The macOS performance deficit
By: Brett (ggtgp.delete@this.yahoo.com), November 26, 2020 11:29 am
Andrey (andrey.semashev.delete@this.gmail.com) on November 26, 2020 5:08 am wrote:
> Brett (ggtgp.delete@this.yahoo.com) on November 24, 2020 8:01 pm wrote:
> > The Linux build system dates back to the 1960’s, beyond antique and well into archeological.
> > MMAPing thousands of files to do a build with a 4K file mapping and an average of say 8k per file. Let’s
> > do the simplest update to something approaching a real database, like say consolidate all the files in
> > a folder level into one file with a header so you can pipe the individual files inside to GCC. Average
> > wasted disk space went from 25% (2k) to a few hundred bytes. Which means 22% less memory used, 22% less
> > disk sectors loaded, and now you are only mapping hundreds of files and not thousands.
> > Git can be updated to use this format, and editors would use an interface that faked a filesystem so that
> > they and other tools are none the wiser. Just add a filesystem driver that writes to the new database.
> First, I suspect your average file size estimates are off. I did not look at the
> Firefox sources, but C/C++ source files in the projects I interact with are more
> in the range of tens KiB. Source files of hundreds KiB are not uncommon.
> Second, what makes you think that this new database format will be faster than the other database
> format, which we currently call "a filesystem"? In order to be efficient on the current hardware,
> it will have to face the same problems, and I assume it will have to make some tradeoffs, not unlikely
> the same as those made in the current filesystems. And we do already have plenty filesystems, with
> different design decisions, features, performance and reliability, for every taste.
> Third, every filesystem has a standardized API (well, at least as long as we talk of POSIX systems;
> the same argument works in Windows world, too). Any build system, any compiler, editor or VCS can use
> this API, and it will work with any filesystem. If your new database format doesn't support it, then
> it is DOA, because noone except you is going to support it. So even if your format is fast, and you
> implement a build system that works wonders with it, it won't take off because a whole lot of other
> software won't work with it. And no, you won't be able to rewrite the world to support it.
The beauty of this approach is that all this database needs is to import/export git, and have a filesystem driver, and you don’t care what the rest of the world is doing.
You don’t even need git, git can write to the filesystem, there are just some opportunities to optimize git while you are at it. You can inline compression if it is free, etc.
Everything just works, and you can now optimize the speed of builds and git by tuning the database layout behavior. A folder tree with hundreds of files spread all over the disk is now a small set of large linear packed files that stream quickly and use less disk and less ram.
This is a custom filesystem just for compiling, forcing bulk packed loads for speed. As a single purpose filesystem it can track usage and reconfigure to optimize usage. Something ordinary filesystems cannot do.
Important people read this site, someone may implement this idea, and as a software developer this will make me and you happy with faster builds.
Because Microsoft and Apple are not going to optimize their OS’s for mmaping thousands of files like Linus does. In the end the Linus way will lose the performance crown. Everyone else has abandoned filesystems for databases, it is about time programmers did. Insert quote about the cobbler’s children do not wear shoes.
