Article: Hot Chips XXI Preview
By: AM (.delete@this..), September 3, 2009 1:52 am
Jouni Osmala (josmala@cc.hut.fi) on 9/2/09 wrote:
>>>OoO means more work in the earlier stages of pipeline, AND longer critical path from instruction fetch to execute.
>>>Now you have couple of choices.
>>>A) Increase pipeline length.
>>>B) Reduce clock speed.
>>>C) Improve enough some delay to compensate the extrawork, and EV6 did that by redesigning
>>>the clockdistribution system. However, with equal clock generation hardware inorder system would clock higher.
>>More work (+ die space) -- yes, indeed, but the last statement is not obvious at all. Why?
>If clockcycletime = Work+latch_delay+sometime required to handle variations in clock distribution network.
>IF B) Happens instead of A) in design, and it has SOME headroom to improve latchdelay
>or clockdistribution variation then, it to keep clockcycle time could stay still
>while doing longer delay of work in the stage by improving the latch and clocking
>network. Like happened with EV6 but to a more serious issue is that its too slow.
>>Which part of OoO stuff imposes a hard limitation on clock rate, hittable by an
>>in-order chip, yet unhittabble by an ooo chip?
>I doubt that I would be qualified to answer that.
>I personally think that OoO:s main limitations are extra power and that it increases
>the length of pipeline IF all other parameters would be equal.
Power and space yes, the question is by how much. E.g. PPC750 and esp. 603 consumed only a few watts and had a very modest non-cache transistor count by any standards. What do you think power and pipeline-length overheads are there due to ooo?
As for pipeline length, quickly checking, PPC 604e had 6-stage pipeline (fetch, decode, dispatch, execute, complete, writeback), and PPC750 outdid 604e with 4 stages, apparently combining decode+dispatch and complete+writeback; consumed a few watts and ISSCC presentation reports 500 MHz in 0.2um process: http://isscc.org/isscc/1998/ap/FP15.htm What is the impact of OoO on the length of the pipeline?
In case you don't like old slow chips, let's take Netburst. Power efficiency is not its hallmark, but still how much do you think it lost in clock rate due to being an OoO design?
I'll think that most
>of the time it just couple of extra stages in pipeline and keep the clockspeed same
>as would be inorder design, and pay it by extra power consumption and extra die size.
>(which in inorder design could have been dedicated to extra function units or extra
>cores, or just saved for battery life)
>>Any good examples? Or is that from your own design experience?
>Some is from theoretical designs done while studying, but the choice C is much
>directly from a course in which lecturer disected the EV6->EV5 transition electrical
>design changes in detail to PHD students over several lectures.
Circuit design could have improved, but it couldn't have delivered a massive improvement (so EV6-style EV5 would clock say, 1.5x faster), no frigging way. What are your (your lecturer's) estimations on how much EV6 gained due to circuits and how much it lost back from OoO?
Topic | Posted By | Date |
Hot Chips XXI Preview online | David Kanter | 2009/08/12 01:55 PM |
Hot Chips XXI Preview online | Groo | 2009/08/12 04:27 PM |
Hot Chips XXI Preview online | David Kanter | 2009/08/12 05:17 PM |
recent POWER7 info. from IBM | M.Isobe | 2009/08/16 01:04 AM |
Hot Chips XXI Preview online | slacker | 2009/08/12 07:11 PM |
Attending hot chips | David Kanter | 2009/08/12 07:53 PM |
Power7 vs. single threaded performance and licensing | Daniel Bizó | 2009/08/12 11:05 PM |
Power7 vs. single threaded performance and licensing | Wes Felter | 2009/08/13 10:17 AM |
Power7 vs. single threaded performance and licensing | anon | 2009/08/13 02:25 PM |
Power7 vs. single threaded performance and licensing | Linus Torvalds | 2009/08/13 02:48 PM |
How much IPC | E | 2009/08/14 12:16 AM |
How much IPC | hobold | 2009/08/14 02:03 AM |
How much IPC | a reader | 2009/08/15 09:26 AM |
How much IPC | hobold | 2009/08/15 09:58 AM |
How much IPC | Linus Torvalds | 2009/08/15 11:09 AM |
How much IPC | hobold | 2009/08/15 11:45 AM |
How much IPC | Euronymous | 2009/08/15 12:41 PM |
How much IPC | ? | 2009/08/16 12:13 AM |
How much IPC | Anonymous | 2009/08/16 01:07 AM |
How much IPC | ? | 2009/08/16 02:49 AM |
How much IPC | EduardoS | 2009/08/16 06:04 AM |
How much IPC | Anonymous | 2009/08/16 04:26 PM |
How much IPC | Linus Torvalds | 2009/08/16 06:49 AM |
How much IPC | ? | 2009/08/16 08:32 AM |
How much IPC | EduardoS | 2009/08/16 06:09 AM |
How much IPC | Linus Torvalds | 2009/08/16 07:12 AM |
How much IPC | a reader | 2009/08/16 10:41 AM |
How much IPC | Linus Torvalds | 2009/08/16 11:21 AM |
