8 wide vs 6 wide
By: David Kanter (dkanter.delete@this.realworldtech.com), November 7, 2016 8:43 pm
Wilco (Wilco.Dijkstra.delete@this.ntlworld.com) on November 7, 2016 2:45 am wrote:
> juanrga (noemail.delete@this.juanrga.com) on November 6, 2016 4:06 pm wrote:
> > Wilco (Wilco.Dijkstra.delete@this.ntlworld.com) on November 6, 2016 4:15 am wrote:
> > > juanrga (noemail.delete@this.juanrga.com) on November 4, 2016 4:39 pm wrote:
> > > > Wilco (Wilco.Dijkstra.delete@this.ntlworld.com) on November 4, 2016 1:12 pm wrote:
> > > > > anon (spam.delete.delete@this.this.spam.com) on November 4, 2016 6:12 am wrote:
> > > > > > Yes, but I still don't see any reason why that means the A10 is 6 wide.
> > > > > > If Sandy/Ivy Bridge is 6 wide then that doesn't mean Haswell/Broadwell is 6 wide.
> > > > > Neither are 6-wide using the standard definition.
> > > > If you bother to read one of the resources given (the first link
> > > > I gave), you will learn that there is no "standard" definition:
> > > Actually that same link does give a standard definition:
The number of instructions able to be issued, executed or completed per cycle is called a processor's
> > > width. Note that the issue width is less than the number of functional units – this is typical.
> > Now continue reading the reference until you get to the point where he discusses if Haswell
> > would be considered 4-wide, 5-wide, or 8-wide, why it depends on what definition of "wide"
> > you use,
> No the definition by itself is clear. Instructions are instructions, there
> is no room for argument. No Intel core can decode/execute 8 instructions
> per cycle. Apple A7 can do 6, Haswell can do 4, it's as simple as that.
I believe that Intel cores can actually do 5 instructions/clock with the macro-op fusion.
> > and why he choses 8-wide (as myself did, as the other references given also did).
> The reason some people choose 8-wide is to pretend Intel's cores are wider than other
> CPUs. When you look internally both Apple A7 and Cortex-A57 are wider than Haswell.
Even width itself is only relevant as an approximation for IPC. Having an 8-wide CPU with one load/store unit is no good for general purpose code (would work for some DSP, maybe).
Also, not all instructions are equal. In particular, on vector codes, AVX could give x86 an advantage. Similarly, on spill heavy code, ARMv7 may have an advantage using LDM/STM.
> In fact Apple A7 is wider than Haswell in every regard. So anyone claiming Haswell is 8 wide
> but A7 is only 6 wide is simply lying because by the same measure A7 is actually 9 wide.
It certainly appears that the A7 has similar IPC at low frequencies.
> > > So it's the number of instructions that one can process, not micro-ops
> > > (as those vary significantly with the microarchitecture).
> > The issue is that what you call "instructions" is not what is reordered, issued,
> > executed, tracked, and retired in the metal of a modern chip as Haswell, or
> > Cyclone, or A72, or Hurricane, or Zen, or Vulcan, or Kaby Lake, or...
> There is an almost 1:1 correspondence between instructions
> and micro-ops, so yes instructions are what matters.
The median instruction decodes to 1 uop. But when you run into nasty ones, they are worth noting. I would always carefully consider both uops and instructions.
In fact with Intel's uop cache, it's not even clear that you measure front-end width in instructions anymore...it could operate solely in the uop domain for extended periods.