The macOS performance deficitGabriele Svelto2020/11/22 03:02 PM
  The macOS performance deficitrpg2020/11/22 09:45 PM
    The macOS performance deficitChester2020/11/22 10:20 PM
    It's not really a fair fightanon22020/11/22 11:24 PM
      It's not really a fair fightGabriele Svelto2020/11/22 11:30 PM
        WSLanon2020/11/23 01:21 AM
          WSLkonrad schwarz2020/11/23 04:49 AM
            WSLMichael S2020/11/23 04:53 AM
              WSLKonrad Schwarz2020/11/25 09:02 AM
                WSLMichael S2020/11/25 09:19 AM
                  Cygwin vs MSYSKonrad Schwarz2020/11/26 02:12 AM
                    Cygwin vs MSYSMichael S2020/11/26 02:55 AM
                      Cygwin vs MSYSKonrad Schwarz2020/11/26 06:44 AM
                      Cygwin vs MSYSHoward Chu2020/11/26 12:15 PM
          WSLWindowsExperience2020/11/23 05:17 AM
            WSLHoward Chu2020/11/24 09:37 AM
        WindowsChester2020/11/24 01:34 AM
          WindowsMichael S2020/11/24 02:22 AM
            WindowsHoward Chu2020/11/24 09:41 AM
              WindowsChester2020/11/24 11:49 PM
                WindowsMichael S2020/11/25 12:26 AM
                  WindowsChester2020/11/25 03:40 PM
                    WindowsMichael S2020/11/26 03:03 AM
                      Windows and kernel timeChester2020/11/27 12:57 AM
                        Windows and kernel timeEtienne Lorrain2020/11/27 01:21 AM
                          Windows and kernel timeAndrey2020/11/27 02:56 AM
                            Windows and kernel timeMichael S2020/11/27 03:34 AM
                              Windows and kernel timeJames2020/11/27 06:35 AM
                                Windows and kernel timeanon32020/11/27 01:02 PM
                                  Windows and kernel timeBrendan2020/11/27 04:39 PM
                                    Windows and kernel timeanon32020/11/27 05:22 PM
                                      Windows and kernel timeBrendan2020/11/27 06:43 PM
                                  Windows and kernel timeGionatan Danti2020/11/28 02:13 PM
                              Windows and kernel timeAndrey2020/11/27 07:56 AM
                                Windows and kernel timeSimon Farnsworth2020/11/27 10:04 AM
                                  Windows and kernel timeanon2020/11/27 01:55 PM
                                  You also avoid bus contentionCarson2020/12/05 02:26 AM
                                    You also avoid bus contentionDavid Hess2020/12/05 05:07 AM
                                      You also avoid bus contentionCarson2020/12/05 09:50 AM
                                        You also avoid bus contentionDavid Hess2020/12/05 05:04 PM
                                Windows and kernel timeKonrad Schwarz2020/12/21 06:45 AM
                            Windows and kernel timeDavid Hess2020/11/27 07:13 PM
                          Windows and kernel timeLinus Torvalds2020/11/27 12:00 PM
                            Windows and kernel timeGionatan Danti2020/11/28 03:05 PM
                              Windows and kernel timeLinus Torvalds2020/11/28 04:18 PM
                                Windows and kernel timeBrendan2020/11/28 08:21 PM
                                  Windows and kernel timeDoug S2020/11/29 08:58 AM
                                    Windows and kernel timeBrendan2020/11/29 07:10 PM
                                      I read the profile wrongChester2020/11/30 11:10 AM
                                      Windows and kernel timeDoug S2020/11/30 11:10 AM
                                Windows and kernel timeJörn Engel2020/11/29 03:47 AM
                                  Windows and kernel timeLinus Torvalds2020/11/29 11:17 AM
                                Thanks for the explanation (NT)Gionatan Danti2020/11/29 04:25 AM
                            Windows and kernel timeGabriele Svelto2020/11/29 12:17 PM
                            Windows and kernel timeEtienne Lorrain2020/11/30 01:19 AM
                              Windows and kernel timeAdrian2020/11/30 04:57 AM
        It's not really a fair fightHoward Chu2020/11/24 09:34 AM
  The macOS performance deficitkonrad schwarz2020/11/23 04:52 AM
    The macOS performance deficitJon Masters2020/11/23 09:14 AM
      The macOS performance deficitsoftware_engineer2020/11/23 10:33 AM
        The macOS performance deficitMaynard Handley2020/11/23 11:03 AM
          The macOS performance deficitanon22020/11/23 04:28 PM