How much IPC | none | 2009/08/16 12:30 PM |
How much IPC | ? | 2009/08/16 10:32 PM |
How much IPC | ? | 2009/08/16 11:09 PM |
How much IPC | none | 2009/08/17 01:29 AM |
How much IPC | ? | 2009/08/17 04:25 AM |
Speculation and waste | David Kanter | 2009/08/17 09:03 AM |
Speculation and waste | ? | 2009/08/18 10:59 AM |
Speculation and waste | David Kanter | 2009/08/18 11:22 AM |
Speculation and waste | anon | 2009/08/19 01:52 AM |
Speculation and waste | TruePath | 2009/09/27 05:23 AM |
How much IPC | none | 2009/08/18 12:55 AM |
How much IPC | anon | 2009/08/18 01:27 AM |
How much IPC | anon | 2009/08/16 09:05 PM |
How much IPC | Linus Torvalds | 2009/08/17 09:17 AM |
How much IPC | _Arthur | 2009/08/17 02:23 PM |
How much IPC | David Kanter | 2009/08/17 02:38 PM |
How much IPC | Michael S | 2009/08/17 02:39 PM |
How much IPC | David Kanter | 2009/08/17 02:48 PM |
How much IPC | Michael S | 2009/08/17 04:03 PM |
How much IPC | _Arthur | 2009/08/17 04:33 PM |
How much IPC | Michael S | 2009/08/17 04:56 PM |
How much IPC | _Arthur | 2009/08/17 07:48 PM |
How much IPC | Michael S | 2009/08/18 02:07 AM |
limits of sorting | hobold | 2009/08/18 03:26 AM |
limits of sorting | Michael S | 2009/08/18 04:26 AM |
limits of sorting | _Arthur | 2009/08/18 05:03 AM |
limits of sorting | Richard Cownie | 2009/08/18 05:32 AM |
limits of sorting | Michael S | 2009/08/18 06:17 AM |
limits of sorting | Richard Cownie | 2009/08/18 07:22 AM |
limits of sorting | _Arthur | 2009/08/18 07:57 AM |
limits of sorting | Richard Cownie | 2009/08/18 08:30 AM |
limits of sorting | Richard Cownie | 2009/08/18 08:45 AM |
limits of sorting | Michael S | 2009/08/18 08:50 AM |
limits of sorting | Richard Cownie | 2009/08/18 09:09 AM |
limits of sorting | Michael S | 2009/08/18 09:33 AM |
limits of sorting | Richard Cownie | 2009/08/18 09:53 AM |
limits of sorting | Michael S | 2009/08/18 10:28 AM |
limits of sorting | Richard Cownie | 2009/08/18 11:01 AM |
limits of sorting | JasonB | 2009/08/18 05:40 PM |
limits of sorting | Richard Cownie | 2009/08/18 06:22 PM |
You work on EDA right Richard? | David Kanter | 2009/08/18 06:49 PM |
You work on EDA right Richard? | Richard Cownie | 2009/08/19 04:56 AM |
You work on EDA right Richard? | David Kanter | 2009/08/19 07:26 AM |
You work on EDA right Richard? | Richard Cownie | 2009/08/19 07:47 AM |
You work on EDA right Richard? | slacker | 2009/08/19 08:52 AM |
You work on EDA right Richard? | Richard Cownie | 2009/08/19 09:10 AM |
You work on EDA right Richard? | slacker | 2009/08/19 10:36 PM |
You work on EDA right Richard? | slacker | 2009/08/19 10:45 PM |
You work on EDA right Richard? | Richard Cownie | 2009/08/20 04:28 AM |
You work on EDA right Richard? | slacker | 2009/08/20 05:32 AM |
You work on EDA right Richard? | Aaron Spink | 2009/08/19 11:08 PM |
You work on EDA right Richard? | Rob Thorpe | 2009/08/20 07:31 AM |
You work on EDA right Richard? | David Kanter | 2009/08/20 08:58 AM |
You work on EDA right Richard? | Rob Thorpe | 2009/08/20 03:10 PM |
limits of sorting | rwessel | 2009/08/18 06:56 PM |
limits of sorting | JasonB | 2009/08/18 10:11 PM |
limits of sorting | JasonB | 2009/08/18 10:25 PM |
limits of sorting | Richard Cownie | 2009/08/19 05:32 AM |
limits of sorting | Rob Thorpe | 2009/08/19 06:12 AM |
limits of sorting | Richard Cownie | 2009/08/19 06:46 AM |
limits of sorting | JasonB | 2009/08/19 07:43 PM |
limits of sorting | Richard Cownie | 2009/08/20 06:47 AM |
limits of sorting | JasonB | 2009/08/20 07:20 PM |
limits of sorting | Richard Cownie | 2009/08/20 10:12 PM |
limits of sorting | JasonB | 2009/08/21 01:08 AM |
limits of sorting | Richard Cownie | 2009/08/21 04:15 AM |
limits of sorting | JasonB | 2009/08/22 05:24 PM |
limits of sorting | Richard Cownie | 2009/08/22 06:27 PM |
limits of sorting | Richard Cownie | 2009/08/22 07:39 PM |
limits of sorting | ? | 2009/08/23 04:07 AM |
limits of sorting | Richard Cownie | 2009/08/23 04:53 AM |
limits of sorting | anonymous | 2009/08/23 10:42 AM |
useful link, thanks | Richard Cownie | 2009/08/23 04:23 PM |
limits of sorting | ? | 2009/09/04 03:05 AM |
limits of sorting | JasonB | 2009/08/23 08:26 AM |
wacky C++ features | Richard Cownie | 2009/08/24 06:13 AM |
wacky C++ features | a reader | 2009/08/24 08:59 PM |
wacky C++ features | Richard Cownie | 2009/08/25 02:18 AM |
wacky C++ features | a reader | 2009/08/25 06:04 AM |
wacky C++ features | Potatoswatter | 2009/08/25 09:21 PM |
wacky C++ features | none | 2009/08/26 04:47 AM |
wacky C++ features | Richard Cownie | 2009/08/26 07:09 AM |
wacky C++ features | Potatoswatter | 2009/08/27 05:25 AM |
wacky C++ features | Andi Kleen | 2009/08/24 11:06 PM |
wacky C++ features | Richard Cownie | 2009/08/25 02:10 AM |