David
Neat die area comparison imageRob2016/10/21 05:39 PM
  Neat die area comparison imageanonymou52016/10/21 06:44 PM
    Neat die area comparison imageMr. Camel2016/10/22 04:58 AM
      Neat die area comparison imageHeikki Kultala2016/10/22 05:19 AM
        Neat die area comparison imageMr. Camel2016/10/22 07:10 AM
          Neat die area comparison imageMr. Camel2016/10/22 07:15 AM
          different caches...Heikki Kultala2016/10/22 08:29 AM
            Broadwell includes LLC, just for comparisionanon2016/10/22 08:52 AM
              Broadwell includes LLC, just for comparisionjuanrga2016/10/23 06:09 AM
                Broadwell includes LLC, just for comparisionanon2016/10/23 07:25 AM
                  Broadwell includes LLC, just for comparisionjuanrga2016/10/25 09:57 AM
                    Broadwell includes LLC, just for comparisionSimon Farnsworth2016/10/25 11:03 AM
                      Broadwell includes LLC, just for comparisionjuanrga2016/10/28 02:02 AM
                        Broadwell includes LLC, just for comparisionanon2016/10/28 04:13 AM
                          Broadwell includes LLC, just for comparisionjuanrga2016/10/29 09:47 PM
                            Broadwell includes LLC, just for comparisionTravis2016/10/30 06:34 PM
                              Broadwell includes LLC, just for comparisionjuanrga2016/10/31 04:35 AM
                                Broadwell includes LLC, just for comparisionSimon Farnsworth2016/10/31 04:42 AM
                                Broadwell includes LLC, just for comparisionanon2016/11/01 12:56 PM
                                  Broadwell includes LLC, just for comparisionMaynard Handley2016/11/01 01:37 PM
                                    Broadwell includes LLC, just for comparisionanon2016/11/01 04:22 PM
                                      Broadwell includes LLC, just for comparisionMaynard Handley2016/11/01 07:30 PM
                                        Broadwell includes LLC, just for comparisionanon2016/11/02 06:15 AM
                                          Broadwell includes LLC, just for comparisionMaynard Handley2016/11/02 09:23 AM
                                            Broadwell includes LLC, just for comparisionanon2016/11/02 11:50 AM
                                  Broadwell includes LLC, just for comparisionSimon Farnsworth2016/11/02 02:48 AM
                        Broadwell includes LLC, just for comparisionSimon Farnsworth2016/10/28 06:19 AM
                          Broadwell includes LLC, just for comparisionjuanrga2016/10/29 10:15 PM
                            Broadwell includes LLC, just for comparisionSimon Farnsworth2016/10/30 12:31 PM
                        Broadwell includes LLC, just for comparisionRicardo B2016/10/29 05:30 PM
                    underclocked is different than designed for low clock speedHeikki Kultala2016/10/25 11:47 PM
                      underclocked is different than designed for low clock speedMaynard Handley2016/10/26 10:07 AM
                      That wasn't the pointjuanrga2016/10/28 02:15 AM
                        Even without the point you have invalid comparisonHeikki Kultala2016/10/28 09:03 AM
                          8 wide vs 6 widejuanrga2016/10/29 10:41 PM
                            8 wide vs 6 wideWilco2016/10/30 05:00 AM
                              8 wide vs 6 wideDoug S2016/10/30 12:20 PM
                                8 wide vs 6 wideWilco2016/10/30 01:12 PM
                                8 wide vs 6 widejuanrga2016/10/30 02:56 PM
                                  8 wide vs 6 wideTravis2016/10/30 07:13 PM
                                    8 wide vs 6 widejuanrga2016/10/31 04:55 AM
                                      8 wide vs 6 wideanon2016/11/01 01:00 PM
                                        SoftMachinesnone2016/11/02 03:57 AM
                                          SoftMachinesDavid Kanter2016/11/02 08:53 AM
                                        8 wide vs 6 widejuanrga2016/11/03 12:35 PM
                                          8 wide vs 6 wideWilco2016/11/03 02:13 PM
                                            8 wide vs 6 widejuanrga2016/11/03 07:35 PM
                                              8 wide vs 6 wideWilco2016/11/04 01:27 PM
                                                8 wide vs 6 widejuanrga2016/11/04 06:08 PM
                                                  8 wide vs 6 wideWilco2016/11/06 04:52 AM