            The macOS performance deficitMaynard Handley2020/11/23 05:31 PM
              The macOS performance deficitanon22020/11/23 07:10 PM
                The macOS performance deficitMaynard Handley2020/11/23 08:53 PM
                  The macOS performance deficitanon22020/11/23 10:41 PM
            The macOS performance deficitGabriele Svelto2020/11/24 02:02 AM
              The macOS performance deficitUngo2020/11/24 03:30 AM
                The macOS performance deficitGabriele Svelto2020/11/24 03:38 AM
                The macOS performance deficitanon22020/11/24 06:37 AM
                  The macOS performance deficitUngo2020/11/24 11:31 AM
                    The macOS performance deficitanon22020/11/24 03:17 PM
                      The macOS performance deficitUngo2020/11/24 07:27 PM
                        The macOS performance deficitanon22020/11/24 09:06 PM
      The macOS performance deficitLinus Torvalds2020/11/23 11:59 AM
        The macOS performance deficitgallier22020/11/23 11:13 PM
          The macOS performance deficitLinus Torvalds2020/11/24 11:40 AM
        The macOS performance deficitJon Masters2020/11/24 01:52 AM
        Microsoft LinuxPaul2020/11/25 02:16 AM
          Microsoft LinuxMichael S2020/11/25 04:29 AM
          Microsoft Linuxm2020/11/25 07:52 AM
          Microsoft LinuxDummond D. Slow2020/11/25 08:46 AM
          Microsoft LinuxRobert Williams2020/11/25 09:49 AM
            Microsoft Linuxm2020/11/25 12:22 PM
              Microsoft LinuxMichael S2020/11/26 02:21 AM
                Microsoft Linuxm2020/11/26 09:54 AM
          Microsoft Linuxjuanrga2020/11/25 01:53 PM
            Microsoft Linuxm2020/11/25 10:02 PM
              Microsoft Linuxgpd2020/11/26 06:05 AM
      The macOS performance deficitGabriele Svelto2020/11/23 01:03 PM
        The macOS performance deficitRicardo B2020/11/29 06:31 PM
          The macOS performance deficitGionatan Danti2020/11/30 12:05 AM
            The macOS performance deficitRicardo B2020/11/30 12:35 AM
              The macOS performance deficitJacob Marley2020/11/30 12:45 AM
                The macOS performance deficitRicardo B2020/11/30 01:08 AM
                  The macOS performance deficitGionatan Danti2020/11/30 01:22 AM
            The macOS performance deficitEtienne Lorrain2020/11/30 03:08 AM
              The macOS performance deficitGionatan Danti2020/11/30 04:47 AM
  The macOS performance deficitI_vs2020/11/23 04:58 AM
    The macOS performance deficitGabriele Svelto2020/11/23 05:36 AM
      The macOS performance deficitI_vs2020/11/23 06:06 AM
        What is the disk performance of each system? (NT)Anon2020/11/23 06:29 AM
          What is the disk performance of each system?I_vs2020/11/23 09:29 AM
        The macOS performance deficitDummond D. Slow2020/11/23 07:24 AM
          The macOS performance deficitI_vs2020/11/23 09:39 AM
            The macOS performance deficitJukka Larja2020/11/24 06:37 AM
            The macOS performance deficitHoward Chu2020/11/24 09:58 AM
              The macOS performance deficitI_vs2020/11/24 11:22 AM
            The macOS performance deficitAdrian2020/11/24 10:27 AM
          The macOS performance deficitMichael S2020/11/23 11:12 AM
        The macOS performance deficitGabriele Svelto2020/11/23 12:59 PM
  The macOS performance deficitDoug S2020/11/23 11:58 AM
    The macOS performance deficitLinus Torvalds2020/11/23 12:05 PM
      The macOS performance deficitm2020/11/26 11:11 AM
        Process Creation and MacOSRob Thorpe2020/11/27 10:45 AM
          Process Creation and MacOSNksingh2020/11/28 04:23 PM
            Process Creation and MacOSFoo_2020/11/29 03:01 AM
              Process Creation and MacOSnksingh2020/11/29 09:15 PM
            Interesting, looks like I was wrong on Windows tooRob Thorpe2020/11/30 07:42 AM
              I meant to put (NT) in that title. And this one. (NT)Rob Thorpe2020/11/30 07:44 AM
          Process Creation and MacOSLouis Gerbarg2020/11/29 10:41 AM
            Process Creation and MacOSGabriele Svelto2020/11/29 12:09 PM
              Process Creation and MacOSLouis Gerbarg2020/11/29 05:23 PM
                Process Creation and MacOSGabriele Svelto2020/11/30 01:05 PM
                  Process Creation and MacOSLouis Gerbarg2020/11/30 03:19 PM
                  Process Creation and MacOSgallier22020/12/01 12:25 AM
                    Process Creation and MacOSGabriele Svelto2020/12/01 01:56 AM