wacky C++ features | Octoploid | 2009/08/25 02:40 AM |
wacky C++ features | Richard Cownie | 2009/08/25 04:15 AM |
wacky C++ features | Andi Kleen | 2009/08/25 06:58 AM |
thanks | Richard Cownie | 2009/08/25 07:07 AM |
thanks | Andi Kleen | 2009/08/25 10:28 AM |
wacky C++ features | anon | 2009/08/25 02:34 PM |
wacky C++ features | Andi Kleen | 2009/08/25 09:25 PM |
wacky C++ features | JasonB | 2009/08/25 12:13 AM |
wacky C++ features | Richard Cownie | 2009/08/25 01:32 AM |
exception | a reader | 2009/08/25 06:32 AM |
exception | Richard Cownie | 2009/08/25 06:57 AM |
exception | Potatoswatter | 2009/08/25 07:30 AM |
wacky C++ features | JasonB | 2009/08/25 07:56 PM |
correction | JasonB | 2009/08/25 08:47 PM |
correction | c++ | 2009/08/26 08:53 AM |
correction | JasonB | 2009/08/26 06:48 PM |
(new char[10]) does not have array type (NT) | Potatoswatter | 2009/08/27 05:27 AM |
correction | Potatoswatter | 2009/08/27 06:52 AM |
correction | c++ | 2009/08/27 08:29 AM |
comeau bugs and gcc features | Potatoswatter | 2009/08/27 08:51 AM |
comeau bugs and gcc features | Potatoswatter | 2009/08/27 10:28 AM |
wacky C++ features | Richard Cownie | 2009/08/26 08:17 AM |
wacky C++ features | JasonB | 2009/08/26 06:46 PM |
wacky C++ features | Richard Cownie | 2009/08/27 08:41 AM |
wacky C++ features | JasonB | 2009/08/27 08:33 PM |
wacky C++ features | Richard Cownie | 2009/08/28 12:24 AM |
wacky C++ features | Richard Cownie | 2009/08/28 12:27 AM |
wacky C++ features | Michael S | 2009/08/28 05:05 AM |
wacky C++ features | EduardoS | 2009/08/28 05:45 AM |
wacky C++ features | Richard Cownie | 2009/08/28 06:50 AM |
wacky C++ features | JasonB | 2009/08/28 03:56 PM |
wacky C++ features | JasonB | 2009/08/28 04:55 PM |
wacky C++ features | Richard Cownie | 2009/08/28 06:44 PM |
wacky C++ features | Konrad Schwarz | 2009/09/07 03:24 AM |
wacky C++ features | EduardoS | 2009/08/26 02:22 PM |
wacky C++ features | JasonB | 2009/08/26 05:47 PM |
wacky C++ features | Jukka Larja | 2009/08/26 11:03 PM |
wacky C++ features | JasonB | 2009/08/27 12:17 AM |
wacky C++ features | EduardoS | 2009/08/27 02:26 PM |
wacky C++ features | JasonB | 2009/08/27 05:31 PM |
wacky C++ features | EduardoS | 2009/08/28 02:25 PM |
wacky C++ features | JasonB | 2009/08/28 05:20 PM |
wacky C++ features | JasonB | 2009/08/27 08:56 PM |
Windows vs Unix/Linux culture | Richard Cownie | 2009/08/21 06:33 AM |
Windows vs Unix/Linux culture | Michael S | 2009/08/21 07:07 AM |
Windows vs Unix/Linux culture | Richard Cownie | 2009/08/21 07:33 AM |
Windows vs Unix/Linux culture | Paul | 2009/08/22 03:12 AM |
Windows vs Unix/Linux culture | anon | 2009/08/21 10:18 PM |
Windows vs Unix/Linux culture | Richard Cownie | 2009/08/21 10:45 PM |
Windows vs Unix/Linux culture | anon | 2009/08/21 11:48 PM |
Windows vs Unix/Linux culture | Paul | 2009/08/22 03:25 AM |
Windows vs Unix/Linux culture | Gian-Carlo Pascutto | 2009/08/22 06:02 AM |
Windows vs Unix/Linux culture | Paul | 2009/08/22 07:13 AM |
Windows vs Unix/Linux culture | rwessel | 2009/08/24 02:09 PM |
Windows vs Unix/Linux culture | JasonB | 2009/08/22 04:28 PM |
Windows vs Unix/Linux culture | Richard Cownie | 2009/08/22 05:22 PM |
Windows vs Unix/Linux culture | JasonB | 2009/08/22 05:52 PM |
Windows vs Unix/Linux culture | Richard Cownie | 2009/08/22 06:47 PM |
Encapsulation | Konrad Schwarz | 2009/09/03 03:49 AM |
Encapsulation | anon | 2009/09/03 09:05 AM |
Encapsulation | ? | 2009/09/03 10:38 AM |
Encapsulation | Andi Kleen | 2009/09/04 12:41 AM |
Encapsulation | anon | 2009/09/04 06:24 AM |
Encapsulation | Richard Cownie | 2009/09/04 06:34 AM |
Encapsulation | Konrad Schwarz | 2009/09/07 02:28 AM |
Encapsulation | Richard Cownie | 2009/09/07 03:04 PM |
Windows vs Unix/Linux culture | ? | 2009/09/03 10:51 AM |
Windows vs Unix/Linux culture | no thanks | 2009/08/23 09:36 AM |
Windows vs Unix/Linux culture | Richard Cownie | 2009/08/23 03:23 PM |
Windows vs Unix/Linux culture | JasonB | 2009/08/23 07:31 PM |
Windows vs Unix/Linux culture | Richard Cownie | 2009/08/23 11:10 PM |
Windows vs Unix/Linux culture | Jukka Larja | 2009/08/24 09:13 PM |
Windows vs Unix/Linux culture | JasonB | 2009/08/24 10:35 PM |
Windows vs Unix/Linux culture | Richard Cownie | 2009/08/25 02:04 AM |
Windows vs Unix/Linux culture | JasonB | 2009/08/25 10:48 PM |
Windows vs Unix/Linux culture | Richard Cownie | 2009/08/26 07:28 AM |
Windows vs Unix/Linux culture | JasonB | 2009/08/26 09:31 PM |
Windows vs Unix/Linux culture | Richard Cownie | 2009/08/26 07:43 AM |
Windows vs Unix/Linux culture | anon | 2009/08/26 12:48 PM |
Windows vs Unix/Linux culture | Richard Cownie | 2009/08/26 02:28 PM |
Windows vs Unix/Linux culture | JasonB | 2009/08/26 07:06 PM |
