By: wumpus (wumpus.delete.delete.delete@this.this.this.lost.in.a.hole), April 7, 2021 9:06 am
Doug S (foo.delete@this.bar.bar) on April 5, 2021 6:57 am wrote:
> David Hess (davidwhess.delete@this.gmail.com) on April 4, 2021 8:45 pm wrote:
> > This also means that the external overhead of ECC is greater going from 64/72 to 32/40,
> > but maybe the internal organization is different for the mandatory internal ECC.
> Given that full ECC for DDR5 will (at least) double the ECC DIMM price penalty I wouldn't be
> surprised to see some using DDR5's internal ECC as an excuse to drop board support for it. Fewer
> customers will demand it due to the higher cost, and marketing will be telling those customers
> "its built into the DIMMs now, you don't need ECC except at the extreme high end".
You only need it if you are worried about the entire chip frying at once. But plenty of the people who wanted ECC will still want parity (possibly a multi-bit checksum). If the data gets mangled in the I/O interface you want to know. You can still pull the known-good data from the ECC DRAM with a repeat, but you have to know the error occurred (through parity) before you will do that.
I have to wonder just how much of the market is worried enough about a single chip frying to use double-ECC but not sufficiently concerned about the rest of the server to effectively duplicate entire server racks. There are a lot more single point of failures than DRAM, it is just that DRAM errors are more common (without internal ECC) and easier to deal with, so I suspect that *that guy* in the engineering design review will force them to use double-ECC "because you can't be too careful".
PS. Logically, you could use a single bit carry-chain across "n" chips for a "n-burst" read that would deliver the parity for the entire read at the end of the cycle. Cost would be two pins. Somehow I doubt anyone would bother for DDR-6.