                    Process Creation and MacOSFoo_2020/12/01 12:30 PM
            That's informative (NT).Rob Thorpe2020/11/30 07:43 AM
          Process Creation and MacOSnoko2020/11/29 11:12 PM
    The macOS performance deficitGabriele Svelto2020/11/23 12:56 PM
      The macOS performance deficitanon22020/11/23 03:59 PM
      The macOS performance deficitI_vs2020/11/24 11:40 AM
        The macOS performance deficitMaynard Handley2020/11/24 02:06 PM
          The macOS performance deficitanon22020/11/24 03:46 PM
            The macOS performance deficitMaynard Handley2020/11/24 04:24 PM
              The macOS performance deficitanon22020/11/24 05:43 PM
                The macOS performance deficitMaynard Handley2020/11/24 06:04 PM
                  The macOS performance deficitanon22020/11/24 06:57 PM
                    The macOS performance deficitBrett2020/11/24 07:20 PM
                      The macOS performance deficitanon22020/11/24 09:22 PM
                  The macOS performance deficitJörn Engel2020/11/25 03:31 AM
              The macOS performance deficitGionatan Danti2020/11/25 10:26 AM
          The macOS performance deficitI_vs2020/11/24 11:12 PM
            The macOS performance deficitanon22020/11/26 01:50 AM
    The macOS performance deficitAndrey2020/11/26 04:24 AM
  The macOS performance deficitBrett2020/11/24 08:01 PM
    The macOS performance deficitMaynard Handley2020/11/24 09:09 PM
    Sour grapes (NT)anon22020/11/24 09:28 PM
    The macOS performance deficitGabriele Svelto2020/11/25 05:15 AM
    The macOS performance deficitAndrey2020/11/26 05:08 AM
      The macOS performance deficitBrett2020/11/26 11:29 AM
        The macOS performance deficitAndrey2020/11/26 12:33 PM
          The macOS performance deficitMaynard Handley2020/11/26 01:02 PM
            The macOS performance deficitAndrey2020/11/26 01:41 PM
              The macOS performance deficitrwessel2020/11/26 10:43 PM
              The macOS performance deficitJames2020/11/27 02:06 AM
            The macOS performance deficitGabriele Svelto2020/11/26 03:08 PM
          The macOS performance deficitBrett2020/11/26 04:11 PM
            The macOS performance deficitDummond D. Slow2020/11/26 05:16 PM
              The macOS performance deficitBrett2020/11/27 12:56 PM
                The macOS performance deficitMaynard Handley2020/11/27 02:32 PM
                  The macOS performance deficitJukka Larja2020/11/27 09:02 PM
                    The macOS performance deficitMaynard Handley2020/11/28 10:46 AM
                      The macOS performance deficitDummond D. Slow2020/11/28 12:09 PM
                      The macOS performance deficitsoftware_engineer2020/11/28 01:35 PM
                        The macOS performance deficitMaynard Handley2020/11/28 03:20 PM
                          The macOS performance deficitJukka Larja2020/11/28 09:09 PM
                            The macOS performance deficitMaynard Handley2020/11/28 09:27 PM
                              The macOS performance deficitJukka Larja2020/11/28 11:29 PM
                          The macOS performance deficitsoftware_engineer2020/11/29 12:56 AM
                            The macOS performance deficitMaynard Handley2020/11/29 11:29 AM
                      The macOS performance deficitJukka Larja2020/11/28 09:18 PM
                      The macOS performance deficitJames2020/11/29 04:02 AM
                        The macOS performance deficitFoo_2020/11/29 05:12 AM
                          The macOS performance deficitFoo_2020/11/29 05:18 AM
                            The macOS performance deficitMaynard Handley2020/11/29 11:35 AM
            The macOS performance deficitanon22020/11/26 05:59 PM
              The macOS performance deficitBrett2020/11/27 01:18 PM
                The macOS performance deficitanon22020/11/27 03:13 PM
            The macOS performance deficitAndrey2020/11/27 03:25 AM
              The macOS performance deficitBrett2020/11/27 01:49 PM
                The macOS performance deficitLinus Torvalds2020/11/28 11:16 AM
                  The macOS performance deficitBrett2020/11/28 06:44 PM
                    The macOS performance deficitanon22020/11/29 12:35 AM
                      The macOS performance deficitBrett2020/11/29 11:31 AM
                        The macOS performance deficitGabriele Svelto2020/11/29 12:00 PM
                          The macOS performance deficitBrett2020/11/29 01:09 PM
