memory errors
By: David Hess (davidwhess.delete@this.gmail.com), March 6, 2021 4:27 am
dmcq (dmcq.delete@this.fano.co.uk) on March 5, 2021 12:59 pm wrote:
> David Hess (davidwhess.delete@this.gmail.com) on March 4, 2021 1:44 pm wrote:
> > dmcq (dmcq.delete@this.fano.co.uk) on March 4, 2021 6:40 am wrote:
> > > The initialisation problem could have been easily solved by simply only initialising a page when
> > > it was allocated, or ovcerwriting it if it is set from disk. You'd still get some seconds spent
> > > on the job but the user wouldn't notice. I can't really believe they wouldn't think of that never
> > > mind that booting took a long time anyway so this would be no sort of great gain.
> > I have not noticed any delay on my workstation which has 64G.
> > The entire memory would have to be initialized before memory scrubbing could be used. Without scrubbing,
> > memory could be initialized as written but this would return errors if uninitialized memory was accessed.
> You wouldn't be able to access it before it was allocated. Have you got ECC on your workstation and is it
> enabled? I'm not sure even Windows nowadays takes any notice of it :-( You can depend on Linux though.
Memory scrubbing is handled by the memory controller and not the operating system, so it has to be enabled after the memory is initialized which is easy enough in the BIOS. Caches are also scrubbed. Whether errors are reported to the operating system is configurable.
Windows 7 and later are suppose to record ECC events in the event log but I am not sure if this applies only to server versions.
My workstations have had ECC since the 1990s. Perhaps not coincidentally, they were only retired as they became obsolete rather than because of hardware failure.
CPU & Memory bit flipsGanon2021/03/03 09:05 AM
  Also "Silent Data Corruption"Adrian2021/03/03 10:42 AM
    Thanks for the referenceGanon2021/03/03 11:47 AM
  Implications for linux page cacheanon2021/03/03 11:54 AM
    Implications for linux page cacheLinus Torvalds2021/03/03 01:54 PM
      memory errorsblaine2021/03/03 02:53 PM
        memory errorsanon22021/03/03 05:30 PM
          memory errorsdmcq2021/03/04 05:16 AM
            memory errorsEtienne Lorrain2021/03/04 06:26 AM
              memory errorsdmcq2021/03/04 06:40 AM
                memory errorsEtienne Lorrain2021/03/04 06:58 AM
                  memory errorsdmcq2021/03/04 07:12 AM
                  memory errorsCarson2021/03/05 02:31 AM
                    memory errorsEtienne Lorrain2021/03/05 06:23 AM
                      memory errorsrwessel2021/03/05 07:48 AM
                      memory errorsdmcq2021/03/05 12:01 PM
                        memory errorsrwessel2021/03/05 12:23 PM
                          memory errorsdmcq2021/03/05 12:51 PM
                      memory errorsBrendan2021/03/05 11:38 PM
                      memory errorsCarson2021/03/06 01:35 AM
                        memory errorsCarson2021/03/06 06:24 AM
                memory errorsDavid Hess2021/03/04 01:44 PM
                  memory errorsrwessel2021/03/04 05:14 PM
                  memory errorsLinus Torvalds2021/03/04 08:21 PM
                    memory errorsanon22021/03/04 09:46 PM
                      memory errorsCarson2021/03/05 02:43 AM
                        memory errorsanon22021/03/05 07:55 AM
                    memory errorsgallier22021/03/05 02:22 AM
                  memory errorsdmcq2021/03/05 12:59 PM
                    memory errorsDavid Hess2021/03/06 04:27 AM
                      memory errorsCarson2021/03/06 06:44 AM
                      memory errorsGabriele Svelto2021/03/06 10:11 AM
                        memory errorsDavid Hess2021/03/06 10:28 AM
                          memory errorsMichael S2021/03/06 02:45 PM
              memory errorsDoug S2021/03/04 10:48 AM
                memory errorsMichael S2021/03/04 11:36 AM
              memory errorsJörn Engel2021/03/04 03:32 PM
                memory errorsLinus Torvalds2021/03/04 08:47 PM
                  memory errorsEtienne Lorrain2021/03/05 01:09 AM
                  memory errorsMichael S2021/03/05 04:06 AM
                    memory errorsLinus Torvalds2021/03/05 11:59 AM
                      memory errorsrwessel2021/03/05 12:32 PM
                        memory errorsrwessel2021/03/05 12:37 PM
                        memory errorszArchJon2021/03/06 08:39 PM
                      memory errorsGabriele Svelto2021/03/06 12:58 PM
                  memory errorsJörn Engel2021/03/05 10:12 AM
                Amiga recoverable RAM disk?Carson2021/03/05 03:03 AM
                  Thanks - TIL a cool Amiga feature (nt) (NT)John2021/03/05 12:51 PM
                    Another cool Amiga feature, datatypesCharles2021/03/06 12:01 AM
                      Another cool Amiga feature, datatypesJukka Larja2021/03/06 01:23 AM
                      Another cool Amiga feature, datatypesAnon2021/03/06 12:40 PM
                      Another cool Amiga feature, filesystemsMarcus2021/03/07 12:28 AM
  CPU & Memory bit flipszArchJon2021/03/04 06:39 AM
    CPU & Memory bit flipsdmcq2021/03/04 06:59 AM
      CPU & Memory bit flipsrwessel2021/03/04 12:27 PM
  speak of the devilRobert Williams2021/03/05 07:53 AM
    speak of the devildmcq2021/03/05 11:26 AM
      speak of the devilRobert Williams2021/03/05 03:15 PM