Windows vs Unix/Linux culture | Richard Cownie | 2009/08/27 02:44 AM |
Windows vs Unix/Linux culture | Rob Thorpe | 2009/08/27 04:51 AM |
Windows vs Unix/Linux culture | JasonB | 2009/08/23 08:07 PM |
Windows vs Unix/Linux culture | no thanks | 2009/08/23 08:44 PM |
Windows vs Unix/Linux culture | JasonB | 2009/08/23 11:34 PM |
Windows vs Unix/Linux culture | anon | 2009/08/23 08:46 PM |
limits of sorting | Richard Cownie | 2009/08/20 06:59 AM |
limits of sorting | Richard Cownie | 2009/08/20 08:27 AM |
limits of sorting | JasonB | 2009/08/20 07:55 PM |
limits of sorting | Richard Cownie | 2009/08/20 10:22 PM |
limits of sorting | JasonB | 2009/08/20 11:15 PM |
limits of sorting | Richard Cownie | 2009/08/21 03:47 AM |
limits of sorting | ? | 2009/08/20 10:42 PM |
limits of sorting | Richard Cownie | 2009/08/21 06:51 AM |
limits of sorting | Michael S | 2009/08/21 07:11 AM |
limits of sorting | Richard Cownie | 2009/08/21 07:38 AM |
limits of sorting | dmsc | 2009/08/20 06:56 PM |
limits of sorting | Richard Cownie | 2009/08/20 07:20 PM |
limits of sorting | Rob Thorpe | 2009/08/20 07:09 AM |
limits of sorting | Aaron Spink | 2009/08/19 11:19 PM |
limits of sorting | JasonB | 2009/08/20 12:55 AM |
limits of sorting | Michael S | 2009/08/18 06:12 AM |
limits of sorting | hobold | 2009/08/18 06:55 AM |
limits of sorting | rwessel | 2009/09/08 01:52 PM |
maximal theoretical sorting efficiency | Emil | 2009/09/08 06:06 PM |
maximal theoretical sorting efficiency | rwessel | 2009/09/08 09:04 PM |
maximal theoretical sorting efficiency | hobold | 2009/09/09 03:56 AM |
maximal theoretical sorting efficiency | Richard Cownie | 2009/09/09 08:10 AM |
maximal theoretical sorting efficiency | hobold | 2009/09/10 04:39 AM |
maximal theoretical sorting efficiency | Richard Cownie | 2009/09/10 07:05 AM |
maximal theoretical sorting efficiency | Potatoswatter | 2009/09/10 12:23 PM |
maximal theoretical sorting efficiency | dmsc | 2009/09/13 07:04 AM |
limits of sorting | Potatoswatter is back! | 2009/08/21 05:07 PM |
indeed it doesn't succeed in partitioning at all, but you get the idea ;) (NT) | Potatoswatter is back! | 2009/08/21 05:12 PM |
indeed it doesn't succeed in partitioning at all, but you get the idea ;) (NT) | Jouni Osmala | 2009/08/22 12:01 AM |
limits of sorting | hobold | 2009/08/22 06:25 AM |
limits of sorting | Potatoswatter | 2009/08/22 07:45 AM |
limits of sorting | David Kanter | 2009/08/22 09:16 AM |
limits of sorting | Jouni Osmala | 2009/08/22 11:01 AM |
Oops that was counting sort not bucket sort ;( | Jouni Osmala | 2009/08/22 11:07 AM |
close enough for my purposes | hobold | 2009/08/22 01:15 PM |
select vs. cmove | hobold | 2009/08/22 01:25 PM |
How much IPC | Gian-Carlo Pascutto | 2009/08/18 02:25 AM |
How much IPC | Vincent Diepeveen | 2009/08/19 05:46 AM |
How much IPC | _Arthur | 2009/08/19 08:32 AM |
How much IPC | hobold | 2009/08/18 03:17 AM |
How much IPC | Michael S | 2009/08/18 04:33 AM |
How much IPC | hobold | 2009/08/18 06:35 AM |
How much IPC | ? | 2009/08/18 11:20 AM |
How much IPC | _Arthur | 2009/08/18 11:33 AM |
Nit picking | David Kanter | 2009/08/18 01:17 PM |
Nit picking | _Arthur | 2009/08/18 01:37 PM |
Nit picking | Michael S | 2009/08/18 02:02 PM |
Nit picking | S. Rao | 2009/08/18 04:02 PM |
Nit picking | anon | 2009/08/19 02:03 AM |
Nit picking | Michael S | 2009/08/18 01:53 PM |
Nit picking | JasonB | 2009/08/18 06:16 PM |
How much IPC | ? | 2009/08/18 01:37 PM |
How much IPC | _Arthur | 2009/08/18 03:23 PM |
How much IPC | Matt Sayler | 2009/08/18 05:09 PM |
How much IPC | ? | 2009/08/18 10:59 PM |
nick's testcase | a reader | 2009/08/17 04:47 PM |
How much IPC | TruePath | 2009/09/27 09:00 AM |
Explicit dependency chains | David Kanter | 2009/09/30 06:56 PM |
How much IPC | hobold | 2009/08/17 05:38 AM |
How much IPC | anon | 2009/08/16 08:59 PM |
Speeing Up Single Threads | TruePath | 2009/09/27 07:58 AM |
How much IPC | anon | 2009/08/15 07:01 PM |
How much IPC | EduardoS | 2009/08/16 06:06 AM |
How much IPC | sJ | 2009/08/16 08:48 PM |
Power7 vs. single threaded performance and licensing | anon | 2009/08/14 02:26 PM |
Power7 vs. single threaded performance and licensing | Linus Torvalds | 2009/08/14 03:04 PM |
Power7 vs. single threaded performance and licensing | Jonathan Kang | 2009/08/21 02:43 PM |
Power7 vs. single threaded performance and licensing | Linus Torvalds | 2009/08/21 03:08 PM |
Power7 vs. single threaded performance and licensing | Linus Torvalds | 2009/08/21 03:33 PM |
Power7 vs. single threaded performance and licensing | Jonathan Kang | 2009/08/22 07:57 AM |
Power7 vs. single threaded performance and licensing | Jukka Larja | 2009/08/22 10:04 PM |