                            The macOS performance deficitMaynard Handley2020/11/29 08:57 PM
                              The macOS performance deficitanon32020/11/29 09:37 PM
                              The macOS performance deficitGionatan Danti2020/11/29 11:59 PM
                                The macOS performance deficitDummond D. Slow2020/11/30 08:00 AM
                                  The macOS performance deficitMaynard Handley2020/11/30 09:36 AM
                                    The macOS performance deficitGionatan Danti2020/11/30 10:12 AM
                                      The macOS performance deficitMaynard Handley2020/11/30 08:21 PM
                                        The macOS performance deficitBrett2020/11/30 11:17 PM
                                        The macOS performance deficitGionatan Danti2020/12/01 09:34 AM
                                          The macOS performance deficitMaynard Handley2020/12/01 12:03 PM
                                            The macOS performance deficitGionatan Danti2020/12/01 02:38 PM
                                          The macOS performance deficitUngo2020/12/01 03:13 PM
                                            The macOS performance deficitGionatan Danti2020/12/02 03:23 AM
                                              The macOS performance deficitDoug S2020/12/02 10:38 AM
                                                The macOS performance deficitGionatan Danti2020/12/03 02:23 AM
                                                  The macOS performance deficitDoug S2020/12/03 11:42 AM
                                                    The macOS performance deficitGionatan Danti2020/12/03 12:01 PM
                                                      The macOS performance deficitDoug S2020/12/03 02:37 PM
                                                        The macOS performance deficitDummond D. Slow2020/12/03 05:20 PM
                                                          The macOS performance deficitEtienne Lorrain2020/12/04 01:14 AM
                                                        The macOS performance deficitGionatan Danti2020/12/03 10:53 PM
                                                    The macOS performance deficitDummond D. Slow2020/12/03 05:15 PM
                                                    SDRGJHI4 ?Michael S2020/12/04 02:22 AM
                                                      SDRGJHI4 ?Doug S2020/12/04 08:21 AM
                                                      SDRGJHI4 ?Ungo2020/12/04 10:20 PM
                                              The macOS performance deficitUngo2020/12/02 01:57 PM
                                                The macOS performance deficitRicardo B2020/12/02 05:01 PM
                                          The macOS performance deficitMichael S2020/12/02 12:15 PM
                                            4xMichael S2020/12/02 01:09 PM
                                              4xDoug S2020/12/02 01:40 PM
                                              4xRicardo B2020/12/02 05:16 PM
                                                4xAnon2020/12/02 10:45 PM
                                                  4xAnon2020/12/02 10:47 PM
                                                  4xAndrey2020/12/03 12:01 AM
                                                  4xRicardo B2020/12/03 01:51 AM
                                                    4xAnon2020/12/03 02:00 AM
                                                      4xRicardo B2020/12/03 04:28 AM
                                                        4xAnon2020/12/03 05:25 AM
                                                          4xRicardo B2020/12/03 07:33 AM
                                                            4xAnon2020/12/03 10:34 AM
                                              python v C/C++Michael S2020/12/03 01:42 PM
                                                hw mattersMichael S2020/12/03 03:43 PM
                                                  hw mattersFoo_2020/12/04 02:57 AM
                                                    hw mattersMichael S2020/12/04 03:59 AM
                                                      SSD history mattersAdrian2020/12/04 10:10 AM
                                                  hw mattersRicardo B2020/12/04 03:23 AM
                                                    hw mattersMichael S2020/12/04 04:14 AM
