By: Adrian (a.delete@this.acm.org), December 21, 2020 9:51 am
Linus Torvalds (torvalds.delete@this.linux-foundation.org) on December 20, 2020 10:39 am wrote:
> There is support for "packed BCD" load and store instructions, but they aren't
> actually floating point. They are integer values. They just get converted
> to/from the 80-bit extended FPU register format at load/store time.
> So there's no decimal floating point format internally. It's purely a "load an
> integer value in an odd BCD format into the 64-bit mantissa of a FP register".
> So it's more like a very odd in-memory integer format that can then be loaded into the FP registers. Once
> they are in the FP registers, they are regular (extended 80-bit) binary FP values - any operations you
> do on them will be the regular binary FP, there is no support for doing actual decimal operations.
> So you'll get all the usual binary rounding etc results if you do any actual math on these values.
> I have no idea if anybody ever used those instructions. They are slow iirc, and very
> seldom do anything you want to do. You could use them to do conversions to and from
> ASCII (or, obviously, BCD) decimal integer representations to binary, but I can't imagine
> that it would be faster than just doing it manually on the integer side.
On any modern CPU these instructions are indeed too slow to be useful for anything.
Nevertheless, on an 80386 with 80387 coprocessor, these instructions were fast compared to alternatives and they allowed writing some very simple conversion functions between ASCII and binary number representations (together with other now completely obsolete tricks, e.g. using decimal adjust for hex to ASCII).
However, after passing to 80486, I think that I have soon stopped using them.