Power7 vs. single threaded performance and licensing | Jonathan Kang | 2009/08/25 11:33 AM |
Power7 vs. single threaded performance and licensing | ? | 2009/08/21 11:51 PM |
Power7 vs. single threaded performance and licensing | anon | 2009/08/22 09:56 AM |
Power7 vs. single threaded performance and licensing | Linus Torvalds | 2009/08/22 10:38 AM |
Power7 vs. single threaded performance and licensing | ? | 2009/08/23 03:05 AM |
Power7 vs. single threaded performance and licensing | EduardoS | 2009/08/23 03:28 AM |
Programming Larrabee | ? | 2009/08/23 05:48 AM |
Programming Larrabee | EduardoS | 2009/08/23 06:41 AM |
Programming Larrabee | anon | 2009/08/23 07:29 AM |
Programming Larrabee | Potatoswatter | 2009/08/23 06:47 AM |
Programming Larrabee | Richard Cownie | 2009/08/23 08:11 AM |
Programming Larrabee | Potatoswatter | 2009/08/23 11:49 PM |
Programming Larrabee | ? | 2009/08/23 08:59 AM |
Programming Larrabee | Potatoswatter | 2009/08/23 11:44 PM |
Programming Larrabee | hobold | 2009/08/24 05:41 AM |
Programming Larrabee | none | 2009/08/24 07:15 AM |
Programming Larrabee | Richard Cownie | 2009/08/24 07:33 AM |
Programming Larrabee | Jukka Larja | 2009/08/24 09:30 PM |
Programming Larrabee | none | 2009/08/25 01:53 AM |
Programming Larrabee | mpx | 2009/08/25 08:16 AM |
Power7 vs. single threaded performance and licensing | Joe | 2009/08/24 08:38 AM |
Power7 vs. single threaded performance and licensing | Gabriele Svelto | 2009/08/14 03:35 AM |
Power7 vs. single threaded performance and licensing | anon | 2009/08/14 08:18 AM |
Power7 vs. single threaded performance and licensing | EduardoS | 2009/08/14 04:34 PM |
Power7 vs. single threaded performance and licensing | anon | 2009/08/15 06:30 AM |
Power7 vs. single threaded performance and licensing | anon | 2009/08/15 07:23 AM |
improving Netburst | AM | 2009/08/15 01:36 AM |
improving Netburst | anon | 2009/08/15 07:10 AM |
improving Netburst | Euronymous | 2009/08/15 08:35 AM |
improving Netburst | Michael S | 2009/08/15 01:18 PM |
Power7 vs. single threaded performance and licensing | Jonathan Kang | 2009/08/21 03:10 PM |
Power7 vs. single threaded performance and licensing | anon | 2009/08/22 09:46 AM |
Power7 vs. single threaded performance and licensing | Jonathan Kang | 2009/08/25 09:39 AM |
Power7 vs. single threaded performance and licensing | slacker | 2009/08/26 04:50 AM |
Power7 vs. single threaded performance and licensing | Jonathan Kang | 2009/08/26 08:12 AM |
Power7 vs. single threaded performance and licensing | Jonathan Kang | 2009/08/26 08:45 AM |
Power7 vs. single threaded performance and licensing | someone | 2009/08/26 10:29 AM |
Power7 vs. single threaded performance and licensing | David Kanter | 2009/08/26 10:47 AM |
Not necessarily | Daniel Bizó | 2009/08/14 02:53 AM |
new POWER7 info .. | Thu Nguyen | 2009/08/25 03:05 AM |
new POWER7 info .. | someone | 2009/08/25 05:47 AM |
new POWER7 info .. | hobold | 2009/08/25 06:50 AM |
new POWER7 info .. | G Webb | 2009/08/25 11:49 PM |
new POWER7 info .. | mpx | 2009/08/25 07:36 AM |
new POWER7 info .. | someone | 2009/08/25 08:16 AM |
new POWER7 info .. | Jesper Frimann | 2009/08/27 08:18 AM |
new POWER7 info .. | Linus Torvalds | 2009/08/27 10:53 AM |
new POWER7 info .. | someone | 2009/08/27 12:00 PM |
new POWER7 info .. | a reader | 2009/08/27 03:21 PM |
new POWER7 info .. | David Kanter | 2009/08/27 08:32 PM |
new POWER7 info .. | a reader | 2009/08/28 07:45 AM |
new POWER7 info .. | hobold | 2009/08/28 04:00 AM |
new POWER7 info .. | someone | 2009/08/28 05:51 AM |
new POWER7 info .. | hobold | 2009/08/28 06:44 AM |
new POWER7 info .. | someone | 2009/08/28 07:10 AM |
Non Autopar submissions for Nehalem | IlleglWpns | 2009/08/28 09:41 AM |
Non Autopar submissions for Nehalem | David Kanter | 2009/08/28 10:07 AM |
Non Autopar submissions for Nehalem | someone | 2009/08/28 11:00 AM |
new POWER7 info .. | mas | 2009/08/25 11:25 PM |
An EV8 lite? (NT) | anon | 2009/08/26 08:21 AM |
An EV8 lite? => Piranha? | M. | 2009/08/30 03:54 AM |
new POWER7 info .. | Mark Roulo | 2009/08/27 05:51 AM |
new POWER7 info .. | someone | 2009/08/27 06:03 AM |
new POWER7 info .. | a reader | 2009/08/27 08:55 AM |
new POWER7 info .. | someone | 2009/08/27 10:58 AM |
new POWER7 info .. | a reader | 2009/08/27 03:11 PM |
new POWER7 info .. | Gabriele Svelto | 2009/08/27 11:17 PM |
new POWER7 info .. | someone | 2009/08/28 04:27 AM |
new POWER7 info .. | a reader | 2009/08/28 08:07 AM |
OOOE for low power | David Kanter | 2009/08/28 10:15 AM |
OOOE for low power | someone | 2009/08/28 10:39 AM |
OOOE for low power | David Kanter | 2009/08/28 12:55 PM |
OOOE for low power | Mark Roulo | 2009/08/28 02:16 PM |
OOOE for low power | Mark Roulo | 2009/08/28 02:44 PM |