                                                      hw mattersRicardo B2020/12/04 04:58 AM
                                                  hw mattersGionatan Danti2020/12/04 03:38 AM
                                                    hw mattersMichael S2020/12/04 04:33 AM
                                                      hw mattersGionatan Danti2020/12/04 08:49 AM
                                                        hw mattersMichael S2020/12/05 09:04 AM
                                                          hw mattersGionatan Danti2020/12/05 10:07 AM
                                                            hw mattersMichael S2020/12/05 10:25 AM
                                                              Win7 Home vs ProMichael S2020/12/07 08:43 AM
        Win7 Home vs ProGionatan Danti2020/12/08 01:04 AM
                                                for MSVC usersMichael S2020/12/04 04:37 AM
                                            The macOS performance deficitGionatan Danti2020/12/03 02:09 AM
                                              The macOS performance deficitJukka Larja2020/12/03 07:31 AM
                                                The macOS performance deficitRicardo B2020/12/03 08:46 AM
                                                  The macOS performance deficitJukka Larja2020/12/03 10:01 AM
                                                    The macOS performance deficitGionatan Danti2020/12/03 12:37 PM
                                                      The macOS performance deficitJukka Larja2020/12/04 06:14 AM
                                                        The macOS performance deficitGionatan Danti2020/12/04 08:51 AM
                                                      The macOS performance deficitUngo2020/12/04 10:45 PM
                                                        The macOS performance deficitJukka Larja2020/12/05 02:11 AM
                                                          The macOS performance deficitMichael S2020/12/05 09:49 AM
                                                            The macOS performance deficitGionatan Danti2020/12/05 10:11 AM
                                                              The macOS performance deficitMichael S2020/12/05 11:00 AM
        The macOS performance deficitGionatan Danti2020/12/05 11:59 AM
        The macOS performance deficitMichael S2020/12/05 12:22 PM
                                                        The macOS performance deficitGionatan Danti2020/12/05 09:41 AM
                                                          The macOS performance deficitMichael S2020/12/05 09:55 AM
                                                          The macOS performance deficitUngo2020/12/05 09:39 PM
                                                            The macOS performance deficitanon32020/12/05 11:07 PM
                                                              The macOS performance deficitGionatan Danti2020/12/06 01:10 AM
                                                            The macOS performance deficitGionatan Danti2020/12/06 01:04 AM
                                                              The macOS performance deficitUngo2020/12/06 12:24 PM
        The macOS performance deficitLinus Torvalds2020/12/06 02:17 PM
        The macOS performance deficitUngo2020/12/06 03:28 PM
        The macOS performance deficitGionatan Danti2020/12/07 02:31 AM
        The macOS performance deficitLinus Torvalds2020/12/07 11:14 AM
        The macOS performance deficitGionatan Danti2020/12/07 02:29 PM
        The macOS performance deficitLinus Torvalds2020/12/08 12:36 PM
        Linux writebackGionatan Danti2020/12/08 01:23 PM
        Linux writebackLinus Torvalds2020/12/08 03:57 PM
        Good points, thanks (NT)Gionatan Danti2020/12/08 11:42 PM
        The macOS performance deficitRicardo B2020/12/06 04:05 PM
                                                            The macOS performance deficitRicardo B2020/12/06 05:43 AM
                                                              The macOS performance deficitRicardo B2020/12/06 05:48 AM
                                                              The macOS performance deficitLinus Torvalds2020/12/06 11:11 AM
        The macOS performance deficitRicardo B2020/12/06 02:57 PM
        Ext4 performance deficitBrett2020/12/06 05:01 PM
        Ext4 performance deficitRicardo B2020/12/06 05:36 PM