                                                    8 wide vs 6 widejuanrga2016/11/06 04:56 PM
                                                      8 wide vs 6 wideWilco2016/11/07 04:25 AM
                                              8 wide vs 6 wideAaron Spink2016/11/04 04:08 PM
                                                8 wide vs 6 widejuanrga2016/11/04 06:10 PM
                                            Dunning-Krueger effectHeikki Kultala2016/11/04 03:22 AM
                                              Dunning-Krueger effectitsmydamnation2016/11/04 02:48 PM
                                          8 wide vs 6 wideanon2016/11/04 03:38 AM
                                            8 wide vs 6 widejuanrga2016/11/04 05:05 AM
                                              8 wide vs 6 wideanon2016/11/04 06:12 AM
                                                8 wide vs 6 wideWilco2016/11/04 01:12 PM
                                                  8 wide vs 6 wideanon2016/11/04 02:54 PM
                                                    8 wide vs 6 widejuanrga2016/11/04 05:34 PM
                                                      8 wide vs 6 wideanon2016/11/05 02:14 AM
                                                  8 wide vs 6 widejuanrga2016/11/04 05:39 PM
                                                    8 wide vs 6 wideWilco2016/11/06 05:15 AM
                                                      8 wide vs 6 widejuanrga2016/11/06 05:06 PM
                                                        8 wide vs 6 wideWilco2016/11/07 03:45 AM
                                                          8 wide vs 6 wideDavid Kanter2016/11/07 08:43 PM
                                                            8 wide vs 6 wideWilco2016/11/08 03:57 AM
                                                          8 wide vs 6 widejuanrga2016/11/14 12:12 PM
                                                            8 wide vs 6 wideWilco2016/11/14 04:53 PM
                                                              8 wide vs 6 widedmcq2016/11/15 03:17 AM
        8 wide vs 6 wideWilco2016/11/15 03:43 AM
        8 wide vs 6 widedmcq2016/11/15 04:28 AM
        1 µop per instruction is not necessaryPaul A. Clayton2016/11/17 12:09 PM
                                                              8 wide vs 6 widejuanrga2016/11/20 06:56 AM
        8 wide vs 6 wideWilco2016/11/21 05:54 PM
        8 wide vs 6 widejuanrga2016/11/22 08:49 AM
        8 wide vs 6 wideWilco2016/11/22 03:25 PM
                                  8 wide vs 6 wideWilco2016/10/31 03:03 AM
                              Skylake can retire 8 uopsDavid Kanter2016/10/31 12:41 AM
                                Skylake can retire 8 uopsjuanrga2016/10/31 04:15 AM
                                  Skylake can retire 8 uopsAlberto2016/11/04 07:22 AM
                            8 wide vs 6 wide bogus numbersHeikki Kultala2016/10/30 06:25 AM
                    Broadwell includes LLC, just for comparisionanon2016/10/26 03:10 AM
                      Pushing the hidden agendajuanrga2016/10/28 03:11 AM
                        Pushing the hidden agendaanon2016/10/28 04:35 AM
      Neat die area comparison imageDavid Hess2016/10/22 01:26 PM
        Neat die area comparison imageanon22016/10/22 05:20 PM
          Neat die area comparison imageDavid Hess2016/10/22 10:31 PM
            Neat die area comparison imageanon22016/10/23 01:50 AM
        Neat die area comparison imageTravis2016/10/24 01:26 PM
          Neat die area comparison imageMaynard Handley2016/10/24 04:27 PM
            Neat die area comparison imagejuanrga2016/10/25 10:02 AM
            Neat die area comparison imageDavid Hess2016/10/25 09:59 PM
              Neat die area comparison imageTravis2016/10/25 10:22 PM
                Neat die area comparison imageDavid Hess2016/10/25 10:37 PM
                  Neat die area comparison imageTravis2016/10/30 06:09 PM
              Neat die area comparison imageGabriele Svelto2016/10/26 02:23 AM
                Neat die area comparison imageDoug S2016/10/26 08:17 AM
                  Neat die area comparison imageJukka Larja2016/10/27 09:28 AM
              Neat die area comparison imageanon2016/10/26 03:32 AM
      Neat die area comparison imagejuanrga2016/10/23 06:29 AM
    Neat die area comparison imageMatthias Waldhauer2016/10/22 06:12 AM
  Neat die area comparison imagejuanrga2016/10/23 05:44 AM
  Neat die area comparison imageGabriele Svelto2016/10/24 02:17 AM
