05:57 AM |
Knights Landing - time for obituary? | Passing Through | 2018/08/02 11:29 AM |
Knights Landing - time for obituary? | Eric Bron | 2018/08/02 12:49 PM |
Knights Landing - time for obituary? | Passing Through | 2018/08/02 01:17 PM |
chess algorithms vs, low level optimizations | Eric Bron | 2018/08/02 06:15 AM |
AlphaZero vs Stockfish | Michael S | 2018/08/02 06:55 AM |
AlphaZero vs Stockfish | Eric Bron | 2018/08/02 07:24 AM |
AlphaZero vs Stockfish | Michael S | 2018/08/02 08:01 AM |
AlphaZero vs Stockfish | Eric Bron | 2018/08/02 08:11 AM |
Leela 4th vs all others | Eric Bron nli | 2018/09/11 02:40 AM |
AlphaZero vs Stockfish | Gian-Carlo Pascutto | 2018/09/11 05:31 AM |
AlphaZero vs Stockfish | Eric Bron | 2018/09/11 08:26 AM |
AlphaZero vs Stockfish | Eric Bron | 2018/09/11 08:58 AM |
AlphaZero vs Stockfish | Per Hesselgren | 2018/12/31 09:04 AM |
Leela Chess Zero | Per Hesselgren | 2018/12/31 11:00 AM |
AlphaZero vs Stockfish (on Xeon) | Per Hesselgren | 2018/12/31 08:59 AM |
C/C++ and vector/parallel/distributed | RichardC | 2018/08/02 04:50 AM |
Knights Landing - time for obituary? | Passing Through | 2018/08/01 06:52 AM |
Knights Landing - time for obituary? | Kevin G | 2018/08/01 01:03 PM |
Knights Landing - time for obituary? | Passing Through | 2018/08/01 01:33 PM |
Knights Landing - time for obituary? | Kevin G | 2018/08/01 07:26 AM |
Knights Landing - time for obituary? | juanrga | 2018/08/01 01:26 PM |
Knights Landing - time for obituary? | hobel | 2018/08/02 04:46 AM |
Knights Landing - time for obituary? | juanrga | 2018/07/31 10:25 PM |
Right, time for obituary for whole LRB lineage | AM | 2018/08/02 10:46 AM |
Right, time for obituary for whole LRB lineage | Adrian | 2018/08/02 10:46 PM |
LRBNI, AVX512, etc... | Michael S | 2018/08/03 04:23 AM |
Right, time for obituary for whole LRB lineage | juanrga | 2018/08/03 03:11 AM |