        Ext4 performance deficitBrett2020/12/06 06:13 PM
        Ext4 performance deficitBrett2020/12/06 11:25 PM
        Ext4 performance deficitGionatan Danti2020/12/07 03:06 AM
        Ext4 performance deficitBrett2020/12/07 02:12 PM
        Ext4 performance deficitanonymou52020/12/07 08:04 PM
        Ext4 performance deficitGionatan Danti2020/12/08 12:59 AM
        Ext4 performance deficitBrett2020/12/09 01:54 PM
        Ext4 performance deficitGionatan Danti2020/12/10 12:41 AM
        Ext4 performance deficitBrett2020/12/10 12:08 PM
        Ext4 performance deficitanon22020/12/10 12:33 PM
        Ext4 performance deficitUngo2020/12/10 12:14 PM
        Ext4 performance deficitBrett2020/12/10 01:00 PM
        Ext4 performance deficitanonymou52020/12/10 03:20 PM
        Ext4 performance deficitBrett2020/12/13 12:04 AM
        Ext4 performance deficitMichael S2020/12/13 01:29 AM
        Ext4 performance deficitanonymou52020/12/13 02:46 AM
        Ext4 performance deficitLinus Torvalds2020/12/13 11:30 AM
        Ext4 performance deficitMichael S2020/12/13 12:24 PM
        Ext4 performance deficitBrett2020/12/13 06:26 PM
        Ext4 performance deficitanon2020/12/13 04:58 PM
        Ext4 performance deficitFoo_2020/12/14 03:56 AM
        Ext4 performance deficitrwessel2020/12/14 06:16 AM
        Ext4 performance deficitBrett2020/12/15 04:59 PM
        Ext4 performance deficitBrett2020/12/19 04:23 PM
        Ext4 performance deficitanon2020/12/19 04:44 PM
        Ext4 performance deficitBrett2020/12/19 07:47 PM
        Ext4 performance deficitMichael S2020/12/19 11:40 PM
        Ext4 performance deficitLinus Torvalds2020/12/20 11:09 AM
        Ext4 performance deficitBrett2020/12/24 06:08 PM
        Ext4 performance deficitMichael S2020/12/25 01:32 AM
        Ext4 performance deficitAdrian2020/12/11 01:42 AM
        Ext4 performance deficitanon2020/12/11 12:34 PM
        Ext4 performance deficitAdrian2020/12/12 02:46 AM
        Ext4 performance deficitGionatan Danti2020/12/10 01:06 PM
        Ext4 performance deficitJörn Engel2020/12/08 04:19 AM
        Serving NTFS?Michael S2020/12/07 12:32 AM
                                                            The macOS performance deficitgallier22020/12/07 12:50 AM
                                    The macOS performance deficitAndrey2020/11/30 12:14 PM
                                      The macOS performance deficitUngo2020/11/30 02:58 PM
                                        The macOS performance deficitMaynard Handley2020/11/30 05:13 PM
                                          The macOS performance deficitUngo2020/12/01 12:37 AM
                                            The macOS performance deficitMaynard Handley2020/12/01 09:49 AM
                                        The macOS performance deficitAndrey2020/12/01 12:55 AM
                                          The macOS performance deficitGionatan Danti2020/12/01 01:48 AM
                                          The macOS performance deficitAnne O. Nymous2020/12/01 02:10 AM
                                        The macOS performance deficitRicardo B2020/12/01 07:40 AM
                                          The macOS performance deficitUngo2020/12/01 06:03 PM
                                            The macOS performance deficitRicardo B2020/12/02 03:08 AM
                                            The macOS performance deficitDoug S2020/12/02 10:51 AM
                                              The macOS performance deficitMatt Sayler2020/12/02 05:36 PM
                                              The macOS performance deficitGionatan Danti2020/12/03 01:47 AM
                                              The macOS performance deficitLouis Gerbarg2020/12/03 09:32 AM
                                                The macOS performance deficitDoug S2020/12/03 11:51 AM
                                      The macOS performance deficitMaynard Handley2020/11/30 06:21 PM
                                        The macOS performance deficitAndrey2020/12/01 02:03 AM
                                          I take it no one here has any real storage admin experienceDoug S2020/12/01 09:39 AM
                                            I take it no one here has any real storage admin experienceGionatan Danti2020/12/01 09:58 AM
                                            I take it no one here has any real storage admin experienceAndrey2020/12/01 12:40 PM