Atom uarch | David Kanter | 2009/08/28 07:19 PM |
OOOE for low power | David Kanter | 2009/08/28 07:07 PM |
OOOE for low power | someone | 2009/08/28 03:18 PM |
OOOE for low power | David Kanter | 2009/08/29 12:55 AM |
OOOE for low power | someone | 2009/08/29 06:21 AM |
OOOE for low power | a reader | 2009/08/29 08:14 AM |
OOOE for low power | someone | 2009/08/29 08:56 AM |
OOOE for low power | David Kanter | 2009/08/29 09:08 AM |
OOOE for low power | Michael S | 2009/08/29 10:27 AM |
OOOE for low power | a reader | 2009/08/29 03:50 PM |
OOOE for low power | anonymous | 2009/08/29 06:17 PM |
OOOE for low power | Michael S | 2009/08/29 11:07 PM |
OOOE for low power | Jonathan Kang | 2009/09/01 04:44 AM |
OOOE for low power | Michael S | 2009/09/01 03:21 PM |
OOOE for low power | Mark Roulo | 2009/09/01 04:53 PM |
OOOE for low power | Wilco | 2009/09/02 01:27 AM |
OOOE for low power | Mark Roulo | 2009/09/02 07:46 AM |
OOOE for low power | Wilco | 2009/09/02 03:52 PM |
Define "emulate" (NT) | Michael S | 2009/09/02 10:44 PM |
Define "emulate" | Wilco | 2009/09/02 11:33 PM |
Define "emulate" | none | 2009/09/03 03:46 AM |
Define "emulate" | Adrian | 2009/09/03 09:45 AM |
Define "emulate" | Wilco | 2009/09/03 01:20 PM |
Define "emulate" | none | 2009/09/03 09:41 PM |
Define "emulate" | Wilco | 2009/09/04 02:30 AM |
low power ARM chips | Michael S | 2009/10/31 01:32 PM |
low power ARM chips | Gabriele Svelto | 2009/10/31 03:05 PM |
low power ARM chips | Michael S | 2009/10/31 03:45 PM |
low power ARM chips | t | 2009/10/31 04:21 PM |
OOOE for low power | David Kanter | 2009/08/29 09:07 AM |
OOOE for low power | someone | 2009/08/29 11:40 AM |
OOOE for low power | a reader | 2009/08/29 04:03 PM |
OOOE for low power | anonymous | 2009/08/29 06:13 PM |
OOOE for low power | someone | 2009/08/30 06:35 AM |
OOOE for low power | David Kanter | 2009/08/30 01:32 PM |
OOOE for low power | Matt Sayler | 2009/08/31 12:38 PM |
OOOE for low power | David Kanter | 2009/08/30 11:07 AM |
OOOE for low power | Michael S | 2009/08/29 10:44 AM |
TTM | Michael S | 2009/08/29 11:24 AM |
TTM | Foo_ | 2009/08/29 12:40 PM |
TTM | Michael S | 2009/08/29 01:10 PM |
TTM | anon | 2009/08/29 06:33 PM |
TTM | Jukka Larja | 2009/08/29 08:49 PM |
TTM | anon | 2009/08/30 05:07 AM |
TTM | Jukka Larja | 2009/08/30 08:31 PM |
Area, power and Atom | David Kanter | 2009/08/30 09:36 PM |
Area, power and Atom | Michael S | 2009/08/30 11:18 PM |
Area, power and Atom | a reader | 2009/08/31 07:44 AM |
Area, power and Atom | Michael S | 2009/08/31 11:19 AM |
Area, power and Atom | a reader | 2009/08/31 01:53 PM |
Area, power and Atom | anonymous | 2009/08/31 03:17 PM |
Area, power and Atom | Gabriele Svelto | 2009/08/31 02:41 PM |
64-bit disabled Atoms | Foo_ | 2009/09/02 03:38 AM |
64-bit disabled Atoms | Robert David Graham | 2009/09/02 11:56 AM |
64-bit disabled Atoms | anon | 2009/09/02 01:14 PM |
64-bit disabled Atoms | anonymous | 2009/09/02 03:30 PM |
TTM | Michael S | 2009/08/30 10:49 PM |
TTM | Jukka Larja | 2009/08/31 10:23 PM |
TTM | Paul | 2009/08/30 05:38 AM |
TTM | Paul | 2009/08/30 05:40 AM |
TTM | Mark Roulo | 2009/08/30 08:50 AM |
TTM | Paul | 2009/08/30 08:54 AM |
TTM | Mark Roulo | 2009/08/30 09:16 AM |
TTM | Foo_ | 2009/09/02 03:31 AM |
OOOE for low power | Rob Thorpe | 2009/08/30 08:19 AM |
OOOE for low power | Michael S | 2009/08/29 10:16 AM |
OOOE for low power | Jukka Larja | 2009/08/29 08:40 PM |
OOOE for low power | Michael S | 2009/08/29 11:04 PM |
OOOE and cache/mem sizes | Richard Cownie | 2009/08/28 04:30 PM |
OOOE and cache/mem sizes | Linus Torvalds | 2009/08/31 09:53 PM |
OOOE and cache/mem sizes | Richard Cownie | 2009/09/01 03:15 AM |
OOOE and pipe length etc. | AM | 2009/09/01 07:35 AM |
OOOE and pipe length etc. | Jouni Osmala | 2009/09/01 07:57 AM |
OOOE and clock rate | AM | 2009/09/02 12:34 AM |
OOOE and clock rate | Jouni Osmala | 2009/09/02 04:35 AM |
OOOE and clock rate | Martin Høyer Kristiansen | 2009/09/02 05:19 AM |
OOOE and clock rate | anon | 2009/09/02 08:43 PM |
OOOE and clock rate | AM | 2009/09/03 01:52 AM |
OOOE and clock rate | Jouni Osmala | 2009/09/03 06:34 AM |
OOOE impacts | AM | 2009/09/04 01:04 AM |
OOOE impacts | David Kanter | 2009/09/04 09:12 AM |
OOOE impacts | Jouni Osmala | 2009/09/06 11:16 AM |
OOOE impacts | AM | 2009/09/07 02:47 AM |
OOOE impacts | Martin Høyer Kristiansen | 2009/09/07 05:03 AM |
Does IBM lie about PPC603 being OoO chip? | AM | 2009/09/08 02:13 AM |
No, but... | Michael S | 2009/09/08 06:05 AM |
No, but... | hobold | 2009/09/09 04:09 AM |
OOOE impacts | JS | 2009/09/07 05:34 AM |
Are Sandpile and others wrong about 0.28 um? | AM | 2009/09/08 02:12 AM |
OOOE impacts | someone | 2009/09/08 05:43 AM |
