Article: Transistor Count: A Flawed Metric
By: Chris L (not.delete@this.real.address), January 7, 2021 11:38 pm
David Kanter (dkanter.delete@this.realworldtech.com) on January 4, 2021 8:48 am wrote:
> Chris L (not.delete@this.real.address) on January 3, 2021 8:39 pm wrote:
> > industry tends to use Gate Equivalent for the metric, e.g. when
> > purchasing some IP in RTL form, the post-synthesis will be quoted in GE.
> How is gate equivalent calculated in these tools? Again, decap,
> dummy devices, etc. seem like they would throw off the count.
The use of fillers etc. are there to ensure the IP post-synthesis passes Design Rule Checking. The use of these are typically outside the control of the RTL IP supplier, since the RTL will typically be used with other RTL either from suppliers or written in-house by the chip designer.
So for sure, dummy devices will throw off the count, but if they're used or not is outside the scope of the party supplying the RTL IP.
For IP supplied as 'hard macro', the size will typically be quoted in mm2 for a given process node. The hard macro block will have previously passed some DRC on some test chip.
Cheers,
Chris.
Cheers,
Chris.
Topic | Posted By | Date |
New article: Transistor count: A Flawed Metric | David Kanter | 2020/05/18 06:04 AM |
Non active transistors | Doug S | 2020/05/18 01:26 PM |
Non active transistors | Ricardo B | 2020/05/18 08:12 PM |
Minor quibble about fixed-performance ASIC | Paul A. Clayton | 2020/05/19 02:59 PM |
Minor quibble about fixed-performance ASIC | David Kanter | 2020/05/21 05:58 AM |
A complementary article about xtor density | Paul A. Clayton | 2020/06/02 06:07 AM |
Low leakage transistors | David Kanter | 2020/06/02 06:53 AM |
Transistor count: Metric is often GE | Chris L | 2021/01/03 08:39 PM |
Transistor count: Metric is often GE | David Kanter | 2021/01/04 08:48 AM |
Transistor count: Metric is often GE | Chris L | 2021/01/07 11:38 PM |