                                            I take it no one here has any real storage admin experienceDavid Hess2020/12/02 04:03 AM
                                              I take it no one here has any real storage admin experienceDoug S2020/12/02 10:57 AM
                                                I take it no one here has any real storage admin experienceDavid Hess2020/12/02 03:46 PM
                                        The macOS performance deficitSimon Farnsworth2020/12/01 03:50 AM
                                        The macOS performance deficitRicardo B2020/12/01 11:23 AM
                        The macOS performance deficitanon22020/11/29 01:20 PM
                  The macOS performance deficitDoug S2020/11/29 09:18 AM
                    The macOS performance deficitLinus Torvalds2020/11/29 11:03 AM
                      The macOS performance deficitHoward Chu2020/11/30 09:07 AM
                        The macOS performance deficitLinus Torvalds2020/11/30 11:05 AM
                          The macOS performance deficitrwessel2020/11/30 11:54 AM
                          The macOS performance deficitanon2020/11/30 03:05 PM
                          The macOS performance deficitHoward Chu2020/11/30 07:57 PM
                            The macOS performance deficitLinus Torvalds2020/11/30 10:34 PM
                              The macOS performance deficitBrett2020/11/30 11:34 PM
                                The macOS performance deficitBrett2020/12/01 01:47 PM
                                  The macOS performance deficitLinus Torvalds2020/12/01 02:57 PM
                                    The macOS performance deficitPatrick Schlüter aka gallier22020/12/02 07:31 AM
                                    The macOS performance deficitDoug S2020/12/02 11:07 AM
                                      The macOS performance deficitAdrian2020/12/03 02:50 AM
                                        The macOS performance deficitLinus Torvalds2020/12/03 12:28 PM
                                          The macOS performance deficitAdrian2020/12/03 12:40 PM
                                    The macOS performance deficitBrett2020/12/02 02:49 PM
                                The macOS performance deficitDavid Hess2020/12/01 08:17 PM
                              BitKeeperanon2020/12/01 12:03 AM
                                BitKeeperanon2020/12/01 12:28 AM
                                charlatansanon22020/12/01 02:57 AM
                                  charlatansMichael S2020/12/01 04:30 AM
                                    charlatansanon22020/12/01 05:38 AM
                                      charlatansrwessel2020/12/01 06:18 AM
                                      version controlMichael S2020/12/02 11:50 AM
                                        version controlLinus Torvalds2020/12/02 01:18 PM
                                          Cheap commits are a huge git winCarson2020/12/08 02:05 AM
                                        version controlanon22020/12/02 08:43 PM
                                BitKeeperLinus Torvalds2020/12/01 11:35 AM
                                  BitKeeperanon2020/12/01 03:42 PM
                                    BitKeeperanonymou52020/12/01 05:26 PM
                                    Larry? (NT)anon22020/12/01 08:25 PM
                                      Larry McVoy, the lead developer of bitkeeper (NT)Carson2020/12/08 02:07 AM
                              The macOS performance deficitDoug S2020/12/01 09:42 AM
                            The macOS performance deficitrwessel2020/12/01 05:51 AM
                              The macOS performance deficitanon2020/12/01 02:49 PM
                        LMDB transactionsanon2020/11/30 02:58 PM
                          LMDB transactionsHoward Chu2020/11/30 07:29 PM
                            LMDB transactionsanon2020/11/30 11:44 PM
                              LMDB transactionsHoward Chu2020/12/01 12:44 PM
                                LMDB transactionsanon2020/12/01 02:33 PM
                                  LMDB transactionsHoward Chu2020/12/02 08:52 AM
                                    LMDB transactionsHoward Chu2020/12/02 08:55 AM
                                      LMDB transactionsAnon2020/12/02 10:54 AM
                        Fossil SCM (SQLite based) works pretty well (NT)anonymous22020/11/30 03:50 PM
                      The macOS performance deficitAnon2020/12/01 11:39 PM