OOOE impacts | Jouni Osmala | 2009/09/07 06:48 AM |
OOOE costs | David Kanter | 2009/09/07 11:07 AM |
OOOE impacts | AM | 2009/09/08 02:11 AM |
OOOE impacts | Jouni Osmala | 2009/09/10 12:53 AM |
OOOE impacts | AM | 2009/09/11 03:35 AM |
OOOE impacts | Jouni Osmala | 2009/09/11 07:38 AM |
OOOE impacts | AM | 2009/09/12 04:06 AM |
OOOE impacts | Jouni Osmala | 2009/09/12 10:36 PM |
OOOE impacts | AM | 2009/09/14 03:39 AM |
OOOE impacts | Jouni Osmala | 2009/09/14 05:18 AM |
if-ex distance | AM | 2009/09/15 04:16 AM |
small addendum | AM | 2009/09/19 02:54 AM |
small addendum | Jouni Osmala | 2009/09/19 08:51 PM |
small addendum | AM | 2009/09/20 05:54 AM |
small addendum | Jouni Osmala | 2009/09/20 12:16 PM |
small addendum | Thiago Kurovski | 2009/09/20 03:51 PM |
small addendum | Jouni Osmala | 2009/09/20 08:21 PM |
small addendum | Thiago Kurovski | 2009/09/21 05:59 AM |
small addendum | AM | 2009/09/21 02:14 AM |
small addendum | Jukka Larja | 2009/09/21 09:21 PM |
small addendum | AM | 2009/09/22 02:01 AM |
small addendum | Jukka Larja | 2009/09/22 10:31 PM |
small addendum | AM | 2009/09/23 07:35 AM |
small addendum | Jukka Larja | 2009/09/23 09:31 PM |
small addendum | AM | 2009/09/23 11:13 PM |
OT metadiscussion | Jukka Larja | 2009/09/24 08:39 PM |
OT metadiscussion | AM | 2009/09/25 04:18 AM |
Back to bits | Michael S | 2009/09/25 06:14 AM |
Back to bits | Thiago Kurovski | 2009/09/25 10:24 AM |
Back to bits | Wilco | 2009/09/25 02:18 PM |
Back to bits | Thiago Kurovski | 2009/09/26 08:12 AM |
Back to bits | Michael S | 2009/09/26 07:54 AM |
Back to bits | Thiago Kurovski | 2009/09/26 08:05 AM |
Back to bits | Michael S | 2009/09/26 08:16 AM |
Agree, with very minor change. | Jouni Osmala | 2009/09/25 08:37 PM |
Back to bits | AM | 2009/09/26 05:16 AM |
Back to bits | Michael S | 2009/09/26 08:13 AM |
OT metadiscussion | David Kanter | 2009/09/25 11:23 AM |
OT metadiscussion | AM | 2009/09/26 04:55 AM |
OT metadiscussion | Jukka Larja | 2009/09/25 10:33 PM |
OT metadiscussion | AM | 2009/09/26 04:50 AM |
OT metadiscussion | Jukka Larja | 2009/09/27 01:16 AM |
OT metadiscussion | Michael S | 2009/09/27 03:58 AM |
OT metadiscussion | AM | 2009/09/28 03:07 AM |
OT metadiscussion | AM | 2009/09/28 02:43 AM |
OT metadiscussion | Jukka Larja | 2009/09/28 11:45 PM |
OT metadiscussion | AM | 2009/09/30 02:13 AM |
OT metadiscussion | Jukka Larja | 2009/10/01 12:34 AM |
OT metadiscussion | AM | 2009/10/01 03:05 AM |
OT metadiscussion | Jukka Larja | 2009/10/01 11:38 PM |
OT metadiscussion | AM | 2009/10/03 06:19 AM |
OT metadiscussion | Jukka Larja | 2009/10/04 02:38 AM |
OT metadiscussion | AM | 2009/10/04 07:27 AM |
OT metadiscussion | Jukka Larja | 2009/10/04 10:48 PM |
OT metadiscussion | AM | 2009/10/05 06:13 AM |
About teaching | Jukka Larja | 2009/10/05 10:36 PM |
About teaching | AM | 2009/10/06 03:37 AM |
About teaching | Jukka Larja | 2009/10/07 02:15 AM |
About teaching | anon | 2009/10/07 11:39 AM |
About teaching | AM | 2009/10/08 02:11 AM |
About teaching | Jukka Larja | 2009/10/09 03:10 AM |
About teaching | AM | 2009/10/09 04:40 AM |
About teaching | Jukka Larja | 2009/10/09 08:02 PM |
About teaching | AM | 2009/10/09 10:24 PM |
About teaching | Jukka Larja | 2009/10/10 09:50 PM |
About teaching | AM | 2009/10/12 01:02 AM |
About teaching | Jukka Larja | 2009/10/12 09:51 PM |
About teaching | AM | 2009/10/13 03:06 AM |
About teaching | Jukka Larja | 2009/10/13 10:33 PM |
About teaching | AM | 2009/10/14 02:36 AM |
About teaching | Jukka Larja | 2009/10/14 07:19 PM |
About teaching | AM | 2009/10/15 03:22 AM |
About teaching | Salvatore De Dominicis | 2009/10/12 01:23 AM |
About teaching | Dean Kent | 2009/10/12 11:25 AM |
About teaching | Salvatore De Dominicis | 2009/10/13 01:11 AM |
OT metadiscussion | Seni | 2009/09/26 05:26 AM |
OT metadiscussion | Wilco | 2009/09/26 07:08 AM |
OT metadiscussion | Jukka Larja | 2009/09/27 01:18 AM |
OT metadiscussion | Michael S | 2009/09/27 04:12 AM |
small addendum | Jouni Osmala | 2009/09/24 09:04 PM |
small addendum | AM | 2009/09/25 04:04 AM |
extra stage in EV6 | AM | 2009/09/26 05:29 AM |
PPC603 does OoOE | hobold | 2009/09/08 04:40 AM |
OOOE impacts | someone | 2009/09/08 04:39 AM |
EV6 | AM | 2009/09/09 03:33 AM |
OOOE and clock rate | Seni | 2009/09/02 08:11 AM |
OOOE and clock rate | Linus Torvalds | 2009/09/02 05:48 PM |
OOOE and clock rate | anon | 2009/09/02 10:55 PM |
OOOE and clock rate | Wilco | 2009/09/02 11:44 PM |
OOOE and clock rate | Jouni Osmala | 2009/09/03 12:02 AM |
OOOE and Itanium | AM | 2009/09/03 12:27 AM |
OOOE and clock rate | Martin Høyer Kristiansen | 2009/09/03 02:41 AM |
OOOE and clock rate | anon | 2009/09/03 12:12 AM |
OOOE and clock rate | Wilco | 2009/09/03 01:10 AM |
POWER6 skewed pipeline | Paul A. Clayton | 2009/09/03 10:22 AM |
POWER6 skewed pipeline | Anon4 | 2009/09/03 06:00 PM |
OOOE and clock rate | Mr. Camel | 2009/09/03 02:40 AM |
OOOE and clock rate | Richard Cownie | 2009/09/03 05:42 AM |
OOOE and pipe length etc. | Richard Cownie | 2009/09/01 08:01 AM |
OOOE and pipe length etc. | AM | 2009/09/02 12:32 AM |
OOOE and pipe length etc. | Richard Cownie | 2009/09/02 06:49 AM |
LRB choice of P54 | AM | 2009/09/03 12:40 AM |
LRB choice of P54 | Gian-Carlo Pascutto | 2009/09/03 12:45 AM |
LRB choice of P54 | AM | 2009/09/03 02:18 AM |
LRB choice of P54 | Gian-Carlo Pascutto | 2009/09/03 02:55 AM |
LRB choice of P54 | AM | 2009/09/03 03:28 AM |
LRB choice of P54 | Gian-Carlo Pascutto | 2009/09/03 04:29 AM |
Amount of cache per core matters,and mem bandwith too (NT) | Jouni Osmala | 2009/09/03 06:44 AM |
LRB choice of P54 | rwessel | 2009/09/03 01:31 PM |
LRB choice of P54 | AM | 2009/09/04 01:24 AM |
LRB choice of P54 | anon | 2009/09/03 05:40 AM |
LRB choice of P54 | a reader | 2009/09/03 08:20 AM |
LRB choice of P54 | anon | 2009/09/03 04:57 PM |
LRB choice of P54 | Jonathan Kang | 2009/09/03 01:30 PM |
LRB choice of P54 | David Kanter | 2009/09/03 03:38 PM |
LRB choice of P54 | Jonathan Kang | 2009/09/04 07:16 AM |
LRB choice of P54 | anon | 2009/09/03 05:07 PM |
LRB choice of P54 | AM | 2009/09/04 01:20 AM |
LRB choice of P54 | Jonathan Kang | 2009/09/04 07:13 AM |
LRB choice of P54 | Dan Downs | 2009/09/04 07:38 AM |
LRB choice of P54 | Dan Downs | 2009/09/05 03:36 AM |
LRB choice of P54 | Anon | 2009/09/05 01:44 PM |
LRB choice of P54 | AM | 2009/09/04 11:12 PM |
LRB choice of P54 | AM | 2009/09/04 01:18 AM |
LRB choice of P54 | anon | 2009/09/04 07:18 PM |
LRB choice of P54 | AM | 2009/09/04 10:53 PM |
LRB choice of P54 | anon | 2009/09/05 03:06 AM |
LRB choice of P54 | AM | 2009/09/05 08:14 AM |
LRB choice of P54 - Layout? | Anonymous | 2009/09/03 01:40 PM |
LRB choice of P54 - Layout? | anonymous | 2009/09/03 02:54 PM |
LRB choice of P54 | Jukka Larja | 2009/09/03 08:58 PM |
LRB choice of P54 | mpx | 2009/09/04 03:07 AM |
LRB choice of P54 | anon | 2009/09/03 01:02 AM |
OOOE and pipe length etc. | Gian-Carlo Pascutto | 2009/09/03 12:40 AM |
Larrabee: Pentium vs 486 vs 386 | Mark Roulo | 2009/09/03 03:26 PM |
Larrabee: Pentium vs 486 vs 386 | Michael S | 2009/09/03 04:14 PM |
Larrabee: Pentium vs 486 vs 386 | Mark Roulo | 2009/09/04 09:05 AM |
Larrabee: Pentium vs 486 vs 386 | Jonathan Kang | 2009/09/04 09:59 AM |
Larrabee: Pentium vs 486 vs 386 | Michael S | 2009/09/05 08:58 AM |
Larrabee: Pentium vs 486 vs 386 | James | 2009/09/07 02:15 AM |
Larrabee: Pentium vs 486 vs 386 | Mark Roulo | 2009/09/07 06:44 PM |
OOOE and pipe length etc. | Michael S | 2009/09/03 04:42 PM |
LRB core | AM | 2009/09/04 01:09 AM |
LRB core | Michael S | 2009/09/04 04:07 AM |
LRB core | anon | 2009/09/04 07:27 PM |
LRB core | Michael S | 2009/09/05 09:12 AM |
LRB core | anon | 2009/09/05 10:03 PM |
reasons for split I/D L1 caches | Michael S | 2009/09/06 03:10 AM |
reasons for split I/D L1 caches | anon | 2009/09/06 05:32 AM |
reasons for split I/D L1 caches | ? | 2009/09/06 09:35 AM |
reasons for split I/D L1 caches | megol | 2009/09/06 02:39 PM |
reasons for split I/D L1 caches | ? | 2009/09/07 03:20 AM |
reasons for split I/D L1 caches | anon | 2009/09/07 05:25 AM |
cache hinting | ? | 2009/09/07 06:10 AM |
cache hinting | anon | 2009/09/07 06:35 AM |
cache hinting | ? | 2009/09/07 08:10 AM |
cache hinting | anon | 2009/09/07 08:49 AM |
cache hinting | ? | 2009/09/07 09:37 AM |
Split and unified caches | David Kanter | 2009/09/06 12:38 PM |
Split and unified caches | anon | 2009/09/06 10:15 PM |
Split and unified caches | Michael S | 2009/09/06 11:40 PM |
Split and unified caches | anon | 2009/09/07 01:24 AM |
Split and unified caches | David Kanter | 2009/09/06 11:51 PM |
Split and unified caches | anon | 2009/09/07 01:13 AM |
LRB core | AM | 2009/09/04 11:08 PM |
LRB core | Linus Torvalds | 2009/09/05 09:47 AM |
LRB core | David Kanter | 2009/09/04 12:23 PM |
LRB core | Anon | 2009/09/04 05:32 PM |
LRB core | David Kanter | 2009/09/04 09:15 PM |
LRB core | Michael S | 2009/09/05 09:21 AM |
OOOE and cache/mem sizes | a reader | 2009/09/01 08:19 AM |
OOOE and cache/mem sizes | Richard Cownie | 2009/09/01 08:43 AM |
snapdraon? | Michael S | 2009/08/28 05:10 AM |
snapdraon? | a reader | 2009/08/28 07:51 AM |
Thanks (NT) | Michael S | 2009/08/29 11:53 AM |
snapdraon? | Paul | 2009/08/28 12:12 PM |
new POWER7 info .. | EduardoS | 2009/08/27 02:41 PM |
new POWER7 info .. | Jesper Frimann | 2009/08/28 04:03 AM |
Single threaded performance | David Kanter | 2009/08/28 09:52 AM |
Hot Chips XXI Preview online | hobold | 2009/08/13 06:30 AM |
